231-306/026-000
231-306/026-000
    WAGO(万可电子)
    P=5.08mm
    接线端子 间距:5.08mm 1x6P 自由悬挂
231-306/026-000 数据手册
Data sheet from 03.02.2009 Item no.: 231-306/026-000 Product description: FEMALE PLUG; 6 POLE; PIN SPACING 5.08 MM / 0.2 IN; WITH CODIG FINGERS; WITH INTEGRATED FIXING FLANGES; CAGE CLAMP®CONNECTION Packing unit 50 pieces Product group 3 (Multi Conn. System) Pin spacing from 5,08 mm Pin spacing from 0,2 in pole count 6 Cross section from [mm²] 0,08 mm² Cross section to [mm²] 2,5 mm² Cross section from [AWG] 28 AWG Cross section to [AWG] 12 AWG Connection method CAGE CLAMP®CONNECTION Measured voltage EN 250 V Measured shock voltage 4 kV Pollution degree 3 Current intensity EN 16 A Weight 10,98 g Color orange No. of connection Points 6 No. of potentials 6 Height 14,3 mm Height 0,563 in Width 31,98 mm Width 1,259 in Depth 26,45 mm 1 von 3 Data sheet from 03.02.2009 Depth 1,041 in Strip length from 8 mm Strip length to 9 mm Strip length 0,33 in 2 von 3 Data sheet from 03.02.2009 Item number Admission office Approval no. Voltage [V] Current [A] Cross section [ mm² ] 231-306/026-000 BV 11915/A0 400 16 2,5 231-306/026-000 CCA 5764 250 16 0,08-2,5 231-306/026-000 CSA 154112-1466354 300 15 22-12 231-306/026-000 DEMKO 88126 250 231-306/026-000 KEMA 2083746.02 250 16 0,08-2,5 231-306/026-000 KR HMB05880-EL003 250/400/600 12/16 2,5 231-306/026-000 NEMKO P94101840 250 231-306/026-000 UR E45171 600 15 12 231-306/026-000 UR E45172 300 15 22-12 Sorting criteria: admission office - approval number © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 3 von 3 2,5 2,5
231-306/026-000 价格&库存
很抱歉,暂时无法提供与“231-306/026-000”相匹配的价格&库存,您可以联系我们找货
