19443100305
19443100305
    HARTING(浩亭)
19443100305 数据手册
98 42 921 0201 HARTING Han-INOX Stainless Steel Hoods and Housings Han-INOX Features • Stainless steel hoods and housings • Stainless steel locking elements • Resistant against aggressive detergents • Fields of application - Food and beverage industry - Water and sewage industry - Pharmaceutical industry - Chemical industry - Offshore and shipbuilding Technical characteristics Material Sealing Limiting temperatures Protection degree in locked position Locking lever stainless steel NBR -40 °C ... +125 °C IP 65 stainless steel General Informatoin Fields of application HARTING Industrial Connectors are applicable in a wide variety of electronic and electrical ­applications. The degree of protection of all hoods and housings is in accordance with International Standard IEC 60 529. Power Utilities Robotics ● Chemical Plants ● Machine Tool Controls ● Injection Moulding ● ● Industrial Instrumentation ● Conveyor Equipment ● Transportation ● and many more. ● Certified according to EN ISO 9001 in design/development, production, ­installation and servicing Specifications VDE 0110 table concerning ­clearance and ­creepage distances VDE 0627 Connectors and plug ­devices Standards: DIN EN 175 301 - 801 DIN EN 61 984 Approvals UL, CSA for inserts Note Connectors should not be coupled and decoupled under electrical load. ­Connectors of the same or different series being mounted side by side may be ­protected against incorrect mating by the use of coding options. General information It is the user’s responsibility to check whether the components illustrated in this catalogue comply with different regulations from those stated in special fields of application which we are unable to foresee. We reserve the right to modify designs in ­ order to improve quality, keep pace with technological advancement or meet particular ­requirements in production. No part of this catalogue may be reproduced in any form (print, photocopy, microfilm or any other process) or processed, duplicated or distributed by means of electronic systems without the prior written consent of HARTING Electric GmbH & Co. KG, Espelkamp. We are bound by the German version only. © HARTING Electric GmbH & Co. KG, Espelkamp – All rights reserved, including those of the translation. Page  Han-INOX Size 10 B Identification Hood side entry Hood top entry Bulkhead mounted housing with 1 metal locking lever Part-Number M 19 44 310 0547 32 19 44 310 0447 32 19 44 310 0305 _ Drawing Dimensions in mm Panel cut out Gasket _ as spare part 19 44 000 9902 Han-Modular® frames size 10 B marking A..C 09 14 010 0303 marking a..c 09 14 010 0313 _ inserts see page 5 Page  Inserts size 10 B Series Han E® Han E® Han® ES Number of contacts 10 + 10 + 10 + Termination Screw terminal with wire protection Crimp terminal Cage clamp