Han® Q 12/0
Han-Quick Lock®
Number of contacts
12 +
Inserts
Identification
Part Number
Male insert
Female insert
Han® Q 12/0
Dimensions in mm
09 12 012 3001
09 12 012 3101
Coding pins
09 12 000 9924
09 12 000 9924
order separately
1 unit à 20 pieces
Identification
Wire gauge
Part Number
mm²
Male contacts
Female contacts
Dimensions in mm
Han D® crimp contacts
silver plated
gold plated
0.14-0.37
0.5
0.75
1.0
1.5
2.5
09 15 000 6104
09 15 000 6103
09 15 000 6105
09 15 000 6102
09 15 000 6101
09 15 000 6106
09 15 000 6204
09 15 000 6203
09 15 000 6205
09 15 000 6202
09 15 000 6201
09 15 000 6206
0.14-0.37
0.5
0.75
1.0
1.5
2.5
09 15 000 6124
09 15 000 6123
09 15 000 6125
09 15 000 6122
09 15 000 6121
09 15 000 6126
09 15 000 6224
09 15 000 6223
09 15 000 6225
09 15 000 6222
09 15 000 6221
09 15 000 6226
Wire gauge
0.14-0.37 mm²
0.5 mm²
0.75 mm²
1.0 mm²
1.5 mm²
2.5 mm²
AWG 26-22
AWG 20
AWG 18
AWG 18
AWG 16
AWG 14
ø
Stripping
length
0.90 mm
1.10 mm
1.30 mm
1.45 mm
1.75 mm
2.25 mm
8 mm
8 mm
8 mm
8 mm
8 mm
6 mm
Han® Data sheet 0368
Han® Q 12/0
Features
Technical characteristics
• 12 contact chambers taking the cotrol
contacts of the series Han D® with crimp
termination
• 1 PE contact with innovative Han-Quick
Lock® termination technology
• 2 coding pins
• Insert suitable for metal and plastic hoods
and housings of the series Han® 3 A
Specifications
DIN VDE 0627
DIN VDE 0110
DIN EN 61 984
Inserts
Number of contacts
Electrical data acc. to
DIN EN 61 984
Rated current
Rated voltage
Rated impulse voltage
Pollution degree
Pollution degree 2 also
Termination Han D® contacts
Termination PE contact
Wire gauge PE contact
Insulation resistance
Material
Limiting temperatures
Flammability acc. to UL 94
12 + PE
10 A 400 V 6 kV 3
10 A
400 V
4 kV
3
10 A 400/690 V 6 kV 2
Crimp
Han-Quick Lock®
0.5 – 2.5 mm²
AWG 20 – 14
≥ 1010 Ω
Polycarbonate
-40 °C ... +125 °C
V0
Mechanical working life
≥ 500 mating cycles
Contacts
Material
Surface
- hard silver plated
- hard gold plated
Contact resistance
Crimp termination
- mm²
- AWG
Maximum insilation cross section
- power contacts
Copper alloy
3 µm Ag
2 µm Au over 3 µm Ni
≤ 3 mΩ
0.14 – 2.5 mm²
26 – 14
ø = 5 mm
Plastic hoods/ housings
Material
Locking element
Hoods/ housings seal
Degree of protection acc. to
DIN EN 60 529 in locked position
Polycarbonate
Polyamide
V0
NBR
-40 °C ... +125 °C
IP 67
Metal hoods/ housings
Material
Locking element
Die cast zinc alloy
Steel galvanized
NBR
-40 °C ... +125 °C
IP 44
IP 67 with sealing screw
09 20 000 9918
HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp
Fon: +49 57 72 47-97100 | Fax: +49 57 72 47-124
Internet: www.HARTING.com | E-Mail: HARTING.Electric@HARTING.com
2007-11-06
很抱歉,暂时无法提供与“09 15 000 6102”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+12.348641+1.54914
- 10+10.4836410+1.31518
- 25+9.8297725+1.23315
- 50+9.3587050+1.17406
- 100+8.91199100+1.11802
- 300+8.24640300+1.03452
- 500+7.95424500+0.99787
- 1000+7.574581000+0.95024
- 2500+7.100412500+0.89075
- 国内价格 香港价格
- 10+7.4766710+0.93795
- 30+7.2997130+0.91575
- 125+7.03427125+0.88245
- 300+6.90154300+0.86580
- 1250+6.547621250+0.82140
