08914090108A0
08914090108A0
    HARTING(浩亭)
    HARTING - 08914090108A0 - CHRGING CBLE, IEC 62196-2 RCPT-PLUG/7.5M
08914090108A0 数据手册
Product data sheet 08 91 409 0108 A0 Charging cable Mode3 Typ2 32A 1ph 7,5m Charging cable Mode3 Typ2 32A 1ph 7,5m Part number 08 91 409 0108 A0 Specification Charging cable Mode3 Typ2 32A 1ph 7,5m HARTING eCatalogue https://b2b.harting.com/08914090108A0 Image is for illustration purposes only. Please refer to product description. Identification Element Charging cable Specification Straight Charging mode Mode 3 Connector 1 Type 2 Female (Vehicle side) Connector 2 Type 2 Male (infrastructure side) Version Cable length 7.5 m Termination method Crimp termination Core structure 3x 6 mm² + 0.5 mm² Number of phases 1 Number of contacts 5 Number of signal contacts 2 Number of power contacts 3 Contact configuration Signal: CP, PP Power: L1, N, PE Details Also available with customer specific logo on request. Technical characteristics Rated current (signal) 2 A Rated voltage (signal) 30 V Rated current (power) 32 A Page 1 / 3 | Creation date 2021-07-06 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Automotive GmbH | Marienwerderstraße 2 | D-32339 Espelkamp | Germany Product data sheet 08 91 409 0108 A0 Charging cable Mode3 Typ2 32A 1ph 7,5m Technical characteristics Rated voltage (power) 250 V Type of current AC Charging power 7.4 kW Coding resistance 220 Ω between PE and PP Ambient temperature -30 ... +50 °C in operation -40 ... +80 °C storage/transport Air pressure ≥540 hPa ≈ 5000 m Insertion force
08914090108A0 价格&库存
很抱歉,暂时无法提供与“08914090108A0”相匹配的价格&库存,您可以联系我们找货
08914090108A0
    • 1+2150.04909
    库存:3
    08914090108A0
    • 1+2525.38686
    库存:3
    08914090108A0
    • 2+2075.77091
    • 6+2023.88183
    • 24+1973.27871
    • 48+1923.95142
    • 84+1875.85441
    库存:11
