MPCC-2-16-2-L-44-25.00-S
    SAMTEC(申泰)
MPCC-2-16-2-L-44-25.00-S 数据手册
30 SIGNAL/POWER COMBO CABLE ASSEMBLY/COMPONENTS MPCC -2- SIGNAL PINS -2- –16 - PLATING OPTION –L = Total Signal Pins = 10 µ" (0.25 µm) Gold on contact, Tin on tail (Power & Signal) –24 = Total Signal Pins –T LEAD STYLE Specify LEAD STYLE from chart - - LENGTH –“XX.XX” = Assembled Length in Inches (101.60 mm) 04.00" min. = Tin on contact and tail (Power), Gold on contact, Tin on tail (Signal) MPCC Board Mates: MPTC (10.16) .400 SPECIFICATIONS END 1 OPTION END 2 OPTION –S (Available with –D only) –D = Notch up, straight (Pin A1 to Pin AX) = Single End = Double End Assembled Length Insulator Material: Black LCP Contact Material: Signal: BeCu Power: Copper Alloy Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating: Signal Pin (24 AWG): 3.4 A per pin (4 adjacent pins powered) Power Pin (14 AWG): 23.2 A per pin (1 pin powered) Operating Temp Range: -10 °C to +105 °C Voltage Rating: 250 VAC - –NUS SIGNAL PINS A 16 (44.55) 1.754 24 (48.55) 1.911 LEAD STYLE PWR/SIG –44 –46 A –48 –40 –64 –66 –68 –60 View complete specifications at: samtec.com?MPCC IMSC5 - - POWER PINS –02 = Power Pins Per End SIGNAL PINS - –16 - POWER PINS –02 = Total Signal Pins = Power Pins Per End L SERIES –L = Latch CC81L = Contact, Loose CC81R –24 = Contact, Full Reel (17,000 Parts per Reel) = Total Signal Pins - WIRE GAUGE - 01 - –2426 = 24 to 26 AWG –2830 PWR SIG PWR SIG PWR SIG PWR SIG PWR SIG PWR SIG PWR SIG PWR SIG AWG 14 24 14 26 14 28 14 30 16 24 16 26 16 28 16 30 PLATING OPTION –L = 10 µ" (0.25 µm) Gold on contact = 28 to 30 AWG A (18.60) .732 (12.35) .486 (21.07) .830 SIGNAL PINS A –16 (44.55) 1.754 –24 (48.55) 1.911 Note: Power contact (CC46 Series) information on page 246. TOOLING Hand Tool: CAT-HT-281-2430-13 (Signal: 24-30 AWG) CAT-HT-246-1416-13 (Power: 14-16 AWG) Extraction Tool: CAT-EX-169-01 (Signal) CAT-EX-MPSS-01 (Power) Mini Applicator: CAT-MC-246-1416-XX-01 (Power 14-16 AWG) CAT-MC-281-2426-XX-01 (Signal: 24-26 AWG) CAT-MC-281-2830-XX-01 (Signal: 28-30 AWG) Note: Some lengths, styles and options are non-standard, non-returnable View complete specifications at: samtec.com?IMSC5, samtec.com?CC81R & samtec.com?CC81L samtec.com/PowerStrip Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
MPCC-2-16-2-L-44-25.00-S 价格&库存
很抱歉,暂时无法提供与“MPCC-2-16-2-L-44-25.00-S”相匹配的价格&库存,您可以联系我们找货
