RF174-03SP1-04BJ3-0200 . 数据手册
RF-18 (Rev 28JUN18)
RF174–07SP1–01BJ1–0300
RF174–01RP1–02RP1–0200
50 W RG 174 CABLE ASSEMBLIES
Standard performance 26 AWG
RG 174 coax cable
Mates with:
MCX, MMCX, MMCXV,
SMA, SMB5, BNC5,
TNC
SPECIFICATIONS
For complete specifications see
www.samtec.com?RF174
Plugs and
Jacks
RF Connector:
Outer Contact Material:
Ni plated Brass (BNC)
Au plated Brass (SMB & SMA)
Au plated BeCu (MCX & MMCX)
Center Contact Material:
Au plated Brass (BNC-P, MCX-P,
MMCX-P & SMA-P)
Au plated BeCu
(SMB-P & SMA-J)
Au plated Phos. Bronze (BNC-J)
Insulator Material:
PTFE
Operating Temperature:
-50 °C to +90 °C
Impedance:
50 W
Frequency Range:
0~6 GHz
(Cable & connector dependent)
RoHS Compliant:
Yes
2.3dK
Solutionator
DESIGN IN A MINUTE
• Create a full system:
cable assembly and board level mates,
50 Ω and 75 Ω solutions
• Free samples available
• Visit: rf.samtec.com
Single or
Double Ended
Straight or
Right-angle
RG 174 Cable:
Impedance:
50 W
Capacitance:
101.024 pF/meter
Max Attenuation
(cable only):
1.4 dB @ 1 GHz for 1 meter
Conductor Size:
26 AWG, (0.48 mm) .019" dia.
Conductor Material:
Copper
Insulator Material:
KLPE
Shield Material:
Tin Copper
Jacket Material:
PVC
Jacket Diameter:
(2.70 mm) .106"
Jacket Color:
Black
Bend Radius:
25.4 mm
RoHS Compliant:
Yes
END 2
CONNECTOR
END 1
CONNECTOR
CABLE TYPE
Specify END OPTIONS from chart
RF174
= RG 174 Cable
–01SP1–01RP1 SHOWN
XXXX = OAL (millimeters)
END OPTIONS
–01SP1 = SMA
Straight Plug
(30 µ" (0.76 µm)
Gold on Center Contact,
Gold Flash on Shell)
END OPTIONS
–02RP1 = MCX
Right-angle Plug
(30 µ" (0.76 µm) Gold on Center
Contact, Gold Flash on Shell)
–02SP1 = MCX
Straight Plug
–03SP1 = MMCX
Straight Plug
–03RP1 = MMCX
Right-angle Plug
–V3SP1 = MMCXV
Straight Plug, High Vibration
Contact, Nickel on Shell)
–V3RP1 = MMCXV
Right-angle Plug, High Vibration
–V3SJ1 = MMCXV
Straight Jack, High Vibration
–01RP1 = SMA
Righ-angle Plug
(30 µ" (0.76 µm)
–07SP1 = SMB
Straight Plug
(30 µ" (0.76 µm)
–07RP1 = SMB
Righ-angle Plug
(30 µ" (0.76 µm)
–02SJ1 = MCX
Straight Jack
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
RF174–02RP1–02SP1–0200
RF174–03RP1–07RP1–0200
RF174–04BJ2–07SP1–0100
RF174 SERIES
Variety of
Bulkhead Jacks
Heavy Gold
plated
Standard heat
shrink wraps
Single or
Double ended
ALSO AVAILABLE
(MOQ Required)
• Additional stripping and tinning options
• IP67 TNC option
• Additional plating options
Choice of RF
connector styles
OTHER SOLUTIONS
• Additional end connector combinations
• Knurled nuts with BNC option
• Cable connector kits
(see cable components catalog pages)
OVERALL LENGTH
–“XXXX”
= Overall Length in millimeters –0100 (100 mm) minimum
(Cable lengths larger than 1000 millimeters are not supported by S.I. Test data)
END OPTIONS
END OPTIONS
–04SP3 = BNC
Straight Plug
(10 µ" (0.25 µm)
Nickel on Shell)
–01PN1 = SMA
4-Hole Panel Mount Jack
(30 µ" (0.76 µm)
–05SP3 = TNC
Straight Plug
(10 µ" (0.25 µm)
Nickel on Shell)
–04BJ2 = BNC
Bulkhead Jack
(30 µ" (0.76 µm)
Nickel on Shell)
–07BJ1 = SMB
Bulkhead Jack (30 µ" (0.76 µm)
Gold flash on Shell)
–01BJ1 = SMA
Straight Bulkhead Jack
–01SB1 = SMA
Straight Bulkhead Jack, Sealed
–01SR1 = SMA
Straight Bulkhead Jack, Sealed,
Reversed Polarity
–01BR1 = SMA
Reversed Polarity
END OPTIONS
–SING = Single Ended
(End 2 Callout)
XXXXXX = Stripped & Tinned
(End 2 Callout)
B
A
C
STRIPPED & TINNED
(Dimensions in mm)
–05BJ3 = TNC
Bulkhead Jack
(10 µ" (0.25 µm)
Nickel on Shell)
–06BJ2 = N Type
Bulkhead Jack
(30 µ" (0.76 µm)
Nickel on Shell)
WWW.SAMTEC.COM
CALLOUT
–303030
–303040
–403030
–403040
–404040
A
3.0
3.0
4.0
4.0
4.0
B
3.0
3.0
3.0
3.0
4.0
C
3.0
4.0
3.0
4.0
4.0
Both center conductor and
braid shield are stripped,
only the center
conductor is tinned.
RF174-03SP1-04BJ3-0200 . 价格&库存
很抱歉,暂时无法提供与“RF174-03SP1-04BJ3-0200 .”相匹配的价格&库存,您可以联系我们找货
