Han® PCB adapter
Contents
Page
Technical characteristics Han DD® with PCB adapter . . . . . . . . . . . . . . . . .
20.02
Han DD® with PCB adapter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.03
Technical characteristics Han E® with PCB adapter . . . . . . . . . . . . . . . . . .
20.04
Han E® with PCB adapter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.05
Technical characteristics Han® Q 4/2 with PCB adapter . . . . . . . . . . . . . . .
20.06
Han® Q 4/2 with PCB adapter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.07
Technical characteristics Han® Q 5/0 with PCB adapter . . . . . . . . . . . . . . .
20.08
Han® Q 5/0 with PCB adapter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.09
Technical characteristics Han® Q 7/0 with PCB adapter . . . . . . . . . . . . . . .
20.10
Han® Q 7/0 with PCB adapter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.11
Technical characteristics Han® Q 8/0 with PCB adapter . . . . . . . . . . . . . . .
20.12
Han® Q 8/0 with PCB adapter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.13
Technical characteristics Han-Modular® with PCB adapter . . . . . . . . . . . . .
20.14
Han-Modular® with PCB adapter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.15
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.16
PCBAdapter
Features
O
Robust design
Approvals
O
Suitable for standard and EMC housing
Inserts
O
Low wiring costs
O
Higher contact density
Number of contacts
24, 42, 72, 108
Electrical data
acc. to DIN EN 61 984
7.5 A
250 V
4 kV
Working current
Working voltage
Rated impulse voltage
Pollution degree
Working voltage
acc. to UL
250 V
Testing voltage Urms
Insulation resistance
Material
Limiting temperatures
Flammability acc. to UL 94
Mechanical working life
- Mating cycles
Wire gauge
2 kV
q 1010 7
Polyamide
- 40 OC / +125 OC
HB
q500
0.14 - 2.5 mm²
Layout of printed circuit boards
Han® 24 DD
PCBAdapter
Han® 42 DD
Han® 72 DD
Han® 108 DD
Recommended hole diameter: 0.8 mm
Assembly situation
PCB adapter
Printed circuit board
Switch board panel
Han® D double contact
Han® B bulkhead mounted housing
1)
Han DD® insert
for Han® B EMC hoods/housings spacing of 12.5 ± 0.2 is necessary as no flange seal is used.
3
Han DD® inserts with PCB adapter
Insert
Size
Part No.
Male insert (M)
Female insert (F)
250 V
Drawing
Dimensions in mm
1)
Order contacts
separately
Han® 24 DD
Han® 42 DD
Han® 72 DD
Han® 108 DD
7.5 A
6B
10 B
16 B
24 B
Han D® double contacts
09 16 024 3001
09 16 042 3001
09 16 072 3001
09 16 108 3001
09 16 024 3101
09 16 042 3101
09 16 072 3101
09 16 108 3101
Part No.
Male contacts
Female contacts
Distance for contact
max. 21 mm
24 DD
42 DD
72 DD
108 DD
a
44.5
57.5
77.5
104.5
b
51.5
64.5
84.5
111.5
Drawing
Dimensions in mm
Drawing
Dimensions in mm
to connect
the PCB adapter
Device side
09 15 000 6191
PCB adapter
09 15 000 6291
Part No.
09 16 000 9905
09 16 000 9908
for PCBs up to 1.6 mm
for PCBs up to 2.4 mm
09 16 000 9905
09 16 000 9908
a
2.6
3.4
PCBAdapter
Cable side
Housing
Size
Part No.
6B
10 B
16 B
24 B
09 30 006 0301
09 30 010 0301
09 30 016 0301
09 30 024 0301
Drawing
Size
6B
10 B
16 B
24 B
Dimensions in mm
a
b
70
80
83
93
103 113
130 140
Panel cut out
48 x 35
60 x 35
82 x 35
108 x 35
Size 6 B with
1 locking lever
Further informations
see chapter 02 (Han D ® / DD ®)
Stock items in bold type
Features
O
Inserts
Robust design
O
Suitable for standard and EMC housings
O
Low wiring costs
O
Counter connector available with screw,
crimp or cage clamp termination
Number of contacts
6, 10, 16, 24
Electrical data
16 A
500 V
6 kV
Working current
Working voltage
Pollution degree
Material
- Mating cycles
Wire gauge
q 1010 7
Polycarbonate
- 40 OC / +125 OC
V0
q500
0.5 - 4 mm²
Han® 6 E
Han® 10 E
Han® 16 E
Han® 24 E
Recommended hole diameter: 1.8 mm
PCBAdapter
Assembly situation
PCB
adapter
Han® B housing
bulkhead mounting
Han E® Insert
1)
for Han® B EMC hoods/housings spacing of 12.5 ± 0.7 is necessary as no flange seal is used
Printed
circuit board
Switch cabinet
panel
Han E® double contact
3
Han E® inserts with PCB adapter
500 V
Part No.
