02P-SJN
02P-SJN
    JST
    P=2mm
    1X2P 2MM
02P-SJN 数据手册
SJN CONNECTOR 2.0mm pitch/Board-in Crimp style connectors 2 4 5 6 9 T BJS 1 3 8 U 7 U- Specifications ––––––––––––––––––– Side entry type board-in connector, with a mounting height of only 2.8mm and a thickness of 4.9mm. • Housing lances • Easy mounting onto printed circuit boards • Current rating: 3A AC, DC (AWG #22) • Voltage rating: 250V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 800V AC/minute • Applicable wire: AWG #28 to #22 • Applicable PC board thickness: 1.2 to 1.6mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 Recognized E60389 PC board layout (viewed from soldering side) and Assembly layout 2.8 4.9 5.45 1.2min 3.5min 2.0±0.05 φ0.9±0.03 Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 1 SJN CONNECTOR Contact Applicable wire AWG # mm2 Model No. 0.95 SJN-001PT-0.9 SJN-002PT-0.9 Insulation O.D.(mm) Q’ty / reel 0.20∼0.33 24∼22 1.1∼1.4 15,000 0.08∼0.22 28∼24 0.9∼1.4 18,000 Material and Finish (5.4) Brass, tin-plated (reflow treatment) RoHS compliance Note: Contact JST if you require shielded wires, thin wires or other special wires. Crimping machine Crimp applicator Contact SJN-001PT-0.9 AP-K2N 0.2 4.0 0.9 0.8 SJN-002PT-0.9 0.6 Applicator Dies Crimp applicator with dies MKS-L MK/SJN-001-09 APLMK SJN001-09 − − − MKS-L MK/SJN-002-09 APLMK SJN002-09 − − − Housing Circuits B A 2.0 2.8 4.9 1 2 7 8 9 JST Model No. A Dimensions (mm) B 2 02P-SJN 2.0 4.4 2,000 3 03P-SJN 4.0 6.4 1,000 4 04P-SJN 6.0 8.4 1,000 6 06P-SJN 10.0 12.4 1,000 7 07P-SJN 12.0 14.4 1,000 8 08P-SJN 14.0 16.4 1,000 9 09P-SJN 16.0 18.4 1,000 10 10P-SJN 18.0 20.4 1,000 Material PA 66, UL94V-0, natural (white) RoHS compliance 2 Q’ty / bag
02P-SJN 价格&库存
很抱歉,暂时无法提供与“02P-SJN”相匹配的价格&库存,您可以联系我们找货
02P-SJN
    • 5+0.47950
    • 50+0.42440
    • 150+0.39680
    • 500+0.37610
    • 2000+0.35950
    • 4000+0.35120
    库存:17310
    02P-SJN
      • 1000+0.31390
      库存:21284
      02P-SJN
      • 5+0.42801
      • 50+0.37876
      • 150+0.35414
      • 500+0.33567
      • 2000+0.32087
      • 4000+0.31353
      库存:17270
      02P-SJN
        库存:164000
        02P-SJN
          库存:12000
