285-407
285-407
    WAGO(万可电子)
    连接器 分接线夹接线板 用于
285-407 数据手册
Printview: Power tap; for 95 mm² high-current terminal blocks; module width 20 mm - Item No.: 285-407 . Power tap; for 95 mm² high-current terminal blocks; module width 20 mm Item No.: 285-407 . Power tap; for 95 mm² high-current terminal blocks; module width 20 mm . Marking . Business data Supplier WAGO Item no. 285-407 GTIN / EAN 4045454326241 Content 1 Order amount 5 Customer item number . Notes Technical data Miscellaneous Total number of connection points 2 Total number of potentials 2 Color gray Ratings according to 1 IEC/EN 60947-7-1 Pollution degree (1) 3 Rated voltage EN (1) [V] 1000 [V] Rated surge voltage (1) [kV] 8 [kV] Nominal current [A] 57 [A] Connection technology (1) CAGE CLAMP® Solid sizes 1 0.2 … 10 mm² / 24 … 8 AWG WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Power tap; for 95 mm² high-current terminal blocks; module width 20 mm - Item No.: 285-407 Technical data Fine-stranded wires 1 0.2 … 10 mm² / 24 … 8 AWG Strip length 1 12 … 13 mm / 0.47 … 0.51 in Type of wiring Front-entry wiring Design angled Marking level Center marking Fire load [MJ] 0.249 [MJ] Weight [g] 22.81 [g] Width 20 mm / 0.787 in Height 20 mm / 0.787 in Module width [mm] 20 [mm] Module width [inch] [inch] 0.787 [inch] WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Power tap; for 95 mm² high-current terminal blocks; module width 20 mm - Item No.: 285-407 Images & drawings . WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Power tap; for 95 mm² high-current terminal blocks; module width 20 mm - Item No.: 285-407 Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
285-407 价格&库存
很抱歉,暂时无法提供与“285-407”相匹配的价格&库存,您可以联系我们找货
    库存:25
