Printview: Fuse plug with pull-tab; for miniature metric fuse ¼" x 1¼"; with indicator lamp; 12 … 30 V; 7.4
mm wide - Item No.: 2006-931/1000-541
indicator lamp; 12 … 30 V; 7.4 mm wide
Fuse plug with pull-tab; for miniature metric fuse ¼" x 1¼"; with indicator lamp; 12 … 30 V; 7.4 mm wide
Marking
Business data
Supplier
WAGO
Item no.
2006-931/1000-541
GTIN / EAN
4045454820893
Content
1
Order amount
25
Customer item number
Notes
Safety information 1: Electrical ratings are given by the fuse and blown fuse indication.
Technical data
Miscellaneous
Color
gray
Rated voltage EN (1) [V]
800 [V]
Nominal current [A]
10 [A]
Marking level
Center marking
Weight [g]
6.842 [g]
Width
7.4 mm / 0.291 in
Safety information 2
Leakage current in case of blown fuse: LED 2mA
WAGO Kontakttechnik GmbH & Co. KG
1
Images & drawings
2
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
3
很抱歉,暂时无法提供与“2006-931/1000-541”相匹配的价格&库存,您可以联系我们找货