terminal 16 A / 500 V 16 A / 500 V 16 A / 500 V Electrical data accd. to DIN EN 61 984 UL/CSA 600 V Current / voltage Wire gauge 1 - 2.5 mm² 0.5 - 4 mm² 0.14 - 2.5 mm² Male insert (M) 09 33 010 2601 09 33 010 2602 09 33 010 2616 Female insert (F) 09 33 010 2701 09 33 010 2702 09 33 010 2716 Han® EE Han DD® Series Number of contacts Termination Han® ESS 10 + 18 + Cage clamp terminal 42 + Crimp terminal Crimp terminal Electrical data accd. to DIN EN 61 984 UL/CSA 600 V Current / voltage 16 A / 500 V 16 A / 500 V 10 A / 250 V Wire gauge 0.14 - 2.5 mm² 0.14 - 4 mm² 0.14 - 2.5 mm² Male insert (M) 09 33 010 2672 09 32 018 3001 09 16 042 3001 Female insert (F) 09 33 010 2772 09 32 018 3101 09 16 042 3101 Series Number of contacts Termination Han-Com® Han® HvES 8/24 + 3+ Crimp terminal +2 add. contacts for safe high voltage conn. Cage clamp terminal Han Hv E® 3+ +2 add. contacts for safe high voltage conn. Crimp terminal Electrical data accd. to DIN EN 61 984 UL/CSA 600 V Relay contact 250 V Current 16 A / 10 A 16 A 16 A Voltage 230/400 V / 160 V 830 V 830 V 0.5-4 mm²/ 0.14 -2.5 mm² 0.14 -2.5 mm² 0.14 -4.0 mm² Male insert (M) 09 38 032 3001 09 34 003 2616 09 34 003 2602 Female insert (F) 09 38 032 3101 09 34 003 2716 09 34 003 2702 Wire gauge Page  Han-Modular® Modules Identification Number of contacts Han® Axial Screw Module Han® Axial Screw Module Han® Axial Screw Module Han® Axial Screw Module 1 2 2 3 Axial screw terminal Axial screw terminal Axial screw terminal Axial screw terminal 200 A / 1000 V 100 A / 1000 V 40 A / 1000 V 40 A / 690 V 40 - 70 mm² 16 - 35 mm² 2.5 - 8 mm² 6 - 10 mm² Male insert (M) 09 14 001 2662 09 14 002 2651 09 14 002 2601 09 14 003 2602 Female insert (F) 09 14 001 2762 09 14 002 2751 09 14 002 2701 09 14 003 2702 Han® CC Protected Mod. Han® E Module Han® EE Module Termination Electrical data accd. to DIN EN 61 984 Current / voltage Wire gauge Identification Number of contacts Han® C Module 3 4 6 8 Crimp terminal Crimp terminal Crimp terminal Crimp terminal 40 A / 400/690 V 40 A / 830 V 16 A / 500 V 16 A / 400 V 1.5 - 6 mm² 1.5 - 6 mm² 0.5 - 4 mm² 0.5 - 4 mm² Male insert (M) 09 14 003 3001 09 14 004 3041 09 14 006 3001 09 14 008 3001 Female insert (F) 09 14 003 3101 09 14 004 3141 09 14 006 3101 09 14 008 3101 Han® HV Module Han® ES Module Termination Electrical data accd. to DIN EN 61 984 Current / voltage Wire gauge Identification Number of contacts Han® E Protected Mod. Han® EEE Module 6 20 2 5 Axial screw terminal Axial screw terminal Axial screw terminal Cage clamp terminal Current / voltage 16 A / 830 V 16 A / 500 V 16 A / 2900/5000 V 16 A / 400 V Wire gauge 0.5 - 4 mm² 0.5 - 4 mm² 0.5 - 4 mm² 0.14 - 2.5 mm² Male insert (M) 09 14 006 3041 09 14 020 3001 09 14 002 3021 09 14 005 2616 Female insert (F) 09 14 006 3141 09 14 020 3101 09 14 002 3121 09 14 005 2716 Termination