Data sheet | Item number: 857-724
Solid-state relay module; Nominal input voltage: 24 VDC; Output voltage
range: 0 … 24 VDC; Limiting continuous current: 3 A; 2-wire connection;
Yellow status indicator; Module width: 6 mm; gray
www.wago.com/857-724
Similar to
pictured
device
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
30.05.2020 Page 1/16
Current-carrying capacity curve
Item description
Note:
Optocouplers and solid state relays are designed for use in signal processing networks, which are not supplied by the low-voltage power supply
networks.
Data
Technical Data
Control circuit
Nominal input voltage UN
DC 24 V
Input voltage range (low level)
DC 0 … 10 V
Input voltage range (high level)
DC 18,8 … 31,2 V
Nominal input current at UN
9,2 mA
Load circuit:
Circuit type
2-wire connection
3 A
Inrush current (resistive) (max.)
(AC) 15 A / 0,01 s
Nominal output voltage
DC 24 V
Output voltage range
DC 0 … 30 V
Voltage drop at output (max.)
≤ DC 0,12 V
Hansastr. 27
32423 Minden
30.05.2020 Page 2/16
≤ DC 0,12 V
Leakage current at rated voltage
≤ 1 µA
Switching current (min.)
50 µA
Turn-on time
≤ 100 µs
Turn-off time
≤ 600 µs
Switching frequency
≤ 350 Hz
Signaling
Status indicator
Yellow LED
Safety and protection:
Dielectric strength, control/load circuit (AC, 1 min)
3,75 kVrms
Protection type
IP20
Connection data
Connection technology
Push-in CAGE CLAMP®
Solid conductor
0,34 … 2,5 mm² / 22 … 14 AWG
Fine-stranded conductor
Strip length
9 … 10 mm / 0.35 … 0.39 inch
Geometrical Data
Width
6 mm / 0.236 inch
Height from upper-edge of DIN-rail
81 mm / 3.189 inch
Depth
94 mm / 3.701 inch
Mechanical data
Mounting type
DIN-35 rail
Material Data
Color
gray
Fire load
0.149 MJ
Weight
28.4 g
Hansastr. 27
32423 Minden
30.05.2020 Page 3/16
Environmental Requirements
Surrounding air temperature (operation at UN)
-20 … 70 °C
Surrounding air temperature (storage)
-40 … 70 °C
Processing temperature
-25 … +50 °C
Standards and specifications
Standards/specifications
EN 61000-6-2; EN 61000-6-3; EN 61373; EN 61010-2-201; UL 508;
GL
Elementary relay
WAGO Basic Relay
857-161
Commercial data
Product Group
6 (Interface Electronics)
Packaging type
BOX
Country of origin
CN
GTIN
4045454835552
Customs tariff number
85365005000
Approvals / Certificates
Ex-Approvals
Logo
Approval
Additional Approval Text
Certificate name
ATEX
DEKRA EXAM GmbH
EN 60079-0
BVS_14_ATEX_E_091_X
IECEx
DEKRA EXAM GmbH
IEC 60079-0
IECEx_BVS_14.0079_X
Ship Approvals
Logo
Approval
Certificate
name
BV
Bureau Veritas S.A.
