SD CONNECTOR
LC
P
-G
F
40
KA
JST
A
Specifications –––––––––––––––––––
• Current rating: 0.5A AC, DC
• Voltage rating: 5V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/50m Ω max. (signal part)
After environmental testing/80m Ω max.
(signal part)
• Insulation resistance:
1,000M Ω min.
• Withstanding voltage: 500V AC/minute
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Designed for the SD (secure digital)
memory card. Also applicable to the MMC
(multi-media card).
• Push-push mechanism
• Card-detection switch
• Static electricity shielding
PC board layout
9.75 ±0.05
8.05 ±0.05
5.0±0.05
18.0 ±0.05
+0.1
2-φ3.2 0
29.5 ±0.05
+0.1
2-φ1.1 0
13.0 ±0.05
2.5 ±0.05
8.0 ±0.05
13.5 ±0.05
18.0 ±0.05
22.0±0.05
2.3±0.05
9.375±0.05
+0.1
14-φ0.9 -0
11.5±0.05
13.5 ±0.05
±0.05
13.9 ±0.05
14.1±0.05
14.5 ±0.05
13.7
4.4
Connector
Model No.
Q'ty / box
SD-C-9BND-P23-332
60
30.5
Material and Finish
(6.5)
PC board surface
32.2
(3.15)
Position of card center
Housing: LCP, UL94V-0
Cover: LCP, UL94V-0
Guide: LCP, UL94V-0
Signal contact: Phosphor bronze, nickel-undercoated, gold-plated
Write protect switch: Phosphor bronze, nickel-undercoated, gold-plated
Terminal: Phosphor bronze, nickel-undercoated, gold-plated
Card detection switch: Phosphor bronze, nickel-undercoated, gold-plated
Joint rod: Kovar
Spring: SWPB, nickel-plated
GND contact: Phosphor bronze, tin-plated (reflow treatment)
Shaft: Brass
5.65
RoHS compliance
1
很抱歉,暂时无法提供与“SD-C-9BND-P23-332”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 60+38.8624060+5.02338