Electrical data accd. to DIN EN 61 984 Page  Han-Modular® Modules Identification Number of contacts Termination Han® DD Module Han® DDD Module Han® High Density Module Han® D-Sub Module 12 17 25 9 Crimp terminal Crimp terminal Crimp terminal Crimp terminal Electrical data accd. to DIN EN 61 984 Current / voltage 10 A / 250 V 10 A / 160 V 5 A / 50 V 5 A / 50 V Wire gauge 0.14 - 2.5 mm² 0.14 - 2.5 mm² 0.09 - 0.56 mm² 0.09 - 0.56 mm² Male insert (M) 09 14 012 3001 09 14 017 3001 09 14 025 3001 09 14 009 3001 Female insert (F) 09 14 012 3101 09 14 017 3101 09 14 025 3101 09 14 009 3101 Han® FireWire Module Han® USB Module Identification Han® Dummy Module Number of contacts Han-Quintax® Module 2 1 Electrical data accd. to DIN EN 61 984 Current / voltage 5/10 A / 50 V Wire gauge 1.5 - 6 mm² Male insert (M) 09 14 000 9950 09 14 002 3001 09 14 001 4611 09 14 001 4601 Female insert (F) 09 14 000 9950 09 14 002 3101 09 14 001 4711 09 14 001 4701 Identification Han® SC Module Number of contacts 4 Han® Multi Contact Module Han® Pneumatic Module Han® Pneumatic Module 4 2 3 Coaxial contacts F.O. contacts Tube internal Tube internal accd. to DIN EN 41 626 diameter 6 mm diameter 4 mm Male insert (M) 09 14 004 4701 09 14 004 4501 09 14 002 4501 09 14 003 4501 Female insert (F) 09 14 004 4711 09 14 004 4512 09 14 002 4501 09 14 003 4501 Page  Han-Modular® Accessories Han-Modular® Contacts Identification Male insert (M) SC contact Coaxial contact Pneumatic contact 6.0 Pneumatic contact 4.0 20 10 125 5211 09 14 000 6211 09 14 000 6174 09 14 000 6153 09 14 000 6111 09 14 000 6274 09 14 000 6253 09 14 000 6279 09 14 000 6258 Female insert (F) With shut off valve Han-Quintax® Contacts Number of contacts Identification 4 1 Han-Quintax contact 8 Han D Coax contact ® Han High Density Quintax contact ® ® Order crimp contacts separately Wire gauge 0.14 - 2.5 mm² 0.14 - 2.5 mm² 0.13 - 0.52 mm² Male insert (M) 09 15 004 3013 09 15 001 3013 09 15 008 3013 Female insert (F) 09 15 004 3113 09 15 001 3113 09 15 008 3113 Crimp Contacts Han E® contacts (16 A) for Han E®, Han EE®, Han® Q, Han-Modular®, Han-Com®, Han-Brid®, Han Hv E® Part-Number Male contact Female contact 09 33 000 6121 09 33 000 6220 09 33 000 6114 09 33 000 6214 no groove 1 groove* 09 33 000 6105 09 33 000 6104 09 33 000 6102 09 33 000 6107 1 groove 2 grooves 3 grooves no groove 09 33 000 6205 09 33 000 6204 09 33 000 6202 09 33 000 6207 Identification Wire gauge mm² AWG 0.5 20 0.75 18 1 1.5 2.5 4 18 16 14 12 * on the back crimp collar Han D® contacts (10 A) for Han D®, Han DD®, Han-Modular®, Han-Com® Han C® contacts (40 A) for Han-Modular® Part-Number Male contact Female contact 09 15 000 6104 09 15 000 6204 09 15 000 6103 09 15 000 6203 ø mm 09 15 000 6105 09 15 000 6102 09 15 000 6101 09 15 000 6106 09 15 000 6205 09 15 000 6202 09 15 000 6201 09 15 000 6206 1.3 1.45 