231-532/001-000/RN01-0000
    WAGO(万可电子)
231-532/001-000/RN01-0000 数据手册
WAGO - 231-532/001-000/RN01-0000. - Terminal Block Item no.: 231-532/001-000 Product description: Header right angle solder pin, 1x1mm / 0.039x0.039in 2 pole pin spacing 2.08mm / 0.2in mating direction parallel to PCB with closed end. Product group 3 (Multi Conn. System) Weight 0.848 g Color orange pole count 2 Height 8.4 mm Height 0.331 in Width 13.36 mm Width 0.526 in Depth 12 mm Depth 0.472 in Pin spacing from 5.08 mm Pin spacing from 0.2 in Pollution degree 2 Measured voltage EN 320 V Measured shock voltage 4 kV Current intensity EN 16 A Pollution degree 2 Measured voltage EN 630 V Measured shock voltage 4 kV Current intensity EN 16 A Material group I Contact material Electrolytic copper (Ecu) Contact surface tin-plated
231-532/001-000/RN01-0000 价格&库存
很抱歉,暂时无法提供与“231-532/001-000/RN01-0000”相匹配的价格&库存,您可以联系我们找货
