Han® Q High Density
Size 3 A
~50 V / ‒120 V 6.5 A
Number of contacts
21
Part number
Identification
Male insert (M) Female insert (F)
Drawing
Dimensions in mm
Crimp terminal
Order crimp contacts
separately
M
09 12 021 3001
09 12 021 3101
F
Identification
Part number
Drawing
Dimensions in mm
Insertion / removel tool
for D-Sub crimp contacts
09 99 000 0368
Han® Data Sheet 0730
Han® Q High Density
Features
Technical characteristics
Inserts
• Heavy duty connector for D-Sub signal contacts
Number of contacts
Electrical data
acc. to EN 61 984
Rated current
Rated voltage AC
Rated voltage DC
Rated impulse voltage
Pollution degree
• Suitable for all Han® 3 A hoods/housing types:
Standard (metal, plastic), EMC, INOX, M and
HPR
• High contact density at small foot print
• Easy handling of signal connectors in industrial
environment
Insulation resistance
Material
Limiting temperatures
Mechanical working life
- mating cycles
• One preleading contact
21
6.5 A ~50 V / ‒120 V 0.8 kV 3
6.5 A
~50 V
‒120 V
0.8 kV
3
≥ 1010 Ω
polycarbonate
-40 °C ... 125 °C
according to performance level
of used contacts
Contacts
Current Carrying Capacity
The current carrying capacity of the connectors is limited by the
thermal load capability of the contact element material including
the connections and the insulating parts. The derating curve
is therefore valid for currents which flow constantly (non-intermittent) through each contact element of the connector evenly,
without exceeding the allowed maximum temperature.
Measuring and testing techniques according to
DIN EN 60 512-5
Operating current (A)
Material
Surface
- selectively gold plated
Crimp termination
- mm²
- AWG
① wire gauge: 0.14 mm²
② wire gauge: 0.25 mm²
③ wire gauge: 0.5 mm²
stamped contacts
stamped contacts
turned contacts
0.09 mm² ... 0.56 mm²
28 ... 20
Hoods/Housings
Detailed information and further hoods/housings types see catalog
"Industrial Connectors Han®", chapter 31
Plastic hoods/housings
Material
Flammability acc. to UL 94
Degree of protection
acc. to DIN EN 60 529
for coupled connector
Metal hoods/housings
Material
Ambient temperature (°C)
copper alloy
polycarbonate
V0
IP 67
zinc die-cast
IP 44
IP 67 is achieved with seal
screw 09 20 000 9918
Han
Q High Density Contacts
Contacts
Identification
Wire gauge Part number
(mm²)
Male contact Female contact
Drawing
Dimensions in mm
Individual contacts,
turned
Performance level 1
0.09-0.25
0.13-0.33
0.25-0.52
09 67 000 7576
09 67 000 5576
09 67 000 8576
09 67 000 7476
09 67 000 5476
09 67 000 8476
0.09-0.25
0.25-0.56
09 67 000 7176
09 67 000 8176
09 67 000 7276
09 67 000 8276
Wire gauge
0.09-0.25 mm²
0.13-0.33 mm²
0.25-0.52 mm²
AWG 28-24
AWG 26-22
AWG 24-20
Ø*
Stripping length
1.7
1.7
1.7
4 mm
4 mm
4 mm
Ø*
Stripping length
1.02
1.52
2.5 mm + 0.5
2.5 mm + 0.5
Ø*
Stripping length
1.02
1.52
2.5 mm + 0.5
2.5 mm + 0.5
Ø*
Stripping length
1.02
1.52
2.5 mm + 0.5
2.5 mm + 0.5
stamped
Performance level 1
Wire gauge
0.09-0.25 mm²
0.25-0.56 mm²
AWG 28-24
AWG 24-20
500 pieces/reel
Performance level 1
Unrolling left
0.09-0.25
0.25-0.56
09 67 000 7166
09 67 000 8166
09 67 000 7266
09 67 000 8266
Wire gauge
0.09-0.25 mm²
0.25-0.56 mm²
AWG 28-24
AWG 24-20
10,000 pieces/reel
Performance level 1
Unrolling left
0.09-0.25
0.25-0.56
09 67 000 7156
09 67 000 8156
09 67 000 7256
09 67 000 8256
Wire gauge
0.09-0.25 mm²
0.25-0.56 mm²
AWG 28-24
AWG 24-20
HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp
Phone: +49 5772 47-97100 | Fax: +49 5772 47-495
Internet: www.HARTING.com | E-Mail: electric@HARTING.com
*) Ø = max. isolation diameter
2012-11-12
很抱歉,暂时无法提供与“09 12 021 3101”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+71.56389
- 3+70.13720
- 5+68.73133
- 国内价格 香港价格
- 1+118.966471+15.43580
- 10+105.0318910+13.62780
- 20+100.7644220+13.07410
- 50+95.2776850+12.36220
- 100+91.09731100+11.81980
- 150+88.74585150+11.51470
- 200+87.00403200+11.28870
- 国内价格
- 10+74.96297
- 20+73.08848
- 40+71.96378
- 国内价格 香港价格
- 1+150.936401+19.58388
- 10+128.2959410+16.64630
- 100+109.05985100+14.15043
- 500+97.36301500+12.63277
- 1000+92.722311000+12.03065
