SEI-115-02-G-S-E
SEI-115-02-G-S-E
    SAMTEC(申泰)
    CONN SPRING MOD 15POS SMD
SEI-115-02-G-S-E 数据手册
F-224 WEB SEI–110–02–GF–S–E–TR SEI–120–02–GF–S SIBF–05–F–S–AD (1.00 mm) .0394"(SEI) (1.27 mm) .050"(SIBF) SIBF–25–F–S–AD SIBF–10–F–S–AD SEI, SIBF SERIES ONE-PIECE INTERFACE SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?SEI or see www.samtec.com?SIBF Insulator Material: SEI = Liquid Crystal Polymer SIBF = Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: SEI = Au over 50 µ" (1.27 µm) Ni SIBF = Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: SEI = 2.3 A per pin (1 pin powered) SIBF = 2.5 A per pin (1 pin powered) Operating Temp Range: -55 °C to +125 °C Mating Force: SEI = 50 g (0.49 N) per contact Voltage Rating: SEI = 250 VAC SIBF = 155 VAC Cycles: SEI = 100 min Contact Deflection: SEI = (0.46 mm) .018" nominal RoHS Compliant: Yes PROCESSING Lead-Free Solderable: Yes SMT Lead Coplanarity (SEI): (0.10 mm) .004" max (05-25) (0.15 mm) .006" max (30)* *(.004" stencil solution may be available; contact ipg@samtec.com) SMT Lead Coplanarity (SIBF): (0.10 mm) .004" max (05-20) (0.15 mm) .006" max (25)* *(.004" stencil solution may be available; contact ipg@samtec.com) NO. OF 1 POSITIONS SEI S –G 05, 10, 15, 20, 25, 30 = 10 µ" (0.25 µm) Gold –GF (Standard sizes) = 3 µ" (0.08 µm) Gold flash No. of positions x (1.00) .03937 + (0.41) .016 INSERT OPTION ALIGNMENT OPTION Leave blank for Short Version (No screw down inserts or holes) Leave blank for no Alignment Pin OTHER OPTION –TR = Tape & Reel –AT –FR = Alignment Pin Top Side = Full Reel Tape & Reel = #2-56 x 1/16" = Alignment Pin (must screw thread Bottom Side order max. quantity per reel; (0.89) = 2.00 mm .035 Contact x 0.40 mm DIA (1.27) Samtec screw thread .050 for (4.32) (1.27) quantity .170 .050 breaks) –E –AB –M (6.10) (4.95) .240 .195 01 SHORT VERSION (0.31) .012 (1.65) .065 ((No. of positions-1) x (1.00) .03937) + (7.62) .300 (1.27) .050 (0.15) .006 (0.46) .018 –AT OPTION (4.32) .170 (0.89) .035 DIA –AB OPTION (3.43) .135 SIBF Threaded Insert (2) INSERT OPTIONS NO. OF POSITIONS PLATING OPTION –F For complete scope of recognitions see www.samtec.com/quality S = Flash Gold, Matte Tin on tail –05, –10, –20, –25 RECOGNITIONS FILE NO. E111594 PLATING OPTION 02 OPTION –AD = Top & Bottom Alignment Pin No. of positions x (1.27) .050 + (0.43) .017 (6.25) .246 (1.27) .050 ALSO AVAILABLE (7.50) .295 (MOQ Required) • Additional positions • Top or bottom side only alignment pin (0.70) .028 (4.00) .158 (3.00) .118 No. of positions x (1.27) .050 - (3.81) .150 (1.00) .040 –AD OPTION WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
SEI-115-02-G-S-E 价格&库存
很抱歉,暂时无法提供与“SEI-115-02-G-S-E”相匹配的价格&库存,您可以联系我们找货
