MB1-150-01-L-S-01-SL 数据手册
F-215
MB1–120–01–L–S–02–SL
MB1–130–01–F–S–01–SL–N
(1,00 mm) .0394"
MB1 SERIES
MINI EDGE CARD SOCKET WITH GUIDES
Mates with:
(0,80 mm) .031" PCB,
(1,60 mm) .062" PCB
1
MB1
NO. OF
PINS
01
PLATING
OPTION
S
CARD
SLOT
OTHER
OPTION
SL
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?MB1
Insulator Material: Black LCP
Contact Material: BeCu
Plating: Sn or Au over
50µ" (1,27 µm) Ni
Current Rating:
2.2 A per pin
(6 pins powered)
Operating Temp Range:
-55°C to +125°C
Insertion Depth:
(5,26 mm) .207" to
(6,10 mm) .240"
RoHS Compliant: Yes
= Gold flash on contact,
Matte Tin on tail
(No. of Positions + 2)
x (1,00) .03937 + (4,06) .160
–L
(3,81)
.150
= 10µ" (0,25 µm)
Gold on contact,
Matte Tin on tail
CARD
SLOT
–01
–02
Processing:
Lead–Free Solderable: Yes
SMT Lead Coplanarity:
(0,10 mm) .004" max (20-30)
(0,15 mm) .006" max (40-50)
–F
20, 30, 40, 50
Specify
CARD
SLOT
from
chart
MATES WITH
BOARD THICKNESS
(0,97)
(0,80)
.038
.031
(1,83)
(1,60)
.072
.062
A
(25,5)
1.004
(7,24)
.285
(7,24)
.285
–N OPTION
RECOGNITIONS
01
(1,00)
.03937
For complete scope
of recognitions see
www.samtec.com/quality
50
(0,36)
.014
(1,27)
.050
(1,27)
.050
x (1,00) .03937
Note: Patented
–N
= No Card
Guides
(1,52)
.060
Important Note: Samtec
recommends that pads on the
mating board be Gold plated.
Note: Some sizes, styles and
options are non-standard,
non-returnable.
A
(5,44)
.214
(0,15)
.006
ALSO AVAILABLE
(MOQ Required)
(0,69)
.027
(1,27)
.050
DIA
(2,36)
.093
• Other platings
Contact Samtec.
OTHER SOLUTIONS
Flex Card System
.050" (1,27 mm) (FCF/EMF Series) systems
Vertical and horizontal
Header with snap-on card guides for design flexibility
exibility
Elevated design now available
PCMCIA (PCMT/PCMS Series) Compact Flash
h
(CFT/CFS Series) compatible applications available
ilable
• Ideal for multiple add-on cards
• Solder locks for mechanical stability
• Any size from 40 to 100 contacts
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
MB1-150-01-L-S-01-SL 价格&库存
很抱歉,暂时无法提供与“MB1-150-01-L-S-01-SL”相匹配的价格&库存,您可以联系我们找货