Size
Male insert (M) Female insert (F)
Inserts
Drawing
Dimensions in mm
Order contacts
separately
Han® 6 E
Han® 10 E
Han® 16 E
Han® 24 E
16 A
1)
6 B
10 B
16 B
24 B
09 33 006 2602
09 33 010 2602
09 33 016 2602
09 33 024 2602
09 33 006 2702
09 33 010 2702
09 33 016 2702
09 33 024 2702
Part No.
Male contacts Female contacts
Han E® double contacts
istance for conD
tact
max. 21 mm
a
b
6 E 44.5 51.5
10 E 57.5 64.5
16 E 77.5 84.5
24 E 104.5 111.5
Drawing
Dimensions in mm
Drawing
Dimensions in mm
to connect
the PCB adapter
Device side
09 33 000 6180
PCB adapter
09 33 000 6280
Part No.
09 33 000 9996
PCBAdapter
Housing
Cable side
Size
Part No.
6 B
10 B
16 B
24 B
09 30 006 0301
09 30 010 0301
09 30 016 0301
09 30 024 0301
Drawing
Size
6 B
10 B
16 B
24 B
Dimensions in mm
a
b
70 80
83 93
103 113
130 140
Panel cut out
48 x 35
60 x 35
82 x 35
108 x 35
Size 6 B with
1 locking lever
see chapter 03 (Han E ®)
Han02_Kap20_AT .indd 5
03 .04 .2009 08:10:31
Features
O
Robust Design
Approvals
O
Suitable for Han-Compact® hoods and housings
Number of contacts
O
Low wiring costs
Electrical data acc. to
DIN EN 61 984
O
High contact density
4/2 + PE
Power area
Rated current
Rated voltage
conductor - ground
conductor - conductor
Pollution degree
Signal area
Rated current
Rated voltage
Pollution degree
30 A 400/690 V 6 kV 2
30 A
400 V
690 V
6 kV
2
7.5 A 250 V 4 kV 2
7.5 A
250 V
4 kV
2
q 1010 7
LCP
-40 °C ... +125 °C
V0
q500 mating cycles
Material – PCB adapter
PCBAdapter
Assembly situation
PCB
X = 16+1 with signal contact
16+2 without signal contact
PCB adapter
Wall of cabinet
Han-Compact®
Han C ® double contact
Han® Q 4/2 insert
400/690 V
250 V
Han® Q 4/2 inserts with PCB adapter
Part No.
Insert
Drawing
30 A
7,5 A
Dimensions in mm
Contact arrangement
Order contacts
separately
View from termination side
09 12 006 3041
PCB adapter
09 12 006 3141
Part No.
Drawing
Dimensions in mm
Drawing
Dimensions in mm
Device side
09 12 006 9901
Part No.
Double contacts
Male contact Female contact
to connect the PCB adapter
Han C ® double contacts
Power contact
Han D ® double contacts
Signal contact
09 32 000 6180
09 32 000 6280
09 15 000 6191
09 15 000 6293
Housing Han-Compact ®
Part No.
Housing bulkead mounting
Plastic
PCBAdapter
Drawing
Dimensions in mm
Panel cut out
Cable side
09 12 008 0327
see chapter 13 (Han® Q)
Han02_Kap20_AT .indd 7
03 .04 .2009 08:10:43
Features
O
Robust design
Approvals
O
Suitable for EMC housings
Inserts
O
Low wiring costs
O
Additional robust and secure PE-connection
between housing and PCB
Number of contacts
5
Electrical data
10 A
230/400 V
Working current
Working voltage conductor – ground
Working voltage conductor – conductor
Pollution degree
- pollution degree 2 also
10 A 320/500 V 4 kV 2
Working voltage
acc. to UL/CSA
400 V
Material
- Mating cycles
q 1010 7
Polycarbonate
- 40 OC … +125 OC
V0
q500
Recommended hole diameter: 2.6 mm
Recommended hole diameter: 1.5 mm
PCBAdapter
Assembly situation
Han® 3 A bulkhead mounted housing
Han® Q 5/0
Solder
contacts
PCB adapter
4 kV 3
Connection to printed circuit board
Han® Q 5/0 inserts with PCB adapter
Part No.
Male insert (M)
Female insert (F)
Insert
230/400 V
16 A
Drawing
Dimensions in mm
Drawing
Dimensions in mm
Order contacts
separately
09 12 005 3001
PCB adapter
09 12 005 3101
Part No.
with PE contact panel
Device side
09 12 000 9905
Adapter
Solder contacts
Part No.
Male contact
Female contact
Drawing
PE contact panel
Dimensions in mm
to connect the
PCB adapter
09 33 000 6195
09 33 000 6295
PCBAdapter
Housing
bulkead mounting
Part No.
Drawing
Dimensions in mm
Panel cut out
22 x 22 mm
Cable side
09 62 003 0304
Features
O
Robust design
Approvals
O
Inserts
O
Low cost wiring
O
Number of contacts
7
Electrical data
7.5 A 250 V
4 kV
3
Working current
Working voltage
Pollution degree
Material
- Mating cycles
q 1010 7
Polycarbonate
- 40 OC … +125 OC
V0
q500
Dimensions in mm
PCBAdapter
Assembly situation
PCB
PCB adapter
Wall of switching cabinet
Han® D Double contact
Han® Q 7/0 Contact insert
Han® Q 7/0 inserts with PCB adapter
Part No.
