260-108
260-108
    WAGO(万可电子)
260-108 数据手册
Data sheet  |  Item number: 260-108 2-conductor terminal strip; 8-pole; without push-buttons; with fixing flanges; for screw or similar mounting types; Fixing hole 3.2 mm Ø; 1.5 mm²; CAGE CLAMP®; 1,50 mm²; gray www.wago.com/260-108 Color: Data Electrical data Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 400 V Rated surge voltage (III/3) 6 kV Rated current 18 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Connection data Connection technology CAGE CLAMP® Actuation type Operating tool Connectable conductor materials Copper Solid conductor 0.08 … 1.5 mm² / 28 … 16 AWG Fine-stranded conductor 0.08 … 1.5 mm² / 28 … 16 AWG Strip length 8 … 9 mm / 0.31 … 0.35 inch Pole No. 8 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 08.08.2020    Page 1/9 Data sheet  |  Item number: 260-108 www.wago.com/260-108 Pole No. 8 Total number of connection points 16 Total number of potentials 8 Number of levels 1 Wiring type Side-entry wiring Geometrical Data Width 54.5 mm / 2.146 inch Height from the surface 17 mm / 0.669 inch Depth 25 mm / 0.984 inch Module width 5 mm / 0.197 inch Mechanical data Design horizontal type Mounting type Mounting flange Marking level Side marking Material Data Color gray Fire load 0.283 MJ Weight 13.8 g Commercial data Packaging type BOX Country of origin DE GTIN 4044918598835 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60998 NTR-NL 6508 CCA EN 60998 2110272.01 DEKRA Certification B.V. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 08.08.2020    Page 2/9 Data sheet  |  Item number: 260-108 www.wago.com/260-108 DEKRA Certification B.V. CSA DEKRA Certification B.V. C22.2 70010891 VDE VDE Prüf- und Zertifizierungsinstitut EN 60998 40033303 Ship Approvals Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping - 19HG1869868PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001V2 LR Lloyds Register IEC 60998 91/20242 (E7) UL-Approvals Logo Approval Additional Approval Text Certificate name UR Underwriters Laboratories Inc. UL 1059 E45172 Counterpart Compatible products Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 08.08.2020    Page 3/9 Data sheet  |  Item number: 260-108 www.wago.com/260-108 assembling Item no.: 209-123 Mounting foot with screw; can be screwed on terminal blocks with fixing flange; 6.4 mm wide; gray www.wago.com/209-123 Item no.: 209-137 Mounting adapter; can be used as end stop; 6.5 mm wide; gray www.wago.com/209-137 Item no.: 210-136 Test plug; 2 mm Ø; with 500 mm cable; red www.wago.com/210-136 Item no.: 210-137 Test plug; 2.3 mm Ø; with 500 mm cable; yellow www.wago.com/210-137 Item no.: 249-135 Test plug module; without locking device; modular; for 2-conductor terminal blocks; gray www.wago.com/249-135 Item no.: 260-404 Test plug module; with locking latches; modular; for 2-conductor terminal blocks; for 260 Series; gray www.wago.com/260-404 Item no.: 260-402 Jumper; for conductor entry; 2-way; insulated; gray www.wago.com/260-402 Item no.: 216-101 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated www.wago.com/216-101 Item no.: 216-102 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated www.wago.com/216-102 Item no.: 216-103 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-103 Item no.: 216-104 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated www.wago.com/216-104 Item no.: 216-121 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated www.wago.com/216-121 Item no.: 216-122 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated www.wago.com/216-122 Item no.: 216-123 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-123 Item no.: 216-124 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated www.wago.com/216-124 check Jumper ferrule Item no.: 216-131 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/216-131 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 08.08.2020    Page 4/9 Data sheet  |  Item number: 260-108 www.wago.com/260-108 Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-131 Item no.: 216-132 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-132 Item no.: 216-151 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-151 Item no.: 216-152 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-152 Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-201 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-202 Item no.: 216-203 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-203 Item no.: 216-204 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-204 Item no.: 216-221 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-221 Item no.: 216-222 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-222 Item no.: 216-223 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-223 Item no.: 216-224 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-224 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-302 Item no.: 216-321 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-321 Item no.: 216-322 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-322 Item no.: 209-132 Operating tool; for connecting comb-style jumper bar; 2-way; of insulating material www.wago.com/209-132 Item no.: 210-657 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short www.wago.com/210-657 tools Item no.: 210-658 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 08.08.2020    Page 5/9 Data sheet  |  Item number: 260-108 www.wago.com/260-108 Item no.: 210-658 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short www.wago.com/210-658 Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft www.wago.com/210-720 Downloads Documentation Bid Text 260-108 Jun 14, 2017 doc 24.6 kB Download Feb 19, 2019 xml 3.2 kB Download Apr 3, 2019 pdf 2.1 MB Download URL Download EPLAN Data Portal 260-108 URL Download WSCAD Universe 260-108 URL Download ZUKEN Portal 260-108 URL Download doc - Datei 260-108 GAEB X81 - Datei Additional Information Technical explanations CAD/CAE-Data CAD data 2D/3D Models 260-108 CAE data Installation Notes Conductor termination Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 08.08.2020    Page 6/9 Data sheet  |  Item number: 260-108 www.wago.com/260-108 CAGE CLAMP® connection Inserting a conductor. With ferruled conductors, it is necessary to use a terminal block one size larger than the conductor’s nominal cross-section. Commoning Commoning with comb-style jumper bar. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 08.08.2020    Page 7/9 Data sheet  |  Item number: 260-108 www.wago.com/260-108 Testing via test plug modules snapped onto a terminal strip – wired or unwired. As touch contact is made with the CAGE CLAMP® (spring steel) unit, this testing type is limited to maximum 0.5 A. Testing after the conductors have been terminated. Distance between locking devices must be approximately 35 … 40 mm. Installation KMounting and securing a terminal strip directly to the plate via screw-type flanges. Terminal strip with mounting flanges – screwing a 209‑123 Mounting Foot Terminal strip with mounting flanges on DIN35 rail (distance between mounting feet: approx. 25 … 30 mm) Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 08.08.2020    Page 8/9 Data sheet  |  Item number: 260-108 www.wago.com/260-108 Terminal strip, with mounting flanges, for screw or similar mounting types, 3.2 mm mounting hole diameter (with 209‑123 Mounting Foot for DIN-35 rail) Marking Marking with self-adhesive marking strips. Marking by direct printing (upon request). Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 08.08.2020    Page 9/9
260-108 价格&库存
很抱歉,暂时无法提供与“260-108”相匹配的价格&库存,您可以联系我们找货