40179_A0
Hansastr. 27
32423 Minden
30.05.2020 Page 4/16
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAA00001D1
NK
Nippon Kaiji Kyokai
TA17255M
PRS
Polski Rejestr Statków
TE/2186
/880590/18
UL-Approvals
Logo
Approval
UL
UL International Netherlands B.V. (ORDINARY
LOCATIONS)
UL 508
Certificate
name
E175199
Sec.4
Counterpart
Compatible products
General accessories
Item no.: 209-184
Protection cover; transparent
www.wago.com/209-184
Item no.: 857-161
Basic solid-state relay; Nominal input voltage: 24 VDC; Output voltage range: 0 … 24 VDC; Limiting
www.wago.com/857-161
Marking accessories
Item no.: 2009-110
Marking strips; on reel; not stretchable; plain; snap-on type; white
Hansastr. 27
32423 Minden
www.wago.com/2009-110
30.05.2020 Page 5/16
Item no.: 2009-115
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-115
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
/000-002
Item no.: 2009-115/000-006
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-115/000-007
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-115/000-012
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-115/000-017
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light
green
/000-017
Item no.: 2009-115/000-023
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 2009-115/000-024
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 209-128
Adaptor; gray
www.wago.com/209-128
Item no.: 209-183
Marker card; white
www.wago.com/209-183
Item no.: 210-110
Fiber-tip pen
www.wago.com/210-110
Item no.: 249-105
Group marker carrier; gray
www.wago.com/249-105
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/793-501
Item no.: 793-501/000-002
WMB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 793-501/000-005
Hansastr. 27
32423 Minden
30.05.2020 Page 6/16
WMB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 793-501/000-006
WMB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 793-501/000-007
WMB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 793-501/000-012
WMB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 793-501/000-017
WMB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 793-501/000-023
WMB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 793-501/000-024
WMB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 793-502
WMB marking card; as card; MARKED; 1 ... 10 (10x); not stretchable; Horizontal marking; snap-on type;
white
www.wago.com/793-502
Item no.: 793-502/000-002
yellow
/000-002
Item no.: 793-502/000-005
red
/000-005
Item no.: 793-502/000-006
blue
/000-006
Item no.: 793-502/000-007
gray
/000-007
Item no.: 793-502/000-012
orange
/000-012
Item no.: 793-502/000-017
/000-017
light green
Hansastr. 27
32423 Minden
30.05.2020 Page 7/16
light green
Item no.: 793-502/000-023
green
/000-023
Item no.: 793-502/000-024
violet
/000-024
Item no.: 793-503
WMB marking card; as card; MARKED; 11 ... 20 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-503
white
Item no.: 793-503/000-002
/000-002
yellow
Item no.: 793-503/000-005
/000-005
red
Item no.: 793-503/000-006
/000-006
blue
Item no.: 793-503/000-007
/000-007
gray
Item no.: 793-503/000-012
/000-012
orange
Item no.: 793-503/000-017
/000-017
light green
Item no.: 793-503/000-023
/000-023
green
Item no.: 793-503/000-024
/000-024
violet
Item no.: 793-504
WMB marking card; as card; MARKED; 21 ... 30 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-504
white
Item no.: 793-504/000-002
/000-002
yellow
Item no.: 793-504/000-005
Hansastr. 27
32423 Minden
30.05.2020 Page 8/16
red
/000-005
Item no.: 793-504/000-006
/000-006
blue
Item no.: 793-504/000-012
/000-012
orange
Item no.: 793-504/000-017
/000-017
light green
Item no.: 793-504/000-023
/000-023
green
Item no.: 793-505
WMB marking card; as card; MARKED; 31 ... 40 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-505
