Han® EEE
Features
Technical characteristics
• 40 / 64 contacts with crimp termination
Specifications
• Up to 64 Han E® contacts in hoods/housings type
Han® 24 B
Inserts
• Polarised insert
• Contacts available with either hard silver plated or
hard gold plated surface
• Suitable for hoods/housings of series Han® B,
Han® EMV, Han® HPR, Han® M
DIN EN 60 664-1
DIN EN 61 984
Number of contacts
Electrical data acc. to
DIN EN 61 984
Rated current
Rated voltage
Rated impulse voltage
Pollution degree
Insulation resistance
Material
Limiting temperatures
Flammability acc. to UL 94
40, 64 + PE
Mechanical working life
≥ 500 mating cycles
16 A 500 V 6 kV 3
16 A
500 V
3 kV
3
≥ 1010 Ω
Polycarbonate
-40 °C ... +125 °C
V0
Contacts
Material
Copper alloy
Surface
- hard silver plated
- hard gold plated
3 µm Ag
2 µm Au over 3 µm Ni
Contact resistance
≤ 1 mΩ
Crimp termination
- mm²
- AWG
0.14 – 4.0 mm²
26 – 12
Current Carrying Capacity
Contact arrangement
The current carrying capacity of the connectors is limited by the
thermal load capability of the contact element material including
the connections and the insulating parts. The derating curve
is therefore valid for currents which flow constantly (non-intermittent) through each contact element of the connector evenly,
without exceeding the allowed maximum temperature.
Measuring and testing techniques according to DIN EN 60 512-5.
View from termination side
Han® 40 EEE
Working current [A]
Wire gauge: 2.5 mm²
Han® 64 EEE
Ambient temperature [°C]
Han® EEE
Number of contacts
40 / 64 +
Inserts
Identification
9
00 09
2
y
Ma rch 2
y
a
b
ble by M
a
l
le
ai
Av ailab
E
EE E: Av
® 4
E
n ® 64 E
a
H n
Ha
Contact
No.
Part Number
Male insert
Female insert
Dimensions in mm
Crimp termination
order crimp contacts
separately
40
64
Identification
Crimp contacts
silver plated
gold plated
09 32 040 3001
09 32 064 3001
09 32 040 3101
1)
Distance for
contact max.
21 mm
1)
Distance for
contact max.
21 mm
09 32 064 3101
Wire gauge
Part Number
mm²
Male contacts
Female contacts
0.14-0.37
0.5
0.75
1
1.5
2.5
3
4
09 33 000 6127
09 33 000 6121
09 33 000 6114
09 33 000 6105
09 33 000 6104
09 33 000 6102
09 33 000 6106
09 33 000 6107
09 33 000 6227
09 33 000 6220
09 33 000 6214
09 33 000 6205
09 33 000 6204
09 33 000 6202
09 33 000 6206
09 33 000 6207
0.14-0.37
0.5
0.75
1
1.5
2.5
4
09 33 000 6117
09 33 000 6122
09 33 000 6115
09 33 000 6118
09 33 000 6116
09 33 000 6123
09 33 000 6119
09 33 000 6217
09 33 000 6222
09 33 000 6215
09 33 000 6218
09 33 000 6216
09 33 000 6223
09 33 000 6221
Dimensions in mm
Operating contact
Identification
Identification
Wire gauge
no groove 0.14-0.37 mm² AWG 26-22
no groove
0.5 mm² AWG 20
1 groove*
0.75 mm² AWG 18
1 groove
1 mm² AWG 18
2 grooves
1.5 mm² AWG 16
3 grooves
2.5 mm² AWG 14
wide groove
3 mm² AWG 12
no groove
4 mm² AWG 12
* on the back crimp collar
Stripping
length
7.5 mm
7.5 mm
7.5 mm
7.5 mm
7.5 mm
7.5 mm
7.5 mm
7.5 mm
很抱歉,暂时无法提供与“09330006206”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4.124641+0.53246
- 50+3.5591750+0.45946
- 100+3.04359100+0.39290
- 300+2.70264300+0.34889
- 500+2.62780500+0.33923
- 1000+2.577901000+0.33279
- 4000+2.536324000+0.32742
- 国内价格
- 100+1.86300
- 200+1.80090
- 300+1.74183
- 400+1.72973
- 500+1.71764
- 国内价格
- 100+1.65000
- 200+1.59500
- 300+1.58400
- 400+1.57300
- 国内价格
- 100+3.65110
- 200+3.55945
- 400+3.50426
- 国内价格 香港价格
- 1+6.620631+0.85467
- 10+5.6254010+0.72620
- 25+5.2738725+0.68082
- 50+5.0231450+0.64845
- 100+4.78288100+0.61743
- 300+4.42554300+0.57130
- 500+4.26877500+0.55107
- 1000+4.064941000+0.52475
- 2500+3.810362500+0.49189
