09 33 006 2702
09 33 006 2702
    HARTING(浩亭)
09 33 006 2702 数据手册
Han® Thermocouple Connector for compensating wires Identification Screw termination* Series Part No. Male inserts Female inserts Contact arrangement View: termination side Dimensions in mm ® Han E With wire protection Crimp termination* Order contacts separately Crimp termination* Order contacts separately Crimp termination* 10 09 33 010 2691 09 33 010 2791 16 24 09 33 016 2691 09 33 016 2791 09 33 024 2691 09 33 024 2791 Contacts Fe Contacts CuNi M F M F M F M F M F Han® E 6 10 16 24 09 33 006 2602 09 33 010 2602 09 33 016 2602 09 33 024 2602 09 33 006 2702 09 33 010 2702 09 33 016 2702 09 33 024 2702 09 32 010 3001 09 32 018 3001 09 32 032 3001 09 32 046 3001 09 32 010 3101 09 32 018 3101 09 32 032 3101 09 32 046 3101 Han® EE 10 18 32 46 Han® Q 5/0 Order contacts separately 5 Crimp termination* Order contacts separately Identification 09 12 005 3001 09 12 005 3101 Han® A 10 09 20 010 3001 09 20 010 3101 16 09 20 016 3001 09 20 016 3101 Wire gauge mm² Male inserts Female inserts Drawing Dimensions in mm Crimp contacts Constantan 0.5 09 33 000 6162 09 33 000 6262 Iron gold plated 0.5 09 33 000 6172 09 33 000 6272 * For insert dimensions see 'Han Industrial Connectors' Catalogue Han Data Sheet 0045-1 Han® Thermocouple Technical Details Specifications Features DIN VDE 0627 DIN VDE 0110 Inserts Working current Working voltage - Han® E - Han® EE - Han® Q 5/0 - Han® A Degree of pollution Insulation resistance Material Ambient temperature Flammability acc. to UL 94 Mechanical working life - Mating cycles 16 A max. 400 V 500 V 230/400 V 250 V 3 (C) Þ 1010=t Polycarbonate - 40° ... + 125°C V0 Þ 500 • Connector for temperature control wire • Iron and constantan contacts acc. to DIN IEC 584 Type J • Screw and crimp termination • Mixed loading of thermocouple crimp contacts and standard Han®-E power contacts in one insert is possible • Further combinations with Han-Modular® are possible • Special housings and inserts with crimp termination also for higher ambient temperatures available • Ideal for injection moulding machines Contacts Material Identification acc. to DIN IEC 584 Surface Contact resistance Crimp termination Screw termination - Starting/testing torque Material Identification acc. to DIN IEC 584 Surface Contact resistance Crimp termination Screw termination - Starting/testing torque Iron, Fe Type J Gold plated Î 1 mt 0.5 mm² (AWG 20) 2.5 mm² (AWG 14) 0.5 Nm Constantan, CuNi Type J Uncoated Î 1 mt 0.5 mm² (AWG 20) 2.5 mm² (AWG 14) 0.5 Nm Housings (see 'Han Industrial Connectors' Catalogue) Material Surface Aluminium die cast Powder plated RAL 7037 Steel, zinc plated NBR - 40° ... + 125°C Locking element Sealing Ambient temperature Degree of protection acc. to DIN 40 050 in locked position IP 65 2001-04-04 HARTING KGaA • Marienwerderstraße 3 • D-32339 Espelkamp Internet: http://www.HARTING.com or P.O.Box 11 33 • D-32325 Espelkamp E-mail: de.han@HARTING.com Phone: (+49) 5772/47-0 • Fax: (+49) 5772/47-495
09 33 006 2702 价格&库存
很抱歉,暂时无法提供与“09 33 006 2702”相匹配的价格&库存,您可以联系我们找货