white
Item no.: 793-505/000-005
/000-005
red
Item no.: 793-505/000-006
/000-006
blue
Item no.: 793-505/000-007
/000-007
gray
Item no.: 793-505/000-012
/000-012
orange
Item no.: 793-506
WMB marking card; as card; MARKED; 41 ... 50 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-506
white
Item no.: 793-506/000-005
/000-005
red
Item no.: 793-506/000-006
/000-006
blue
Item no.: 793-506/000-012
/000-012
orange
Hansastr. 27
32423 Minden
30.05.2020 Page 9/16
Item no.: 793-506/000-017
/000-017
light green
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
type; white
Item no.: 793-5501/000-002
/000-002
type; yellow
Item no.: 793-5501/000-005
/000-005
type; red
Item no.: 793-5501/000-006
/000-006
type; blue
Item no.: 793-5501/000-007
/000-007
type; gray
Item no.: 793-5501/000-012
/000-012
type; orange
Item no.: 793-5501/000-014
/000-014
type; brown
Item no.: 793-5501/000-017
/000-017
type; green
Item no.: 793-5501/000-023
/000-023
type; light green
Item no.: 793-5501/000-024
/000-024
type; violet
Item no.: 793-566
WMB marking card; as card; MARKED; 1 ... 50 (2x); not stretchable; Horizontal marking; snap-on type;
white
www.wago.com/793-566
Item no.: 793-566/000-002
yellow
/000-002
Item no.: 793-566/000-005
red
Hansastr. 27
32423 Minden
30.05.2020 Page 10/16
red
/000-005
Item no.: 793-566/000-006
blue
/000-006
Item no.: 793-566/000-007
gray
/000-007
Item no.: 793-566/000-012
orange
/000-012
Item no.: 793-566/000-017
light green
/000-017
Item no.: 793-566/000-023
green
/000-023
Item no.: 793-566/000-024
violet
/000-024
transfer module
Item no.: 857-981
Interface adapter; 14-pole; High-side switching input
www.wago.com/857-981
Item no.: 857-982
Interface adapter; 14-pole; High-side switching output
www.wago.com/857-982
Item no.: 857-986
Interface adapter; 15-pole; High-side switching input
www.wago.com/857-986
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
ferrule
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Jumper
Hansastr. 27
32423 Minden
30.05.2020 Page 11/16
Jumper
Item no.: 281-482
Comb-style jumper bar; insulated; 2-way; IN = IN terminal block; gray
www.wago.com/281-482
Item no.: 859-402
Push-in type jumper bar; 2-way; Nominal current 18 A; insulated; light gray
www.wago.com/859-402
Item no.: 859-402/000-005
Push-in type jumper bar; 2-way; Nominal current 18 A; insulated; red
/000-005
Item no.: 859-402/000-006
Push-in type jumper bar; 2-way; Nominal current 18 A; insulated; blue
/000-006
Item no.: 859-402/000-029
Push-in type jumper bar; 2-way; Nominal current 18 A; insulated; yellow
/000-029
Item no.: 859-403
Push-in type jumper bar; 3-way; Nominal current 18 A; insulated; light gray
www.wago.com/859-403
Item no.: 859-403/000-005
Push-in type jumper bar; 3-way; Nominal current 18 A; insulated; red
/000-005
Item no.: 859-403/000-006
Push-in type jumper bar; 3-way; Nominal current 18 A; insulated; blue
/000-006
Item no.: 859-403/000-029
Push-in type jumper bar; 3-way; Nominal current 18 A; insulated; yellow
/000-029
Item no.: 859-404
Push-in type jumper bar; 4-way; Nominal current 18 A; insulated; light gray
www.wago.com/859-404
Item no.: 859-404/000-005
Push-in type jumper bar; 4-way; Nominal current 18 A; insulated; red
/000-005
Item no.: 859-404/000-006
Push-in type jumper bar; 4-way; Nominal current 18 A; insulated; blue
/000-006
Item no.: 859-404/000-029
Push-in type jumper bar; 4-way; Nominal current 18 A; insulated; yellow
/000-029
Item no.: 859-405
Push-in type jumper bar; 5-way; Nominal current 18 A; insulated; light gray
www.wago.com/859-405
Item no.: 859-405/000-005
Hansastr. 27
32423 Minden
30.05.2020 Page 12/16
Push-in type jumper bar; 5-way; Nominal current 18 A; insulated; red
/000-005
Item no.: 859-405/000-006
