Data sheet | Item number: 280-534
Double-deck terminal block; Through/through terminal block; with additional
jumper position on lower level; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²;
CAGE CLAMP®; 2,50 mm²; gray/blue
www.wago.com/280-534
Item description
Note:
Terminating Aluminum Conductors
WAGO spring clamp terminal blocks are suitable for solid aluminum conductors up to 4 mm²/12 AWG if WAGO “Alu-Plus” Contact Paste is used for
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
18.05.2021 Page 1/13
termination.
“Alu-Plus” Contact Paste Advantages:
Automatically destroys the oxide film during clamping.
Prevents fresh oxidation at the clamping point.
Prevents electrolytic corrosion between aluminum and copper conductors (in the same terminal block).
Provides long-term protection against corrosion.
Using terminal blocks with CAGE CLAMP® Spring Pressure Connection Technology, aluminum conductors must first be cleaned with a blade and
then immediately be inserted into the clamping units filled with “Alu-Plus” Contact Paste.
It is also possible to apply WAGO “Alu-Plus” additionally on the whole surface of the aluminum conductor before termination.
Please note that the nominal currents must be adapted to the reduced conductivity of the aluminum conductors::
2.5 mm² = 16 A
4 mm² = 22 A
Data
Electrical data
Ratings per IEC/EN
Ratings per
IEC/EN 60947-7-1
Nominal voltage (III/3)
500 V
Rated surge voltage (III/3)
6 kV
Rated current
20 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Connection data
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Connectable conductor materials
Copper
Aluminum
Solid conductor
0.08 … 2.5 mm² / 28 … 12 AWG
Fine-stranded conductor
Note (conductor cross-section)
12 AWG: THHN, THWN
Strip length
8 … 9 mm / 0.31 … 0.35 inch
Total number of connection points
4
Total number of potentials
2
Hansastr. 27
32423 Minden
18.05.2021 Page 2/13
2
Number of levels
2
Wiring type
Front-entry wiring
Physical data
Width
5 mm / 0.197 inch
Height
74 mm / 2.913 inch
Depth from upper edge of DIN-rail
58.5 mm / 2.303 inch
Mechanical data
Design
horizontal type
Mounting type
DIN-35 rail
Marking level
Center marking
Material data
Color
gray/blue
Insulation material
Polyamide (PA66)
Fire load
0.186 MJ
Weight
10.7 g
Commercial data
Product Group
1 (Rail Mounted Terminal Blocks)
Packaging type
BOX
Country of origin
DE
GTIN
4044918478991
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CCA
DEKRA Certification B.V.
EN 60947
2157201.01
CSA
C22.2
1536071
Hansastr. 27
32423 Minden
18.05.2021 Page 3/13
Ship Approvals
Logo
Certificate
name
Approval
ABS
American Bureau of Shipping
EN 60947
20HG1941090PDA
BV
Bureau Veritas S.A.
EN 60947
07436/F0 BV
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
LR
Lloyds Register
EN 60947
91/20112
(E9)
UL-Approvals
Logo
Approval
UR
Underwriters Laboratories Inc.
UL 1059
Certificate
name
20190731E45172
Required accessories
End plate
Item no.: 280-342
End and intermediate plate; 2.5 mm thick; gray
www.wago.com/280-342
Item no.: 280-343
End and intermediate plate; 2.5 mm thick; orange
www.wago.com/280-343
Hansastr. 27
32423 Minden
18.05.2021 Page 4/13
Compatible products
End plate
Item no.: 280-369
Intermediate plate; 1.1 mm thick; orange
www.wago.com/280-369
Item no.: 210-103
Wire commoning chain; insulated; black
www.wago.com/210-103
Item no.: 210-123
Wire commoning chain; insulated; blue
www.wago.com/210-123
Item no.: 280-402
Jumper; insulated; gray
www.wago.com/280-402
Item no.: 280-409
www.wago.com/280-409
Item no.: 280-482
Jumper; 2-way; insulated; gray
www.wago.com/280-482
Item no.: 280-483
Jumper; 3-way; insulated; gray
www.wago.com/280-483
Item no.: 280-484
Jumper; 4-way; insulated; gray
www.wago.com/280-484
Item no.: 280-485
Jumper; 5-way; insulated; gray
www.wago.com/280-485
Item no.: 280-490
Jumper; 10-way; insulated; gray
www.wago.com/280-490
Item no.: 280-492
www.wago.com/280-492
Item no.: 281-421
Vertical jumper; insulated; gray
www.wago.com/281-421
Item no.: 709-110
Wire commoning chain; 2.5 mm²; insulated; black
www.wago.com/709-110
Item no.: 709-111
www.wago.com/709-111
Item no.: 709-112
www.wago.com/709-112
Item no.: 780-452
Staggered jumper; from 1 to 2; insulated; gray
www.wago.com/780-452
Item no.: 780-453
www.wago.com/780-453
Jumper
Hansastr. 27
32423 Minden
18.05.2021 Page 5/13
Item no.: 780-453
Staggered jumper; from 1 to 3; insulated; gray
Item no.: 780-454
Staggered jumper; from 1 to 4; insulated; gray
www.wago.com/780-454
Item no.: 780-455
Staggered jumper; from 1 to 5; insulated; gray
www.wago.com/780-455
Item no.: 780-456
Staggered jumper; from 1 to 6; insulated; gray
www.wago.com/780-456
Item no.: 780-457
Staggered jumper; from 1 to 7; insulated; gray
www.wago.com/780-457
Item no.: 780-458
Staggered jumper; from 1 to 8; insulated; gray
www.wago.com/780-458
Push-In type wire jumper
Item no.: 249-123
Push-in type wire jumper; 0.75 mm²; insulated; 180 mm long; black
www.wago.com/249-123
Item no.: 249-125
Push-in type wire jumper; insulated; 60 mm long; black
www.wago.com/249-125
Item no.: 249-126
Push-in type wire jumper; 0.75 mm²; insulated; 110 mm long; black
www.wago.com/249-126
Item no.: 249-127
