09340062701
09340062701
    HARTING(浩亭)
    INSERT FEMALE 6+2POS+1GND SCREW
09340062701 数据手册
Han® 6 Hv E/ES Size 16 B 830 V 16 A Number of contacts 6 + + 2 additional contacts for safe high voltage connections Han Hv E Identification Series Cage-clamp terminal Han® Hv ES 1-6 Part number Male insert (M) Female insert (F) 09 34 006 2616 "https://b2b.harting.com/ebusiness/en/ " "https://b2b.harting.com/ebusiness/en/ 09 34 006 2716 Cage clamp terminal Screw terminal Crimp terminal 1) Han Hv E® 1-6 Crimp terminal Order crimp contacts separately (see page 04.16) 04 . 06 a 18,4 18,5 18,5 b 33,4 32,4 34,2 c 18,4 18 18 d 35,6 34,6 37 Distance for contact max. 21 mm Contact arrangement (view from termination side) Han® 6 Hv ES 09 34 006 2601 "https://b2b.harting.com/ebusiness/en/ " "https://b2b.harting.com/ebusiness/en/ 09 34 006 2701 " Han® 6 Hv E Han Hv E® 1-6 Dimensions in mm " not plug compatible to screw/crimp terminal Screw terminal Drawing 09 34 006 2602 "https://b2b.harting.com/ebusiness/en/ " "https://b2b.harting.com/ebusiness/en/ 09 34 006 2702 " ● Working contact ◐ Relay contact ○ Without contact Panel cut out for inserts for use without hoods/ housings Crimp terminal and cage clamp terminal could also be used with 16 B standard hood/housing Stock items in bold type
09340062701 价格&库存
很抱歉,暂时无法提供与“09340062701”相匹配的价格&库存,您可以联系我们找货
  • 1+303.509651+39.17710
  • 5+279.172865+36.03570
  • 10+261.0515710+33.69660
  • 25+239.0784225+30.86030
  • 50+230.3241750+29.73030