Push-in type jumper bar; 5-way; Nominal current 18 A; insulated; blue
/000-006
Item no.: 859-405/000-029
Push-in type jumper bar; 5-way; Nominal current 18 A; insulated; yellow
/000-029
Item no.: 859-406
Push-in type jumper bar; 6-way; Nominal current 18 A; insulated; light gray
www.wago.com/859-406
Item no.: 859-406/000-005
Push-in type jumper bar; 6-way; Nominal current 18 A; insulated; red
/000-005
Item no.: 859-406/000-006
Push-in type jumper bar; 6-way; Nominal current 18 A; insulated; blue
/000-006
Item no.: 859-406/000-029
Push-in type jumper bar; 6-way; Nominal current 18 A; insulated; yellow
/000-029
Item no.: 859-407
Push-in type jumper bar; 7-way; Nominal current 18 A; insulated; light gray
www.wago.com/859-407
Item no.: 859-407/000-005
Push-in type jumper bar; 7-way; Nominal current 18 A; insulated; red
/000-005
Item no.: 859-407/000-006
Push-in type jumper bar; 7-way; Nominal current 18 A; insulated; blue
/000-006
Item no.: 859-407/000-029
Push-in type jumper bar; 7-way; Nominal current 18 A; insulated; yellow
/000-029
Item no.: 859-408
Push-in type jumper bar; 8-way; Nominal current 18 A; insulated; light gray
www.wago.com/859-408
Item no.: 859-408/000-005
Push-in type jumper bar; 8-way; Nominal current 18 A; insulated; red
/000-005
Item no.: 859-408/000-006
Push-in type jumper bar; 8-way; Nominal current 18 A; insulated; blue
/000-006
Item no.: 859-408/000-029
Hansastr. 27
32423 Minden
30.05.2020 Page 13/16
Push-in type jumper bar; 8-way; Nominal current 18 A; insulated; yellow
/000-029
Item no.: 859-409
Push-in type jumper bar; 9-way; Nominal current 18 A; insulated; light gray
www.wago.com/859-409
Item no.: 859-409/000-005
Push-in type jumper bar; 9-way; Nominal current 18 A; insulated; red
/000-005
Item no.: 859-409/000-006
Push-in type jumper bar; 9-way; Nominal current 18 A; insulated; blue
/000-006
Item no.: 859-409/000-029
Push-in type jumper bar; 9-way; Nominal current 18 A; insulated; yellow
/000-029
Item no.: 859-410
Push-in type jumper bar; 10-way; Nominal current 18 A; insulated; light gray
www.wago.com/859-410
Item no.: 859-410/000-005
Push-in type jumper bar; 10-way; Nominal current 18 A; insulated; red
/000-005
Item no.: 859-410/000-006
Push-in type jumper bar; 10-way; Nominal current 18 A; insulated; blue
/000-006
Item no.: 859-410/000-029
Push-in type jumper bar; 10-way; Nominal current 18 A; insulated; yellow
/000-029
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft
www.wago.com/210-720
tools
Downloads
Documentation
Bid Text
857-724
Feb 20, 2019
docx
16.5 kB
Download
Feb 19, 2019
xml
4.2 kB
Download
pdf
Download
GAEB docx - Datei
857-724
GAEB X81 - Datei
Instruction Leaflet
Stecksockel
mit Optokoppler
Subject
to changes.
Hansastr. 27
32423 Minden
30.05.2020 Page 14/16
pdf
2.4 MB
Download
V 1.4.0
Oct 15, 2019
pdf
2.4 MB
Download
Disposal; Electrical and electronic equipment, Packaging
V 1.0.0
pdf
265.8 kB
Download
Step Datei Serie 857-07xx
1.0
Jun 20, 2011
ifc
299.3 kB
Download
URL
Download
EPLAN Data Portal 857-724
URL
Download
WSCAD Universe 857-724
URL
Download
Stecksockel mit Optokoppler
Eingangsnennspannung DC 24 V, Schaltstrom 2 A
Elektromechanical and Solid-State Relays/Optocouplers
Additional Information
CAD/CAE-Data
CAD data
2D/3D Models 857-724
CAE data
Handling Instructions
Conductor termination
Connection of conductor
Commoning
Hansastr. 27
32423 Minden
30.05.2020 Page 15/16
Easy commoning using adjacent jumpers
Marking
Marking using WMB Multi markers
Installation
Operation of the relay ejector
Hansastr. 27
32423 Minden
30.05.2020 Page 16/16
很抱歉,暂时无法提供与“857-724”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+483.366931+57.80880
- 3+476.777253+57.02070
- 5+473.714445+56.65440
- 20+465.6397620+55.68870
- 30+460.3494530+55.05600
