Product data sheet
15 65 012 2701 000
har-flex ang. power F 12P THR PL1 400pcs
Part number
15 65 012 2701 000
Specification
400pcs
HARTING eCatalogue
https://b2b.harting.com/15650122701000
Image is for illustration purposes only. Please refer to product description.
Identification
Category
Connectors
Series
har-flex®
Identification
Power
Element
Female connector
Description of the contact
Angled
Features
Termination method of hold downs: SMT
Version
Termination method
Reflow soldering termination (THR)
Connection type
Motherboard to daughtercard
Extender card
Number of contacts
12
Performance level
1
Details
According to IEC 61984, it is an unencapsulated connector. Protection against
electric shock must be ensured by the type of installation by the user.
Pack contents
400 pieces on reel
Technical characteristics
Contact spacing (mating side)
2.54 mm
Rated voltage
180 V
Rated voltage
acc. to IEC 60664-1
Rated impulse voltage
1.5 kV
Pollution degree
2
Clearance distance
≥0.94 mm
Page 1 / 3 | Creation date 2020-10-20 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to
the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality,
conformity with applicable laws and directives, as well as for the electrical safety in the particular application.
HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany
Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com
Product data sheet
15 65 012 2701 000
Creepage distance
≥0.94 mm PCB
≥1.89 mm Connector
Insulation resistance
>1010 Ω
Contact resistance
≤25 mΩ
Limiting temperature
-55 ... +125 °C
Mating cycles
≥500
Test voltage Ur.m.s.
0.84 kV
Isolation group
IIIa (175 ≤ CTI < 400)
Moisture Sensitivity Level (MSL)
1 acc. to ECA/IPC/JEDEC J-STD-020D
Process Sensitivity Level (PSL)
R0 acc. to ECA/IPC/JEDEC J-STD-020D
Coplanarity of contacts
0.1 mm
Material properties
Material (insert)
Liquid crystal polymer (LCP)
Colour (insert)
Black
Material (contacts)
Copper alloy
Surface (contacts)
Au over Pd/Ni Mating side
Tin plated Termination side
Material flammability class acc. to UL 94
V-0
Commercial data
Packaging size
1
Country of origin
China
European customs tariff number
85366990
eCl@ss
27460201 PCB connector (board connector)
Page 2 / 3 | Creation date 2020-10-20 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to
Product data sheet
15 65 012 2701 000
Current carrying capacity
Operating current (A)
The current carrying capacity of the connectors is
limited by the thermal load capability of the contact
element material including the connections and the
insulating parts. The derating curve is therefore
valid for currents which flow constantly (nonintermittent) through each contact element of the
connector evenly, without exceeding the allowed
maximum temperature.
Measuring and testing techniques acc. to IEC
60512-5-2
Ambient temperature (°C)
Derating curve 80%
Page 3 / 3 | Creation date 2020-10-20 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the
很抱歉,暂时无法提供与“15650122701000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 400+67.97542400+8.79444
- 800+64.73454800+8.37514
- 1200+62.911341200+8.13926
- 国内价格 香港价格
- 1+103.797431+13.42897
- 10+88.1856610+11.40917
- 100+74.95562100+9.69751
- 国内价格
- 1+30499.52151
- 3+26911.35590
- 国内价格 香港价格
- 1+32843.244091+4249.15030
- 3+28979.327883+3749.24960
