Data sheet | Item number: 870-681
3-conductor through terminal block; 2.5 mm²; lateral marker slots; for DINrail 35 x 15 and 35 x 7.5; CAGE CLAMP®; 2,50 mm²; gray
www.wago.com/870-681
Color:
Item description
Safety information 1:
Max. insulation diameter: 4.4 mm
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
17.05.2021 Page 1/15
Data
Electrical data
Ratings per IEC/EN
Ratings per
IEC/EN 60947-7-1
Nominal voltage (III/3)
500 V
Rated surge voltage (III/3)
6 kV
Rated current
24 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Connection data
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Connectable conductor materials
Copper
Solid conductor
0.08 … 2.5 mm² / 28 … 12 AWG
Fine-stranded conductor
0.08 … 4 mm² / 28 … 12 AWG
Fine-stranded conductor; with insulated ferrule
0.08 … 1.5 mm² / 28 … 14 AWG
Strip length
6 … 7 mm / 0.24 … 0.28 inch
Total number of connection points
3
Total number of potentials
1
Number of levels
1
Wiring type
Front-entry wiring
Physical data
Width
5 mm / 0.197 inch
Height
49 mm / 1.929 inch
Depth from upper edge of DIN-rail
27.5 mm / 1.083 inch
Mechanical data
Design
horizontal type
Mounting type
DIN-35 rail
Marking level
Side marking
Hansastr. 27
32423 Minden
17.05.2021 Page 2/15
Material data
Color
gray
Insulation material
Polyamide (PA66)
Fire load
0.101 MJ
Weight
6 g
Commercial data
Packaging type
BOX
Country of origin
DE
GTIN
4045454094553
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60947
NTR NL
7468
CCA
EN 60947
2189801.01
Approval
ABS
American Bureau of Shipping
20HG1941090PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
LR
Lloyds Register
EN 60947
91/20112
(E9)
Ship Approvals
Logo
Certificate
name
Hansastr. 27
32423 Minden
17.05.2021 Page 3/15
UL-Approvals
Logo
Approval
cURus
UL International Germany GmbH
UL 1059
Certificate
name
20160928E45172
Required accessories
End plate
Item no.: 870-933
End and intermediate plate; 1 mm thick; gray
www.wago.com/870-933
Item no.: 870-934
End and intermediate plate; 1 mm thick; orange
www.wago.com/870-934
Compatible products
check
Item no.: 870-425
Tap-off module; with anti-rotation protection; modular; suitable for 870 Series terminal blocks with
jumper slots in the current bar; gray
www.wago.com/870-425
Item no.: 870-426
Tap-off module; modular; suitable for 870 Series terminal blocks with jumper slots in the current bar;
gray
www.wago.com/870-426
Item no.: 870-427
Spacer module; modular; bridging commoned terminal blocks; gray
www.wago.com/870-427
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short; multicoloured
www.wago.com/210-657
Item no.: 210-658
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short; multicoloured
www.wago.com/210-658
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-720
tools
Protective Warning Marker
Item no.: 280-405
Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow
www.wago.com/280-405
Item no.: 870-946
Separator plate; 1 mm thick; gray
www.wago.com/870-946
End plate
Hansastr. 27
32423 Minden
17.05.2021 Page 4/15
Item no.: 870-947
Separator plate; 1 mm thick; orange
www.wago.com/870-947
Insulation stop
Item no.: 280-470
Insulation stop; 0.08 - 0.2 mm² "s" (0.14 mm² "f-st"); 5 pieces/strip; white
www.wago.com/280-470
Item no.: 280-471
Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray
www.wago.com/280-471
Item no.: 280-472
Insulation stop; 0.75 - 1 mm²; 5 pieces/strip
www.wago.com/280-472
Item no.: 870-402
Jumper; 2-way; insulated; light gray
www.wago.com/870-402
Item no.: 870-403
Jumper; 3-way; insulated; light gray
www.wago.com/870-403
Item no.: 870-404
Push-in type jumper bar; insulated; 4-way; Nominal current 18 A; light gray
www.wago.com/870-404
Item no.: 870-405
Jumper; 5-way; insulated; light gray
www.wago.com/870-405
Item no.: 870-405/011-000
Ready-made push-in type jumper bar; insulated; 3-way (1-3-5); Nominal current 18 A; light gray
/011-000
Item no.: 870-406
Jumper; 6-way; insulated; light gray
www.wago.com/870-406
Item no.: 870-406/020-000
Delta jumper; insulated; light gray
/020-000
Item no.: 870-407
Jumper; 7-way; insulated; light gray
www.wago.com/870-407
Item no.: 870-407/011-000
Ready-made push-in type jumper bar; insulated; 1-3-5-7; Nominal current 18 A; light gray
/011-000
Item no.: 870-408
Jumper; 8-way; insulated; light gray
www.wago.com/870-408
Item no.: 870-409
Jumper; 9-way; insulated; light gray
www.wago.com/870-409
Item no.: 870-409/011-000
Ready-made push-in type jumper bar; insulated; 1-3-5-7-9; Nominal current 18 A; light gray
/011-000
Jumper
Hansastr. 27
32423 Minden
17.05.2021 Page 5/15
Item no.: 870-410