1.75 2.25 0.75 1 1.5 2.5 Part-Number Male contact Female contact 09 32 000 6104 09 32 000 6204 09 32 000 6105 09 32 000 6205 ø mm 1.75 2.25 Wire gauge mm² AWG 1.5 16 2.5 14 09 32 000 6107 09 32 000 6108 2.85 3.5 09 32 000 6207 09 32 000 6208 0.8 1.1 Page  Wire gauge mm² AWG 0.14-0.37 26 - 22 0.5 20 4 6 18 18 16 14 12 10 Identification Han-INOX Identification Size 3 A Part-Number M Drawing Dimensions in mm Hood top entry 19 44 003 1440 M20 with glued sealing 19 44 003 1443 M20 19 44 003 0301 _ Bulkhead mounted housing with 1 metal locking lever Panel cut out 22 x 22 mm Page  Inserts size 3 A Series Number of contacts Identification Han-Brid® RJ45 C Han-Brid® RJ45 C 2/4 + HARTING RJ Industrial Han-Brid® RJ45 C 2/8 + 2/8 + RJ45 ® RJ45 Electrical data accd. to DIN EN 61 984 Han D® contacts Current / voltage Han D® 10 A / 50 V 10 A / 50 V 10 A / 50 V Wire gauge 0.14 - 2.5 mm² 0.14 - 2.5 mm² 0.14 - 2.5 mm² Male insert (M) 09 12 003 3011 09 12 003 3021 09 12 003 3031 Han-Brid® RJ45 C Han-Brid® RJ45 C Han-Brid® RJ45 C Female insert (F) Series Number of contacts Identification 2/8 2/8 2/4 Panel feed through, straight Panel feed through, angled Latching part / panel feed through 4-wires Electrical data accd. to DIN EN 61 984 Han D® contacts Current / voltage Han D® 10 A / 50 V 10 A / 50 V 10 A / 50 V Wire gauge 0.14 - 2.5 mm² 0.14 - 2.5 mm² 0.14 - 2.5 mm² Male insert (M) 09 12 003 2774 09 12 003 2776 09 12 003 2770 Female insert (F) Series Number of contacts Identification Han-Brid® Cu Han-Brid® Cu Han-Brid® Cu Han-Brid® Cu 4/2 4/2 4/2 4/2 Cable side Device side Panel feed through with cage clamp terminal Latching part Panel feed through Electrical data accd. to DIN EN 61 984 Current / voltage Wire gauge 10 A / 25 V 10 A / 25 V 10 A / 25 V 10 A / 25 V 0.14 - 2.5 mm² 0.14 - 2.5 mm² 0.14 - 2.5 mm² 0.14 - 2.5 mm² Male insert (M) 09 12 006 3111 09 12 006 2611 09 12 006 2695 09 12 006 2694 Female insert (F) 09 12 006 3001 09 12 006 2701 09 12 006 2795 09 12 006 2794 Page  Inserts size 3 A Series Han® 8 D Number of contacts Termination 8 Han A® Han A® 3+ 4+ Crimp terminal Screw terminal Screw terminal 10 A / 50 V 10 A / 230/400 V 10 A / 230/400 V Electrical data accd. to DIN EN 61 984 UL/CSA 600 V Current / voltage Wire gauge 0.14 - 2.5 mm² 0.14 - 2.5 mm² 0.14 - 2.5 mm² Male insert (M) 09 36 008 3001 09 20 003 2611 09 20 004 2611 Female insert (F) 09 36 008 3101 09 20 003 2711 09 20 004 2711 Series Number of contacts Termination Han® Q Han® Q 5+ 7+ Crimp terminal Han® Q 2+ Crimp terminal Axial screw terminal Electrical data accd. to DIN EN 61 984 UL/CSA 600 V Current / voltage 16 A / 230/400 V 10 A / 400 V 40 A / 400 V Wire gauge 0.14 - 2.5 mm² 0.14 - 2.5 mm² 4 - 6 mm² Male insert (M) 09 12 005 3001 09 12 007 3001 09 12 002 2652 Female insert (F) 09 12 005 3101 09 12 007 3101 09 12 002 2752 Staf® 6 Staf® 6 Han® 3 A SC 