SFMC-111-02-SM-D-P-TR 数据手册
FLEXIBLE PIN COUNT
TIGER EYE™ SOCKET 2.9 8
MAX
A
(1.27 mm) .050" PITCH • SFMC SERIES
SFMC
Board Mates:
TFM
Cable Mates:
FMTP, FFMD*
SFMC
-1
NO. PINS
PER ROW
m
p
s
LEAD
STYLE
02 thru 50
G b p s
PLATING
OPTION
–01, –03
D
–L
= Through-hole
*Note: Standard FFMD callout
will not mate with FLE, SFMC.
Must use gold plated callouts.
(See drawing on web.)
–K
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–L1, –L3
= Low
Insertion
Force
Through-hole
= (4.00 mm) .157"
DIA Polyimide film
Pick & Place Pad
(4 positions min.)
–P
= Plastic Pick
& Place Pad
(5 positions min.)
–02
= Surface Mount
SPECIFICATIONS
PROCESSING
–TR
–L2
= Tape & Reel
= Low
Insertion
Force
Surface Mount
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
Tiger Eye™ = BeCu
Tiger Eye™ LITE=
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
2.9 A per pin
(2 pins powered)
Voltage Rating:
220 VAC/310 VDC
Operating Temp Range:
-55 °C to +125 °C
Insertion Depth:
(3.05 mm) .120" to
(4.06 mm) .160"
Max Cycles:
10,000 with 30 µ" (0.76 µm) Au
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
–T1
= Through-hole
Tiger Eye™ LITE
–T2
= Surface Mount
Tiger Eye™ LITE
(10.00)
.394
x
(5.72)
.225
(1.27) .050 x No. of Positions
+ (0.38) .015
(3.05)
.120
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (02-26)
(0.15 mm) .006" max (27-50)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
–P OPTION
(4.57)
.180
(4.70)
.185
A
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
F-224
(4.19)
.165
B
ALSO AVAILABLE
Other plating
(MOQ Required)
OPTIONS
LEAD
STYLE
A
B
–01, –L1, –T1
(3.05) .120
(0.51) .020
–03, –L3
(1.91) .075
(0.41) .016
View complete specifications at: samtec.com?SFMC
samtec.com/127mm-TigerEye
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
SFMC-111-02-SM-D-P-TR 价格&库存
很抱歉,暂时无法提供与“SFMC-111-02-SM-D-P-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 725+35.60848725+4.61193
