PHT-104-04-L-S
PHT-104-04-L-S
    SAMTEC(申泰)
    Conn Unshrouded Header HDR 4 POS 2.54mm Press Fit ST Thru-Hole
PHT-104-04-L-S 数据手册
PRESS-FIT HEADERS & SOCKETS (2.54 mm) .100" PITCH • PHT/PHF SERIES PHT Board Mates: SSW, SSQ, ESW, ESQ, BCS, BSW, CES, SLW, PHF, SSM Cable Mates: IDSD, IDSS -1 PHT NO. PINS PER ROW 01 02 thru 50 Board Mates: TSW, MTSW, MTLW, EW, ZW, TSS, ZSS, TSM, TSSH, PHT, DW, HW PROCESSING - - PLATING OPTION ROW OPTION –L = Polarized Position –D LEAD STYLE A –01 (2.54) .100 –02 (5.08) .200 –03 (7.62) .300 –04 (10.16) .400 (5.02) .198 A A (3.10) .122 STYLE —01 STYLE —02, —03 & —04 PHF A (3.10) .122 STYLE —01 -1 NO. PINS PER ROW 01 02 thru 50 ALSO AVAILABLE - LEAD STYLE Specify LEAD STYLE from chart - STYLE —02, —03 & —04 PLATING OPTION - ROW OPTION –L TOOLING OTHER OPTION –“XXX” = Single Row = Polarized Position –D = Double Row No. of positions x (2.54) .100 + (0.51) .020 (2.41) .095 - –S = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail Other Platings (MOQ Required) Note: Some lengths, styles and options are non-standard, non-returnable. –“XXX” = Single Row (5.84) .230 A OTHER OPTION = Double Row (2.49) .098 = (single row only) Press-Fit PHT: CAT-PT-PH-1XX-X-X PHF: CAT-PT-PH-1XX-X-B For more information, visit www.samtec.com/tooling - –S = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail No. of positions x (2.54) .100 SPECIFICATIONS Contact ipg@samtec.com LEAD STYLE Specify LEAD STYLE from chart = (single row only) PHF Insulator Material: Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (PHT/PHF): 4.8 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C with Gold (PHF) Insertion Depth: (3.68 mm) .145" to (6.35 mm) .250" - (4.95) .195 LEAD STYLE A –01 (8.50) .335 –02 (11.05).435 –03 (13.59).535 –04 (16.13).635 A A STYLE —03 & —04 A STYLE —02 A STYLE —01 STYLE —01 A STYLE —02 (3.12) .123 STYLE —03 & —04 samtec.com?PHT or samtec.com?PHF Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
PHT-104-04-L-S 价格&库存
很抱歉,暂时无法提供与“PHT-104-04-L-S”相匹配的价格&库存,您可以联系我们找货