4 Series Number of contacts 6 6 Solder terminal Screw terminal 10 A / ~25 V/-60 V 10 A / ~25 V/-60 V 2.5 mm² 1.5 mm² Male insert (M) 09 70 006 2812 09 70 006 2813 09 20 004 4711 Female insert (F) 09 70 006 2615 09 70 006 2616 09 20 004 4701 Termination Electrical data accd. to DIN EN 61 984 UL/CSA 50 V Current / voltage Wire gauge Page 10 Subsidiary companies – worldwide Austria HARTING Ges. m. b. H. Deutschstraße 3, A-1230 Wien Phone +43 1 / 6 16 21 21; Fax +43 1 / 6 16 21 21-21 E-Mail: at@HARTING.com Belgium HARTING N.V. / S.A. Z.3 Doornveld 23, B-1731 Zellik Phone +32 2 / 4 66 01 90; Fax +32 2 / 4 66 78 55 E-Mail: be@HARTING.com; Internet: www.HARTING.be Brazil HARTING Ltda. Av. Dr. Lino de Moraes, Pq. Jabaquara, 255 CEP 04360-001 - São Paulo - SP - Brazil Phone +55 11 / 50 35- 00 73; Fax +55 11 / 50 34 - 47 43 E-Mail: br@HARTING.com Internet: www.HARTING.com.br China Zhuhai HARTING; Limited Shanghai branch Room 5403, 300 Huaihai Zhong Road Hong Kong New World Tower Luwan District, P.R.C; Shanghai 200021, China Phone +86 21 - 63 86 22 00; Fax +86 21 - 63 86 86 36 E-Mail: cn@HARTING.com Czech Republic HARTING spol. s.r.o. Mlýnská 2, 160 00 Praha 6 Phone +420 220 380 460; Fax +420 220 380 461 E-Mail: cz@HARTING.com; Internet: www.HARTING.cz Finland HARTING Oy Teknobulevardi 3-5, PL 35, FI-01530 Vantaa Phone +358 9 350 87 300; Fax +358 9 350 87 320 E-Mail: fi@HARTING.com France HARTING France 181 avenue des Nations, Paris Nord 2 BP 66058 Tremblay en France F-95972 Roissy Charles de Gaulle Cédex Phone +33 1 49 38 34 00; Fax +33 1 48 63 23 06 E-Mail: fr@HARTING.com Germany HARTING Deutschland GmbH & Co. KG Postfach 2451 · D-32381 Minden Simeonscarré 1 · D-32427 Minden Phone (05 71) 88 96 - 0; Fax (05 71) 88 96 - 2 82 E-Mail: de@HARTING.com Internet: www.HARTING.com Office Germany HARTING Deutschland GmbH & Co. KG Blankenauer Straße 99; D-09113 Chemnitz Phone +49 0371 429211; Fax +49 0371 429222 E-Mail: de@HARTING.com Great Britain HARTING Ltd. Caswell Road; Brackmills Industrial Estate GB-Northampton, NN4 7PW Phone +44 16 04 / 76 66 86, 82 75 00 Fax +44 16 04 / 70 67 77, E-Mail: gb@HARTING.com Internet: www.HARTING.co.uk Hong Kong HARTING (HK) Limited, Regional Office Asia Pacific 4208 Metroplaza Tower 1; 223 Hing Fong Road Kwai Fong, N. T., Hong Kong Phone +8 52 / 24 23 - 73 38; Fax +8 52 / 24 80 - 43 78 E-Mail: ap@HARTING.com Internet: www.HARTING.com.hk Hungary HARTING Eastern Europe GmbH Magyarországi Kereskedelmi ­Képviselete 1119 Budapest; Fehérvári út 89-95, II. emelet 217/A. Phone +36-1-205 3464; Fax +36-1-205 3465 E-Mail: hu@HARTING.com; Internet: www.HARTING.hu Indien HARTING India Pvt. Ltd. D4, Doshi Towers; 156 Poonamallee High Rd. Kilpauk, Chennai - 600 010, INDA Tel. +91 44 43560415; Fax +91 44 4356 0417 pushpendra.singh@HARTING.com; www.HARTING.com Italy HARTING SpA Via Dell' Industria 