Data sheet | Item number: 890-105
Socket; with strain relief housing; 5-pole; Cod. A; 1,50 mm²; black
www.wago.com/890-105
Color:
Overall length when mated
Item description
Protected against mismating and maintenance-free
Push-in CAGE CLAMP® spring pressure connection technology allows solid conductors to be simply pushed into a unit
Compact design with 4.4 mm pole spacing
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/9
Note:
All connectors for mounted installations (snap-in versions for lighting fixtures or devices, all types of PCB and distribution connectors) are factoryequipped with locking levers to ensure plugs and sockets are securely locked. Additional locking levers are only required for flying leads (plug
/socket).
Note on Protection Against Mismating:
All WINSTA® components are 100% protected against mismating in terms of:
a.) plugging different number of poles
b.) plugging when turned by 180°
c.) plugging when laterally staggered
d.) plugging one pole
Safety information 1:
Application note for the U.S. market (USR): Some versions may also be used for current interruption in accordance with the UL certificate in select
applications with currents below 5 A and voltages up to 600 V. For further information, please contact your local sales office.
Data
Electrical data
Note on Contact Resistance
approx. 1mΩ contact resistance approx. 0.25mΩ contact transition
plug/socket
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
400 V
Rated impulse voltage (III / 3)
6 kV
Rated current
13 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Approvals per UL 1977
Rated voltage per UL 1977 (factory wiring only)
600 V
Rated current per UL 1977 (factory wiring only)
12 A
Connection data
Connection technology
Push-in CAGE CLAMP®
Actuation type
Operating tool
Push-in
Nominal cross section
1.5 mm²
Solid conductor
0.25 … 1.5 mm² / 22 … 16 AWG
Solid conductor, push-in termination
0.75 … 1.5 mm² / 20 … 16 AWG
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 2/9
Stranded conductor
0.25 … 1 mm² / 22 … 18 AWG
Fine-stranded conductor
Fine-stranded conductor with ferrule with plastic collar
0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule without plastic collar
Fine-stranded conductor with ferrule, push-in termination, from
0.75 mm² / 20 AWG
Strip length
9 mm / 0.35 inch
Note (strip length)
see also packaging or instructions
No. of poles
5
Total number of connection points
5
Total number of potentials
5
Connectable sheathed cable diameter
6.5 … 10.5 mm
Conductor entry direction to mating direction
0 °
Strip length
45 mm
Geometrical Data
Pin spacing
4.4 mm / 0.173 inch
Width
26.7 mm / 1.051 inch
Height
15.8 mm / 0.622 inch
Depth
71.9 mm / 2.831 inch
Mechanical data
Coding
A
Mating force of a plug-in connection
approx. 20 … 70 N (depending on pole number)
Retention force of a plug-in connection
When locked: > 80 N
Unmating force of a plug-in connection
when unlocked: approx. 20 … 70 N (depending on pole number)
Number of mating cycles
200, without resistive load
100, with resistive load IN = 16 A, tested (1.5 mm²/AWG 16)
Marking
N 123
Protection class
IP20
Note on protection class
Only in mated condition with strain relief housing (These compact
connectors are not designed for use in open, easily accessible
areas.)
Potential marking
N 123
Application
Standard network application
Plug
connection
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 3/9
Plug connection
Contact type (pluggable connector)
Female connector/socket
Connector connection type
for conductors
Mismating protection
Yes
Locking of plug-in connection
locking lever
Locking lever
no
Strain relief
Material Data
Color
black
Insulating material
Polyamide 66 (PA 66)
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Copper or copper alloy, surface-treated
Fire load
0.29 MJ
Weight
11.9 g
Environmental Requirements
Processing temperature
-5 … +40 °C
Continuous operating temperature
-35 … +85 °C
Note on Continuous Service Temperature
Insulating parts for temperatures ≤ 105 °C
Commercial data
Product Group
20 (WINSTA)
Packaging type
BOX
Country of origin
DE
GTIN
4045454232870
Customs Tariff No.
85366990990
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 61535
71102984
CCA
IEC 61535
NL-49482
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 4/9
Ship Approvals
Logo
Certificate
name
Approval
ABS
American Bureau of Shipping
Steel Vessel Rules
19HG1869855PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001Z6
LR
Lloyds Register
EN 61535
08/20047
(E2)
UL-Approvals
Logo
Approval
Certificate
name
cURus
Underwriters Laboratories Inc.
UL 1977
E45171
Compatible products
shield connection
Item no.: 890-526
Shield connecting plate; 5-pole; for sockets
www.wago.com/890-526
Item no.: 890-101
Locking lever; for manual operation; black
www.wago.com/890-101
Item no.: 890-111
Locking lever; for flying leads; for tool operation; black
www.wago.com/890-111
Item no.: 890-121
Locking lever; for manual operation; white
www.wago.com/890-121
Locking lever
Item no.: 890-131
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 5/9
Item no.: 890-131
Locking lever; for flying leads; for tool operation; white
www.wago.com/890-131
Item no.: 890-310
Mounting carrier; 2- to 5-pole; for flying leads; black
www.wago.com/890-310
Item no.: 890-311
Mounting carrier; 2- to 5-pole; for flying leads; white
www.wago.com/890-311
Item no.: 210-719
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft
www.wago.com/210-719
Item no.: 890-385
Operating tool; 5-way; green
www.wago.com/890-385
assembling
tools
Downloads
Documentation
Bid Text
890-105
Jun 8, 2015
doc
24.1 kB
Download
Feb 19, 2019
xml
3.1 kB
Download
URL
Download
doc - Datei
890-105
X81 - Datei
CAD/CAE-Data
CAD data
2D/3D Models 890-105
CAE data
WSCAD Universe 890-105
Download
Installation Notes
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 6/9
1. Strip length, outer insulation = 30 mm (2pole), 37 mm (3-pole), 45 mm (4- and 5-pole)
2. Strip length = 9 mm
To terminate fine-stranded conductors,
open the clamping unit via screwdriver (2.5
mm blade width) and insert a stripped
conductor until it hits backstop. Terminate
solid conductors by simply pushing them in.
3. Extended ground conductor = 8 mm
open clamping units via operating tool (890382) and insert stripped conductors until
they hit backstop.
Terminate solid conductors by simply
pushing them in.
open clamping units via operating tool (890383) and insert stripped conductors until
they hit backstop.
pushing them in.
Assembly
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 7/9
Latch wired connector onto the base of the
strain relief housing.
Push down strain relief clamp by hand.
Latch the top of the strain relief housing.
The printed marking of the connector is
clearly visible in the openings of the strain
relief housing.
Push down strain relief clamp via 2.5 mm
screwdriver alternately on both sides.
Shield Connection
Connector with shield termination
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 8/9
Apply the shield to the rubber cable.
Push the shield connecting plate into the
connector until fully inserted.
First insert wired connector into strain relief
housing, then snap the clamp and cover.
Shield length = 8 mm
Product family
WINSTA® MINI
Show all products from the family
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 9/9
很抱歉,暂时无法提供与“890-105”相匹配的价格&库存,您可以联系我们找货
