870-404
870-404
    WAGO(万可电子)
    4 位置 接线板 - 交叉连接 跳接器 扁平引脚
870-404 数据手册
Printview: Push-in type jumper bar; insulated; 4-way; nominal current 18 A - Item No.: 870-404 . Push-in type jumper bar; insulated; 4-way; nominal current 18 A Item No.: 870-404 . Push-in type jumper bar; insulated; 4-way; nominal current 18 A . Marking . Business data Supplier WAGO Item no. 870-404 GTIN / EAN 4044918507837 Content 1 Order amount 25 Customer item number . Notes Technical data Miscellaneous Color light gray Nominal current [A] 18 [A] Nominal current (Ex e II) [A] 13.5 [A] Fire load [MJ] 0.02 [MJ] Weight [g] 1.72 [g] Width 19 mm / 0.748 in Length 2.5 mm / 0.098 in WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Push-in type jumper bar; insulated; 4-way; nominal current 18 A - Item No.: 870-404 Images & drawings . WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Push-in type jumper bar; insulated; 4-way; nominal current 18 A - Item No.: 870-404 Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 3
870-404 价格&库存
很抱歉,暂时无法提供与“870-404”相匹配的价格&库存,您可以联系我们找货