7; I-20090 Vimodrone (Milano) Phone +39 02 / 25 08 01; Fax +39 02 / 2 65 05 97 E-Mail: it@HARTING.com Japan HARTING K. K. Yusen Shin-Yokohama 1 Chome Bldg., 2F 1-7-9, Shin-Yokohama; Kohoku-ku, Yokohama 222-0033 Japan Phone +81 45 476 3456; Fax: +81 45 476 3466 E-Mail: jp@HARTING.com Internet: www.HARTING.co.jp Korea HARTING Korea Limited #308 Leaders Bldg., 342-1, Yatap-dong, Bundang-gu, Sungnam-City, Kyunggi-do, 463-828, Korea Phone +82-31-781-4615; Fax +82-31-781-4616 E-Mail: kr@HARTING.com Representatives – worldwide Netherlands HARTING B.V. Larenweg 44; NL-5234 KA 's-Hertogenbosch Postbus 3526; NL-5203 DM 's-Hertogenbosch Phone +31 73 / 6 41 04 04 Fax +31 73 / 6 44 06 99 E-Mail: nl@HARTING.com Argentina Condelelctric S.A. Hipólito Yrigoyen 2591 (B1640HFY) Martínez, Buenos Aires Phone + Fax +54 11 4836-1053 E-Mail: info@condelelctric.com.ar Norway HARTING A/S, Østensjøveien 36, N-0667 Oslo, Phone +47 22 / 70 05 55 Fax +47 22 / 70 05 70 E-Mail: no@HARTING.com Bulgaria COMET ELECTRONICS 16, Tsar Samuil Str., BG-1000 Sofia Phone +359-2-9155800; Fax +359-2-9540384 E-Mail: office@comet.bg; Internet: www.comet.bg Poland HARTING Eastern Europe GmbH Przedstawicielstwo w Polsce ul. Kamieµskiego 201-219 51-126 Wroc³aw Phone +48 71-352 81 71 ; Fax +48 71-320 74 44 E-Mail: pl@HARTING.com; Internet : www.HARTING.pl Portugal HARTING Iberia, S. A. Avda. Josep Tarradellas, 20-30, 4º 6ª E-08029 Barcelona Phone +351.219.673.177; Fax +351.219.678.457 E-Mail: es@HARTING.com Russia HARTING ZAO ul. Tobolskaja 12, Saint Petersburg 194044 Russia Phone +7 / 8 12 / 3 27 64 77; Fax +7 / 8 12 / 3 27 64 78 E-Mail: ru@HARTING.com Internet: www.HARTING.ru Canada Chartwell Electronics Inc. 140 Duffield Drive; Markham; Ontario L6G 1B5 Phone +1 905-513-7100; Fax +1 905-513-7101 Toll Free +1 877-513-7769; www.chartwell.ca Denmark Knud Wexøe A/S Skaettekaeret 11, P.O. Box 152; DK-2840 Holte Phone +45 45 46 58 00; Fax +45 45 46 58 01 E-Mail: wexoe@wexoe.dk Internet: www.wexoe.dk Estland SKS-tehnika Ou Mustamäe tee 55, EE-10621 Tallinn Phone +372 6819 234; Fax +372 6819 235 E-Mail: peeter.kuus@sks.fi Finland SKS-automaatio OY Martinkyläntie 50, FIN-01721 Vantaa Phone +358 9 852 661; Fax +358 9 852 68 20 E-Mail: automaatio@sks.fi Singapore HARTING Singapore Pte Ltd. No. 1 Coleman Street; #B1-21 The Adelphi Singapore 179803 Phone +656 2 25 52 85; Fax +656 2 25 99 47 E-Mail: sg@HARTING.com Hungary Mile Kft. Mádi u. 52, H-1104 Budapest Phone +36-1-431-9800; Fax +36-1-431-9817 E-Mail: milekft@mile-kft.hu Internet: www.mile-kft.hu Spain HARTING Iberia S.A. Josep Tarradellas 20-30 4º 6ª; E-08029 Barcelona Phone +34 933 638 475; Fax +34 934 199 585 E-Mail: es@HARTING.com Island Smith & Norland Nóatún 4, IS - 105 Reykjavík Phone +354 520 3000; Fax +354 520 3011 E-Mail: olaf@sminor.is; Internet: www.sminor.is Sweden HARTING AB Gustavslundsvägen 141 