08914090301A0
08914090301A0
    HARTING(浩亭)
    HARTING - 08914090301A0 - CHARGING CBLE, IEC 62196-2 RCPT-PLUG, 5M
08914090301A0 数据手册
Product data sheet 08 91 409 0301 A0 Cable Mode3 Type2 20A 3ph 5m spiral Cable Mode3 Type2 20A 3ph 5m spiral Part number 08 91 409 0301 A0 Specification Cable Mode3 Type2 20A 3ph 5m spiral HARTING eCatalogue https://b2b.harting.com/08914090301A0 Image is for illustration purposes only. Please refer to product description. Identification Element Charging cable Specification Spiralised Charging mode Mode 3 Connector 1 Type 2 Female (Vehicle side) Connector 2 Type 2 Male (infrastructure side) Version Cable length 5 m Termination method Crimp termination Core structure 5x 2.5 mm² + 0.5 mm² Number of phases 3 Number of contacts 7 Number of signal contacts 2 Number of power contacts 5 Contact configuration Signal: CP, PP Power: L1, L2, L3, N, PE Technical characteristics Rated current (signal) 2 A Rated voltage (signal) 30 V Rated current (power) 20 A Rated voltage (power) 480 V Page 1 / 3 | Creation date 2021-07-06 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Automotive GmbH | Marienwerderstraße 2 | D-32339 Espelkamp | Germany Product data sheet 08 91 409 0301 A0 Cable Mode3 Type2 20A 3ph 5m spiral Technical characteristics Type of current AC Charging power 11 kW Coding resistance 680 Ω between PE and PP Ambient temperature -30 ... +50 °C in operation -40 ... +80 °C storage/transport Air pressure ≥540 hPa ≈ 5000 m Insertion force
08914090301A0 价格&库存
很抱歉,暂时无法提供与“08914090301A0”相匹配的价格&库存,您可以联系我们找货
