IPL1-103-02-H-D-K-TR
    SAMTEC(申泰)
    .100 TERMINAL ASSEMBLY
IPL1-103-02-H-D-K-TR 数据手册
MAX 4.8 A (2.54 mm) .100" PITCH • DISCRETE WIRE TERMINAL IPL1 - 1 PINS PER ROW - 02, 03, 04, 05, 06, 08, 10, 12, - LEAD STYLE –01 - PLATING OPTION –L = Throughhole = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –02 = Surface Mount 15, 16, –S –RA =Right-angle (–01 lead style only) –SH s - TAIL OPTION = Single Row K - –K =Keyed Polarization –RE1 = Single Row Horizontal (–02 lead style only) –D p =Right-angle Elevated (–01 lead style only) (–K is a required callout) OPTION –TR = Tape & Reel (–02 lead style only) Comes with Polyimide Pick & Place Pad –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (-02 lead style only) Comes with Polyimide Pick & Place Pad = Double Row 20, 25 IPL1 - ROW OPTION m (Standard sizes) Cable Mates: MMSD, MMSS, MMSDT, MMSST SPECIFICATIONS Insulator Material: Natural LCP Terminal Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C Voltage Rating: 675 VAC/954 VDC (8.76) .345 (8.76) .345 (8.76) .345 PROCESSING Lead–Free Solderable: Yes –S & –D (–02 Lead Style) SMT Lead Coplanarity: (0.10 mm) .004" max (02-05) (0.13 mm) .005" max (06-10)* (0.15 mm) .006" max (11-25)* *(.004" stencil solution may be available; contact IPG@samtec.com) –SH SMT Lead Coplanarity: (0.15 mm) .006" max (02-25)* *(.004" stencil solution may be available; contact ipg@samtec.com) (7.04) .277 (7.04) –02–S .277 (8.76) .345 (8.76) .345 (9.58) .377 (9.58) .377 WIRE GUAGE CURRENT RATING (PER PIN) 20 4.8 A 22 4.3 A 24 3.9 A 26 3.5 A 28 2.6 A 30 2.1 A 2 PINS POWERED (6.10) .240 (5.08) .200 (6.86) .270 (6.86) .270 (6.35) .250 (6.86) .270 (6.35) .250 (6.35) .250 (8.76) .345 –02–D –01–D (5.59) .220 (5.59) .220 ALSO AVAILABLE MOQ Required Note: Some lengths, styles and options are non-standard, non-returnable. MMSD/IPL1 (7.04) (9.58) .277 .377 (5.59) .220 Other sizes With or without plug polarization Guide post holes Other platings Weld tab –01, –02 & –RA = No. of positions x (2.54) .100 + (1.52) .060 –01, –02 & –RA = –SH –RE1 = x No. of &positions No..100 of positions (2.54) + (1.52) x.060 (2.54) .100 + (4.06) .160 –SH–02 & –RE1 –01, & –RA= = No. No. of of positions positions xx (2.54) (2.54) .100 .100 ++ (4.06) (1.52) .160 .060 (6.10) (5.08) –SH & –RE1 = .240 .200 No. of positions x (2.54) .100 + (4.06) .160 (6.10) (5.08) .240 .200 –02–SH (7.62) .300 (8.13) .320 (7.62) .300 (8.13) .320 (7.62) .300 (8.13) .320 –02 –01 –RA –01–S –01–S–RE1 (8.26) .325 (8.26) .325 (8.26) .325 –01–S-RA –01–D–RA –01–D–RE1 View complete specifications at: samtec.com?IPL1 samtec.com/minimate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
IPL1-103-02-H-D-K-TR 价格&库存
很抱歉,暂时无法提供与“IPL1-103-02-H-D-K-TR”相匹配的价格&库存,您可以联系我们找货