B 4tr; 167 51 Bromma Phone +46 8 / 4 45 71 71; Fax +46 8 / 4 45 71 70 E-Mail: se@HARTING.com Switzerland HARTING AG Industriestrasse 26; CH-8604 Volketswil Phone +41 44 908 20 60; Fax +41 44 908 20 69 E-Mail: ch@HARTING.com Taiwan HARTING R.O.C. Limited Room 1, 5th Floor, No. 495, GuangFu South Road Taipei, 110 Taiwan Phone +8 86 - 2 - 2758- 61 77 Fax +8 86 - 2 - 2758- 7177 E-Mail: tw@HARTING.com USA HARTING Inc. of North America 1370 Bowes Road; Elgin, Illinois 60123 Phone +1 (877) 741-1500 (toll free) Fax +1 (866) 278-0307 (Inside Sales) Fax +1 (847) 717-9430 (Sales and Marketing) E-Mail: us@HARTING.com Internet: www.HARTING-USA.com Israel MIGVAN Technologies & Engineering Ltd. 13 Hashiloh St., P.O.Box 7022 IL - Petach Tikva 49170 Phone +972 3 9240784; Fax +972 3 9240787 E-Mail: info@mte.co.il; Internet: www.mte.co.il Poland Soyter Sp. z o. o. ul. Warszawska 3, 05-082 Warszawa - Stare Babice Phone +48 22 722 0 685; Fax +48 22 722 0 550 E-Mail: handlowy@soyter.com.pl Internet: www.soyter.com South-Africa HellermannTyton Pty Ltd., Private Bag X158 Rivonia 2128 34 Milky Way Avenue; Linbro Business Park 2065 Johannesburg, South Africa Phone +27 (0)11 879-66 00; Fax +27 (0)11 879-66 06 E-Mail: sales.jhb@hellermann.co.za Switzerland Distrelec AG Grabenstrasse 6, CH-8606 Nänikon Phone +41 1 944 99 11; Fax +41 1 944 99 88 E-Mail: info@distrelec.com Internet: www.distrelec.com Eastern-Europe HARTING Eastern Europe GmbH Bamberger Straße 7; D-01187 Dresden Phone +49 351 / 4361760 Fax +49 351 / 4361770 E-Mail: Eastern.Europe@HARTING.com Turkey Gökhan Elektrik San. Tic. Ltd. Sti. Perpa Elektrikçiler Is Merkezi A Blok Kat:7-8-9 No.694; TR - 80270 Okmeydani/Istanbul Phone +9 0 (212) 2 21 32 36 (pbx) Fax +9 0 (212) 2 21 32 40 E-Mail: gokhan@gokhanelektrik.com Internet: www.gokhanelektrik.com Other countries HARTING Electric GmbH & Co. KG P.O. Box 14 73, D-32328 Espelkamp Phone +49 57 72 / 47 - 97 100 Fax + 49 57 72 / 47 - 4 95 E-Mail: electric@HARTING.com Ukraine Incomtech Ltd. 4 Lermontovskaya St., UA-04050 Kiev Phone +380-44-213-3641; Fax +380-44-213-3814 E-Mail: eletech@incomtech.com.ua Internet: www.incomtech.com.ua Distributors – worldwide Global Business Unit Electric Farnell InOne www.farnellinone.com; in US: Newark InOne: www.newarkinone.com RS Components www.rs-components.com; in US: Allied Electronics: www.alliedelec.com HARTING Electric GmbH & Co. KG P.O. Box 14 73 D-32328 Espelkamp Phone +49 57 72 / 47-97 100 Fax +49 57 72 / 47- 4 95 E-Mail: HARTING.electric@HARTING.com Internet: www.HARTING.com People | Power | Partnership www.HARTING.com
19443100305 价格&库存
很抱歉,暂时无法提供与“19443100305”相匹配的价格&库存,您可以联系我们找货
  • 1+1455.841321+188.70476
  • 10+1237.6036810+160.41700
  • 25+1160.1984025+150.38380
  • 50+1104.9080650+143.21712
库存:10
19443100305
    • 1+1117.42555
    • 100+1095.07745
    • 500+1073.18757
    库存:4