Male insert (M)
Female insert (F)
Insert
250 V
7,5 A
Drawing
Dimensions in mm
Drawing
Dimensions in mm
Drawing
Dimensions in mm
Order contacts separately
Coding
09 12 007 3001
09 12 007 3101
09 12 000 9901
09 12 000 9902
PCB adapter
Part No.
for PCB up to 2.4 mm
Device side
09 12 000 9908
Part No.
Male contact
Female contact
to connect the
PCB adapter
09 15 000 6190
09 15 000 6290
PCBAdapter
Housing
bulkead mounting
Part No.
Drawing
Dimensions in mm
Panel cut out
22 x 22 mm
Cable side
09 20 003 0301
Features
O
Robust Design
Approvals
O
Number of contacts
O
Low wiring costs
DIN EN 61 984
O
Rated current
Rated voltage
conductor - ground
Pollution degree
8
16 A 230/400 V 4 kV 2
16 A
230 V
400 V
4 kV
2
q 1010 7
LCP
-40 °C ... +125 °C
V0
q500 mating cycles
PCBAdapter
Assembly situation
PCB
PCB adapter
Wall of cabinet
Han-Compact®
Han® E double contact
Han® Q 8/0 insert
Han® Q 8/0 inserts with PCB adapter
Part No.
Male insert (M)
Female insert (F)
Insert
230/400 V
Drawing
16 A
Dimensions in mm
Contact arrangement
Order contacts
separately
09 12 008 3001
PCB adapter
09 12 008 3101
Part No.
Drawing
Dimensions in mm
Drawing
Dimensions in mm
Device side
09 12 008 9901
Han® E double contacts
Part No.
Male contact
Female contact
09 33 000 6180
09 33 000 6280
PCBAdapter
Housing
bulkead mounting
Part No.
Plastic
Drawing
Dimensions in mm
Panel cut out
Cable side
09 12 008 0327
Features
O
Modular assembly
Han DD® module with PCB adapter
O
Robust design
O
O
Low wiring costs
Number of contacts
Working current
Working voltage
Wire gauge
Han® 40 A module for PCB adaptions
Number of contacts
Working current
Working voltage
Wire gauge
Recommended
hole diameter: 3,2 mm
Han DD® module
Han® 40 A module
Assembly situation
Han DD® solder adapter
Han® B bulkhead
mounted housing
2
40 A
500 V
2.5 - 10 mm²
Depiction
Recommended
hole diameter: 0,8 mm
PCBAdapter
12
7.5 A
250 V
0.14 - 2.5 mm²
1)
Solder contact
Switch cabinet panel
Module for connection
Han-Modular®
Hinged frame
No. of
modules
1
2
3
4
6
Identification
Part No.
Male insert (M)
Female insert (F)
Size
Figure
09 14 000 0304
09 14 006 0303
09 14 010 0303
09 14 016 0303
09 14 024 0303
10 A
6B
10 B
16 B
24 B
Drawings and further details
see chapter 06 (Han-Modular®)
09 14 000 0304
09 14 006 0313
09 14 010 0313
09 14 016 0313
09 14 024 0313
Part No.
Male insert (M)
Female insert (F)
Drawing
Dimensions in mm
Han DD® module
PCB termination/
crimp termination
09 14 012 3001
09 14 012 3101
09 15 000 6191
09 15 000 6291
to connect the PCB
PCB adapter
09 16 000 9905
09 16 000 9908
09 16 000 9905
09 16 000 9908
a
2.6
3.4
PCBAdapter
Han® 40 A module
Part No.
Male insert (M)
Female insert (F)
Drawing
Dimensions in mm
Axial screw termination
Cable side
09 14 002 2601
09 14 002 2701
09 14 002 2603
09 14 002 2703
PCB adaption
Device side
Solder contact
09 32 000 6295
Han® PCB adapter
Applications
L
Secondary mating between industrial connector and
printed circuit board.
L
No higher force is applied on the soldering joint when
mating the industrial connector due to an additional mating point.
L
No wiring between printed circuit board and industrial
connector necessary.
Han DD® and Han® Q 5/0 PCB adapter
Wilhelm Fette GmbH, Germany
L
thus no wiring faults
§ no testing, no costs
L
Connecting times are minimized.
Han E® PCB adapter
L
Easy handling is time and cost saving.
L
The production of mechanical and electrical / electronical
components can be completely separated.
L
Possibility to reach a higher degree of automation in the
production (i. e. wave soldering of the PCBs).
PCB adapter Han E®
PCBAdapter
Han E® connector in a bulkhead mounted housing
很抱歉,暂时无法提供与“09 12 007 3101”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+94.85027
- 20+92.95391
- 40+91.09400
