LST-118-07-S-D
LST-118-07-S-D
    SAMTEC(申泰)
LST-118-07-S-D 数据手册
F-224 SUPPLEMENT LST–112–07–G–D LST–120–07–G–D (2.54 mm) .100" LST SERIES SELF-MATING HERMAPHRODITIC STRIP SPECIFICATIONS For complete specifications see www.samtec.com?LST Hermaphroditic self-mating combination header/socket system Mates with: LST Insulator Material: Black Glass Filled Polyester Terminal Material: Phosphor Bronze Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Insertion Depth: (3.68 mm) .145" to (6.35 mm) .250" Cycles: 100 with 10 µ" (0.25 µm) Au RoHS Compliant: Yes Lead–Free Solderable: Wave Only APPLICATION Polarized (13.59) .535 MATED HEIGHT One part number for both socket and terminal (2.54 mm) .100" pitch Locking feature increases unmating force and provides audible “click” when properly mated (0.64 mm) .025" square post RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality TYPE STRIP 1 NO. PINS PER ROW PLATING OPTION 07 D FILE NO. E111594 LST 02 thru 30 = Standard –F = Gold flash on contact area, Matte Tin on tail –G = 10 µ" (0.25 µm) Gold on contact area, Gold flash on balance No. of Positions x (2.54) .100 + (0.51) .020 (2.54) .100 –T 02 = Matte Tin (2.54) .100 Note: Other Gold plating options available. Contact Samtec. (0.64) .025 SQ 01 (8.51) .335 (6.10) .240 (2.29) .090 (11.05) .435 (2.54) .100 (5.08) .200 (5.84) .230 Note: Some lengths, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
LST-118-07-S-D 价格&库存
很抱歉,暂时无法提供与“LST-118-07-S-D”相匹配的价格&库存,您可以联系我们找货