Push-in type jumper bar; insulated; 10-way; Nominal current 18 A; light gray
www.wago.com/870-410
Item no.: 870-433
Jumper; from 1 to 3; insulated; light gray
www.wago.com/870-433
Item no.: 870-434
Jumper; from 1 to 4; insulated; light gray
www.wago.com/870-434
Item no.: 870-435
Jumper; from 1 to 5; insulated; light gray
www.wago.com/870-435
Item no.: 870-436
Jumper; from 1 to 6; insulated; light gray
www.wago.com/870-436
Item no.: 870-437
Jumper; from 1 to 7; insulated; light gray
www.wago.com/870-437
Item no.: 870-438
Jumper; from 1 to 8; insulated; light gray
www.wago.com/870-438
Item no.: 870-439
Jumper; from 1 to 9; insulated; light gray
www.wago.com/870-439
Item no.: 870-440
Push-in type jumper bar; insulated; from 1 to 10; Nominal current 18 A; light gray
www.wago.com/870-440
Marking accessories
Item no.: 2009-115
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-115
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
/000-002
Item no.: 2009-115/000-006
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-115/000-007
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-115/000-012
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-115/000-017
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light
green
/000-017
Item no.: 2009-115/000-023
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Hansastr. 27
32423 Minden
17.05.2021 Page 6/15
Item no.: 2009-115/000-024
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 2009-145
www.wago.com/2009-145
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
Item no.: 2009-145/000-002
yellow
/000-002
Item no.: 2009-145/000-005
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 2009-145/000-006
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue /000-006
Item no.: 2009-145/000-007
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray /000-007
Item no.: 2009-145/000-012
orange
/000-012
Item no.: 2009-145/000-023
green
/000-023
Item no.: 2009-145/000-024
violet
/000-024
Item no.: 248-501
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/248-501
Item no.: 248-501/000-002
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 248-501/000-005
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 248-501/000-006
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 248-501/000-007
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Hansastr. 27
32423 Minden
17.05.2021 Page 7/15
Item no.: 248-501/000-012
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 248-501/000-017
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 248-501/000-023
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 248-501/000-024
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 709-177
Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; translucent
www.wago.com/709-177
Item no.: 709-178
Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; white
www.wago.com/709-178
Item no.: 709-196
Marking strips; for laser printer; translucent
www.wago.com/709-196
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/793-501
Item no.: 793-501/000-002
WMB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 793-501/000-005
WMB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 793-501/000-006
WMB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 793-501/000-007
WMB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 793-501/000-012
WMB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 793-501/000-017
WMB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 793-501/000-023
Hansastr. 27
32423 Minden
17.05.2021 Page 8/15
WMB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 793-501/000-024
WMB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
type; white
Item no.: 793-5501/000-002
/000-002
type; yellow
Item no.: 793-5501/000-005
/000-005
type; red
Item no.: 793-5501/000-006
/000-006
type; blue
Item no.: 793-5501/000-007
/000-007
type; gray
Item no.: 793-5501/000-012
/000-012
type; orange
Item no.: 793-5501/000-017
/000-017
type; green
Item no.: 793-5501/000-023
/000-023
type; light green
Item no.: 793-5501/000-024
/000-024
type; violet
Item no.: 870-182
Adaptor; gray
www.wago.com/870-182
Item no.: 870-183
Adaptor; gray
www.wago.com/870-183
Item no.: 870-184
Adaptor; gray
www.wago.com/870-184
Carrier rail
Item no.: 210-112
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112
Hansastr. 27
32423 Minden
17.05.2021 Page 9/15
silver-colored
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
www.wago.com/210-113
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
www.wago.com/210-114
