M12 PCB adapter A-coded SMT
Mating face
A-coding
Mating face
acc. to IEC 61 076-2-101
Technical characteristics: M12 PCB adapter
Degree of protection IP67
(mated and locked)
Rated current 4/5 poles: max. 4 A
8 poles: max. 2 A
(dependant
on PCB layout)
Rated voltage 4 poles: 250 V
5 poles: 60 V
8 poles: 30 V
Identification
Part number
Mating cycles
≥ 100
Limiting temperature
-40 °C … +85 °C
Termination SMT
Contact material
Copper alloy
Contact plating
(mating side)
Au over Ni
Insulator material
LCP
Drawing
Dimensions in mm
M12 PCB adapter
Male, A-coding,
straight, unshielded
4 poles
5 poles
8 poles
21 03 311 1415
21 03 311 1515
21 03 311 1815
Tape on reel
4 poles
5 poles
8 poles
21 03 311 1416
21 03 311 1516
21 03 311 1816
95
Mating face
A-coding
Mating face
Identification
Part number
M12 PCB adapter
Male, A-coding,
straight, shielded
8 poles
21 03 321 1802
Tape on reel
8 poles
21 03 321 1803
Female socket
for front mounting
M14x1 H9
21 41 000 0012
Hexagonal nut
M14x1
21 41 000 0011
96
Drawing
Dimensions in mm
Mating face
A-coding
Mating face
(mated and locked)
8 poles: max. 2 A
(dependant
on PCB layout)
5 poles: 60 V
8 poles: 30 V
Identification
Part number
Mating cycles
≥ 100
-40 °C … +85 °C
Termination SMT
Contact material
Copper alloy
Contact plating
(mating side)
Au over Ni
Insulator material
LCP
Drawing
Dimensions in mm
M12 PCB adapter
Female, A-coding,
4 poles
5 poles
8 poles
21 03 311 2410
21 03 311 2510
21 03 311 2810
Tape on reel
4 poles
5 poles
8 poles
21 03 311 2411
21 03 311 2511
21 03 311 2811
97
Mating face
A-coding
Mating face
Identification
Part number
M12 PCB adapter
Female, A-coding,
straight, shielded
8 poles
21 03 321 2802
Tape on reel
8 poles
21 03 321 2803
Female socket
for front mounting
M14x1 H9
M14x1 H13
21 41 000 0010
21 41 000 0013
Hexagonal nut
M14x1
21 41 000 0011
98
Drawing
Dimensions in mm
M12 PCB adapter D-coded SMT
Mating face
D-coding
Mating face
(mated and locked)
Rated current max. 4 A
(dependant
on PCB layout)
-40 °C … +85 °C
Termination SMT
Contact material
Copper alloy
Rated voltage
250 V
Contact plating
(mating side)
Au over Ni
Mating cycles
≥ 100
Insulator material
LCP
Identification
Part number
Drawing
Dimensions in mm
M12 PCB adapter
Female, D-coding,
straight, shielded
4 poles
21 03 381 2404
Tape on reel
4 poles
21 03 381 2405
Female socket
for front mounting
M14x1 H9
M14x1 H13
21 41 000 0010
21 41 000 0013
Hexagonal nut
M14x1
21 41 000 0011
99
M12 PCB adapter X-coded SMT
Mating face
X-coding
Mating face
acc. to IEC 61 076-2-109
(mated and locked)
Rated current max. 0.5 A
(dependant
on PCB layout)
-40 °C … +85 °C
Termination SMT
Contact material
Copper alloy
Rated voltage
48 V
Contact plating
(mating side)
Au over Ni
Mating cycles
≥ 100
Insulator material
LCP
Identification
Part number
M12 PCB adapter
Female, X-coding,
straight, shielded
8 poles
21 03 381 2820
Tape on reel
8 poles
21 03 381 2821
Female socket
for front mounting
M14x1 H9
M14x1 H13
21 41 000 0010
21 41 000 0013
Hexagonal nut
M14x1
21 41 000 0011
100
Drawing
Dimensions in mm
很抱歉,暂时无法提供与“21033112510”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+83.6307325+10.73500
- 100+77.82060100+9.98920
- 250+70.86604250+9.09650
- 500+67.87294500+8.71230
