09030006262
09030006262
    HARTING(浩亭)
    插件
    板对板连接器 插件
09030006262 数据手册
DIN 41 612 · Special contacts type M Application matrix   Coax Contacts Board to Backplane Mezzanine l High Voltage Contacts FOC- Contacts l l 1. M male & M female DIN Signal up to 2 A Connector M male & M flat female 3. 4. MH 21+ 5 male M invers & MH 21+ 5 male female & M female 5. M invers male & M flat female Part number Male connector type M angled 09 03 1XX X901 Female connector type M straight 09 03 2XX 6804 Female connector type M straight 09 03 2XX 6805 Female connector type M straight 09 03 2XX 6850 Female connector type M flat 09 03 2XX 6864 Female connector type M flat 09 03 2XX 6865 Female connector type M flat 09 03 2XX 6830 Male connector type MH 21+5 09 06 X21 6883 Female connector type MH 21+5 09 06 121 6981 Male connector type M invers 09 73 1XX 6902 Male connector type M invers 09 73 1XX 6903 Male connector type M invers 09 73 1XX 6904 Male connector type M invers 09 73 1XX 6907 Male connector type M invers 09 73 1XX 6974 Male connector type M invers 09 73 1XX 6991 Impedance Termination Part number 50 Ω cable solder/crimp 09 03 000 6160 50 Ω cable solder/crimp 09 03 000 6161 50 Ω pcb solder 09 03 000 6165 75 Ω cable solder/crimp 09 03 000 6181 50 Ω pcb solder 09 03 000 6182 50 Ω cable solder/crimp 09 03 000 6260 50 Ω cable solder/crimp 09 03 000 6261 50 Ω pcb solder 09 03 000 6262 50 Ω pcb solder 09 03 000 6263 50 Ω pcb solder 09 03 000 6265 75 Ω pcb solder 09 03 000 6269 50 Ω cable solder/crimp 09 03 000 6274 75 Ω cable solder/crimp 09 03 000 6281 High voltage 1.5 KV FOC ceramic ferrule* FOC for SI-fibre (HCS)* 01 . 36 2. FOC for 1 mm (POF)* 09 03 000 6140 09 03 000 6240 20 10 125 4212 20 10 125 4222 20 10 230 4211 20 10 230 4221 20 10 001 4211 20 10 001 4221 l = can be used in male connector = male connector for l contacts * details see catalogue Industrial Connectors Han® u u u u l l l l l l l l u l u l u l u u l l l l l u u u l l l l l l l l u l u l u l u u = can be used in female connector = female connector for u contacts u u u u l l l l l l l u l u l u l u u l l l l
09030006262 价格&库存
很抱歉,暂时无法提供与“09030006262”相匹配的价格&库存,您可以联系我们找货
    • 30+59.44400
    • 60+59.25700
    • 90+59.20200
    • 180+59.13600
    库存:5000