Item no.: 210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115
silver-colored
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
www.wago.com/210-118
Item no.: 210-196
www.wago.com/210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored
www.wago.com/210-198
Item no.: 210-504
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715; silvercolored
www.wago.com/210-504
Item no.: 210-505
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715;
silver-colored
www.wago.com/210-505
Item no.: 210-506
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715; silvercolored
www.wago.com/210-506
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715; silvercolored
www.wago.com/210-508
Item no.: 216-121
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-121
Item no.: 216-122
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-122
Item no.: 216-123
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-123
Item no.: 216-124
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated
www.wago.com/216-124
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
ferrule
Item no.: 216-132
Hansastr. 27
32423 Minden
17.05.2021 Page 10/15
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-221
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-221
Item no.: 216-222
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-222
Item no.: 216-223
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-223
Item no.: 216-224
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-224
Item no.: 216-321
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-321
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-322
Item no.: 209-106
Mounting carrier; for isolated mounting on DIN 35 rails; gray
www.wago.com/209-106
Item no.: 249-116
Screwless end stop; 6 mm wide; for DIN-rail 35 x 15 and 35 x 7.5; gray
www.wago.com/249-116
Item no.: 249-117
Screwless end stop; 10 mm wide; for DIN-rail 35 x 15 and 35 x 7.5; gray
www.wago.com/249-117
assembling
Downloads
Documentation
Bid Text
870-681
2019 Feb 19
xml
3.3 kB
Download
2017 May 31
doc
25.1 kB
Download
2019 Apr 3
pdf
2.2 MB
Download
X81 - Datei
870-681
doc - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
Hansastr. 27
32423 Minden
17.05.2021 Page 11/15
URL
Download
EPLAN Data Portal 870-681
URL
Download
ZUKEN Portal 870-681
URL
Download
WSCAD Universe 870-681
URL
Download
URL
Download
2D/3D Models 870-681
CAE data
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 870-681
3-conductor through terminal block; 2.5 mm²; lateral marker slots; for DIN-rail 35 x 15
Installation Notes
Installation
Snapping a rail-mount terminal block onto
DIN-35 rail.
Removing a terminal block from the
assembly.
Conductor termination
Hansastr. 27
32423 Minden
17.05.2021 Page 12/15
CAGE CLAMP® connection
Inserting insulation stops into conductor
entry holes of terminal strip.
Inserting a conductor via operating tool (0.08
… 4 mm² “f-st”).
With ferruled conductors, it is necessary to
use a terminal block one size smaller than
the conductor's nominal cross-section.
Commoning
Push jumper bars down firmly until fully
inserted. When using multipole bars, push
alternately on the right and then left side
until installed.
Commoning with push-in type jumper bars:
Commoning terminal blocks of different
sizes via step-down jumpers.
Two parallel jumper slots are
accommodated in one terminal block.
Push-in type jumper bars 1 – 3 – 5 – 7 or
1 – – 4 – – 7
upon request
Testing
Hansastr. 27
32423 Minden
17.05.2021 Page 13/15
Testing with phase testing device, also
possible with single-pole voltage tester.
Testing is also possible using a pre-wired
tap-off module assembly in the very same
way as test plugs.
Cover
Protective warning markers (280‑405), with a
black high-voltage symbol
Marking
Hansastr. 27
32423 Minden
17.05.2021 Page 14/15
WMB markers in Mini-WSB marker slots
Translucent marking strip (709-196) –
jumpers below may be visible.
Mini-WSB markers
In addition to the plastic marker strips, group
marker carriers are now available for the
WMB and WSB marking systems. They can
be mounted in parallel to a push-in type
jumper bar via the open jumper contact slot.
It is also very useful if the marker slots on the
side of the terminal block are hidden. The
carriers are available in the following widths:
5 mm (0.197 inch), 10 mm (0.394 inch) and
15 mm (0.591 inch).
Notice:
Group marker carriers are not suitable for
ground conductor terminal blocks and
double potential terminal blocks as they
have no jumper contact slots.
Hansastr. 27
32423 Minden
17.05.2021 Page 15/15
很抱歉,暂时无法提供与“870-681”相匹配的价格&库存,您可以联系我们找货
