30FLZT-SM1-TF(H)(LF)(SN)
    JST
    30 Circuit .5mm Pitch FPC Connector
30FLZT-SM1-TF(H)(LF)(SN) 数据手册
0.5mmピッチ 0.5mm ピッチ FLZT CONNECTOR Emboss Tape 0.5mm pitch/Connectors for FPC Specifications ––––––––––––––––––– • Current rating: 0.5A AC, DC • Voltage rating: 50V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/20m Ω max. After environmental testing/40m Ω max. • Insulation resistance: 100M Ω min. • Withstanding voltage: 200V AC/minute • Applicable FPC: Conductor pitch/0.5mm Conductor width/0.35mm Mating part thickness/0.3±0.05mm Note: FPC to be actually used should be checked for applicability. Vertical 0.5mm pitch ZIF type connector with staggered solder tails. Both normal type and reverse type are available. • Zero insertion force mechanism • Two types of connections • Heat resisting design suitable for surface mounting * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 PC board layout (viewed from component side) and Assembly layout Normal type Reverse type A±0.1 1.0±0.05 0.5±0.05 A±0.1 1.0±0.05 0.5±0.05 1.0 1.4 Circuit No.1 1.7 1.7 4.3 4.3 1.4 1.0 0.6 0.8 Circuit No.1 A±0.1 A±0.1 1.0±0.05 0.5±0.05 1.0±0.05 0.5±0.05 1.0 1.4 Circuit No.1 1.7 1.7 4.3 4.3 1.4 1.0 0.8 Odd number circuits Odd number circuits 3.9 0.6 0.6 0.8 Even number circuits Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. The dimensions above should serve as a guideline. Contact JST for details. 1 3.0 0.6 Even number circuits 0.8 Circuit No.1 3.3 FLZT CONNECTOR Connector Normal type Circuits 6 A 0.5 Circuit No.1 8 10 12 14 15 16 3.0 20 B 22 3.9 (5.6) 24 F JST 28 30 37 0.2 40 3.3 42 Model No. Normal type Reverse type 06FLZT-SM1-TF 06FLZT-RSM1-TF 08FLZT-SM1-TF 08FLZT-RSM1-TF 10FLZT-SM1-TF 10FLZT-RSM1-TF 12FLZT-SM1-TF 12FLZT-RSM1-TF 14FLZT-SM1-TF 14FLZT-RSM1-TF 15FLZT-SM1-TF 15FLZT-RSM1-TF 16FLZT-SM1-TF 16FLZT-RSM1-TF 20FLZT-SM1-TF 20FLZT-RSM1-TF 22FLZT-SM1-TF 22FLZT-RSM1-TF 24FLZT-SM1-TF 24FLZT-RSM1-TF 28FLZT-SM1-TF 28FLZT-RSM1-TF 30FLZT-SM1-TF 30FLZT-RSM1-TF 37FLZT-SM1-TF 37FLZT-RSM1-TF 40FLZT-SM1-TF 40FLZT-RSM1-TF 42FLZT-SM1-TF 42FLZT-RSM1-TF Dimensions (mm) A B Q'ty / reel 2.5 8.5 1,500 3.5 9.5 1,500 4.5 10.5 1,500 5.5 11.5 1,500 6.5 12.5 1,500 7.0 13.0 1,500 7.5 13.5 1,500 9.5 15.5 1,500 10.5 16.5 1,500 11.5 17.5 1,500 13.5 19.5 1,500 14.5 20.5 1,500 18.0 24.0 1,500 19.5 25.5 1,500 20.5 26.5 1,500 Material and Finish Reverse type Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment) Slider housing: PPS, UL94V-0        Nomal type...natural (brown)        Reverse type...black Housing: PPS, UL94V-0, natural Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) A 0.5 RoHS compliance This product displays (LF)(SN) on a label. Circuit No.1 3.0 3.9 (5.6) B F JST 0.2 3.3 Lead section dimensions of FPC 0.5(N+1)±0.05 0.5±0.1 0.5(N−1)±0.03 0.3±0.05 0.35±0.04 (4.5) 3.0min 0.5±0.03 Base layer Cover layer Reinforcing layer Note: N---Number of circuits 2
30FLZT-SM1-TF(H)(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“30FLZT-SM1-TF(H)(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