Push-in type wire jumper; 0.75 mm²; insulated; 250 mm long; black
www.wago.com/249-127
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
ferrule
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
Hansastr. 27
32423 Minden
www.wago.com/216-204
18.05.2021 Page 6/13
Item no.: 216-204
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-302
Protective Warning Marker
Item no.: 280-415
Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow
www.wago.com/280-415
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short; multicoloured
www.wago.com/210-657
Item no.: 210-658
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short; multicoloured
www.wago.com/210-658
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-720
tools
Carrier rail
Item no.: 210-112
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112
silver-colored
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
www.wago.com/210-113
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
www.wago.com/210-114
Item no.: 210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115
silver-colored
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
www.wago.com/210-118
Item no.: 210-196
www.wago.com/210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored
www.wago.com/210-198
Item no.: 210-504
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715; silvercolored
www.wago.com/210-504
Item no.: 210-505
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715;
Hansastr. 27
32423 Minden
www.wago.com/210-505
18.05.2021 Page 7/13
silver-colored
Item no.: 210-506
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715; silvercolored
www.wago.com/210-506
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715; silvercolored
www.wago.com/210-508
Marking accessories
Item no.: 2009-115
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-115
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/793-501
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
type; white
assembling
Item no.: 209-106
Mounting carrier; for isolated mounting on DIN 35 rails; gray
www.wago.com/209-106
Item no.: 249-116
Screwless end stop; 6 mm wide; for DIN-rail 35 x 15 and 35 x 7.5; gray
www.wago.com/249-116
Item no.: 709-154
Cover; Type 2; suitable for cover carrier, type 2; 1 m long; transparent
www.wago.com/709-154
Insulation stop
Item no.: 280-470
Insulation stop; 0.08 - 0.2 mm² "s" (0.14 mm² "f-st"); 5 pieces/strip; white
www.wago.com/280-470
Item no.: 280-471
Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray
www.wago.com/280-471
Item no.: 280-472
Insulation stop; 0.75 - 1 mm²; 5 pieces/strip
www.wago.com/280-472
Item no.: 249-141
L-type test plug module; modular; with spring-loaded contact pin; Center module; 1,50 mm²; gray
www.wago.com/249-141
Item no.: 249-142
L-type end module; modular; with rigid contact pin; End module; 1,50 mm²; gray
www.wago.com/249-142
check
Downloads
Documentation
Bid Text
280-534to changes. Please also observe the further product documentation!
Subject
Hansastr. 27
32423 Minden
2019 Feb 19
xml
Download
18.05.2021 Page 8/13
2019 Feb 19
xml
3.5 kB
Download
2017 Feb 28
doc
25.1 kB
Download
2019 Apr 3
pdf
2.2 MB
Download
URL
Download
EPLAN Data Portal 280-534
URL
Download
WSCAD Universe 280-534
URL
Download
ZUKEN Portal 280-534
URL
Download
URL
Download
280-534
X81 - Datei
280-534
doc - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
2D/3D Models 280-534
CAE data
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 280-534
Double-deck terminal block; Through/through terminal block; with additional jumper
position on lower level; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; CAGE CLAMP®; 2,50
mm²; gray/blue
Installation Notes
Installation
Hansastr. 27
32423 Minden
18.05.2021 Page 9/13
Snapping a terminal block onto the DIN-rail.
Removing a terminal block from the
assembly.
Double-deck terminal blocks accommodate
two circuits of different potentials on two
decks; different circuits can be
differentiated by color coding either deck
(280 Series). The lower deck is wider than
the upper for easier wiring.
Conductor termination
The flexible marker carrier, which is placed
above the wiring level, can be pushed aside
during wiring or commoning. The carrier has
two staggered levels for WMB markers that
perfectly align with the terminal block decks.
Commoning
Hansastr. 27
32423 Minden
18.05.2021 Page 10/13
Commoning using an adjacent jumper
(280‑402).
Push jumpers down until fully inserted!
Commoning
Commoning with a vertical jumper (281‑421).
Combining vertical and adjacent jumpers.
Push vertical jumper down until fully inserted!
Hansastr. 27
32423 Minden
18.05.2021 Page 11/13
Example of a mixed assembly with doubledeck terminal blocks.
The 280 Series Double-Deck Terminal
Blocks are available with decks of same or
different color according to their function.
This is an additional visual aid during wiring,
service or maintenance.
Use 50% less rail space with double-deck
terminal blocks.
Marking
Hansastr. 27
32423 Minden
18.05.2021 Page 12/13
Labeling via WMB Multi Marking System.
Hansastr. 27
32423 Minden
18.05.2021 Page 13/13
很抱歉,暂时无法提供与“280-534”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+100.763921+13.06093
