QTS-048-01-L-D-DP-RA-WT
    SAMTEC(申泰)
    CONN DIFF ARRAY PLUG 96P R/A SMD
QTS-048-01-L-D-DP-RA-WT 数据手册
F-219 QTS–025–01–F–D–RA ® QTS–050–01–F–D–RA–WT (0.635 mm) .025" QTS-RA SERIES RIGHT-ANGLE GROUND PLANE HEADER Integral metal plane for power or ground Board Mates: QSS SPECIFICATIONS Rightangle For complete specifications and recommended PCB layouts see www.samtec.com?QTS-RA Selectively plated Insulator Material: Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: Contact: 2 A per pin (2 pins powered) Ground Plane: 15.7 A per ground plane (1 ground plane powered) Operating Temp Range: -55 °C to +125 °C Voltage Rating: 275 VAC mated with QSS-RA RoHS Compliant: Yes • Guide posts APPLICATIONS • Weld tabs • PCB mounting holes • Solder pin option HORIZONTAL HIGH-SPEED CHANNEL PERFORMANCE QTS-RA/QSS-RA or QTS-RA/QSS-D Rating based on Samtec reference channel. For full SI performance data visit Samtec.com or contact SIG@samtec.com PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (025-075) 14 G b p s NO. OF POSITIONS PER ROW QTS Guide post 01 PLATING OPTION RA D PERPENDICULAR OTHER OPTION WT RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality –F –025, –050, –075 = Gold Flash on Signal Pins and Ground Plane, Matte Tin on tails (50 total positions per bank) FILE NO. E111594 –SP –WT = Solder Pin = Weld Tab (Not available on 25 positions) –L = 10 µ" (0.25 µm) Gold on Signal Pins and Ground Plane, Matte Tin on tails ALSO AVAILABLE (MOQ Required) • 30 µ" (0.76 µm) Gold • Differential Pair • “Partitionable” (combine differential & single-ended banks in same connector) • Lead Style for (2.36 mm) .093" thick board • –LS1 Locking Screw (Mates with QSS-RA-LS1) • –LS2 Locking Screw (Mates with QSS-LS2) • 100 positions per row (No. of Positions per Row/25) x (20.00) .7875 + (14.73) .580 (No. of Positions per Row/25) x (20.00) .7875 + (8.38) .330 (3.18) .125 DIA (6.35) .250 DIA (10.29) (3.05) (7.11) .405 .120 .280 (3.18) .125 DIA 01 (No. of Positions per Row/25) x (20.00) .7875 + (5.72) .225 02 (0.38) .015 (2.03) .080 (0.635) .025 SQ (0.635) .025 (0.89) .035 DIA –SP OPTION (5.08) .200 (5.97) (9.42) .235 .371 Note: Some lengths, styles and options are non-standard, non-returnable. (1.40) .055 (0.20) .008 (1.50) .059 (0.10) .004 (0.30) .012 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. (1.73) .068
QTS-048-01-L-D-DP-RA-WT 价格&库存
很抱歉,暂时无法提供与“QTS-048-01-L-D-DP-RA-WT”相匹配的价格&库存,您可以联系我们找货
  • 16+197.9900716+25.64324
