09 06 048 0504
09 06 048 0504
    HARTING(浩亭)
    HARTING - 09 06 048 0504 - Connector Backshell, Housing, Connector Types F, H and MH, Thermoplastic ...
09 06 048 0504 数据手册
Directory chapter 20 Page Summary of shell housings and accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . 20.02 Shell housing C . . . . . . . . . . . . . . . . . . . . . . . . . . 20.04 Shell housing A . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20.08 Shell housing B . . . . . . . . . . . . . . . . . . . . . . . . . 20.10 Shell housing D 15 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20.14 Open hood G . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20.17 Junction element O . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20.17 Shell housings D 20/2 and D 20/4 . . . . . . . . . . . . . 20.18 EMC housing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20.24 Shell housings D 20/2 and D 20/4 metallised. . . . . 20.25 Shell housings D 20 metal . . . . . . . . . . . . . 20.28 Electronic connectors in Heavy Duty Housings . . . . . . . . . . . . . . . . . . . . . . . . . 20.30 Application examples . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20.32 Shell housings Shell housings 20 . 01 Summary shell housings and accessories Appropriate connectors in shell housings Types B, C, D, E Type F Types F, H, MH Types E, F, H, MH Check list: How to order shell housings and accessories. Types F, H, MH … 9968 The Part No. is stated. … 9930 Shell housings Cable insert C A B G O 09 02 064 0501 09 02 064 0502 09 03 096 0501 09 05 048 0501 09 06 048 0501 09 06 048 0401 09 06 048 0402 09 06 048 0503 09 06 048 0504 09 06 048 0505 09 06 000 9957 09 06 000 9968 °09 06 000 9930° 09 02 000 9910 09 02 000 9911 09 06 000 9914 09 06 000 9915 Insert for LED 09 06 000 9917 Locking lever 09 02 000 9902 09 02 000 9903 Locking screws 09 02 000 9909 M 2.5 x 16 M 2.5 x 00 09 02 000 9909 M 2.5 x 16 M 2.5 x 00 09 02 000 9909 M 2.5 x 16 M 2.5 x 00 M 2.5 x 12 M 2.5 x 00 09 02 000 9909 M 2.5 x 16 M 2.5 x 00 M 2.5 x 22 Supplied with the interface connector I C Order 2 pieces, in some cases each with different Part Nos. for left and right hand Order 2 sets ° order 2 pieces for fixing elements with male connectors for interface connectors U for interface connectors I Fixing brackets Supplied with the shell housing 09 06 000 9913 09 06 000 9919 09 06 000 9926 M 2.5 x 20 M 2.5 x 00 09 06 000 9926 M 2.5 x 20 M 2.5 x 00 09 06 000 9955 M 2.5 x 26 Supplied with the shell housing Supplied with the shell housing Supplied with the shell housing 09 06 000 9926 M 2.5 x 20 M 2.5 x 00 A B B B 09 02 000 9919 09 06 000 9901 09 02 000 9920 09 06 000 9902 09 06 000 9907 09 06 000 9966 09 06 000 9908 09 06 000 9967 09 06 000 9907 09 06 000 9966 09 06 000 9908 09 06 000 9967 09 06 000 9907 09 06 000 9966 09 06 000 9908 09 06 000 9967 09 02 000 9921 09 02 000 9922 09 06 000 9905 09 06 000 9906 09 06 000 9909 09 06 000 9910 09 06 000 9909 09 06 000 9910 09 06 000 9909 09 06 000 9910 for 19” racks Shell housings for male connectors Multiple fixing left Single fixing left right right B B 09 06 000 9933 09 06 000 9933 only … 9930 09 06 000 9933 09 06 000 9933 for female connectors Multiple fixing left right Fixing brackets for inverse male connectors on pcb R R1 R 32 09 02 000 9953 09 02 000 9954 Distance fixing brackets for piggyback connectors Type D top Type E bottom Type F top bottom 20 . 02 09 04 000 9907 09 04 000 9906 09 06 000 9936 09 06 000 9937 09 04 000 9907 09 04 000 9906 09 06 000 9936 09 06 000 9937 Protection strip 09 06 000 9929 Protection and fixing strip 09 06 001 9909 for 20 mm shell housing for 20 mm shell housing Female connectors Male connectors Detailed system description see chapter 00 Summary shell housings and accessories Appropriate connectors in shell housings Types F, H, MH Types F, H, MH D 15 D 20 Types F, H, MH Types F, H, MH Check list: How to order shell housings and accessories. The Part No. is stated. Shell housings 09 06 048 0515 09 06 948 0521 09 06 948 0522 09 06 000 9988 09 06 000 9989 09 06 900 9988 09 06 000 9986 09 06 000 9987 09 06 900 9986 09 06 900 9987 09 06 000 9926 M 2,5 x 16 M 2,5 x 00 Supplied with the shell housing Supplied with the shell housing Supplied with the shell housing B B B B 09 06 000 9907 09 06 000 9966 09 06 000 9907 09 06 000 9966 09 06 000 9995 09 06 000 9997 09 06 900 9907 09 06 900 9966 09 06 900 9995 09 06 900 9997 09 06 900 9997 09 06 000 9908 09 06 000 9967 09 06 000 9996 09 06 000 9998 09 06 900 9908 09 06 900 9967 09 06 900 9996 09 06 000 9909 09 06 001 9934 09 06 900 9909 09 06 901 9934 09 06 000 9910 09 06 001 9935 09 06 900 9910 09 06 901 9935 09 06 001 9909 09 06 001 9909 Insert for LED Order 2 pieces, in some cases each with different Part Nos. for left and right hand Locking screws Order 2 sets for fixing elements with male connectors D 20 metal 09 06 048 0521 09 06 048 0522 Cable insert Locking lever D 20 metallised 09 06 848 0550 09 06 848 0551 Supplied with the shell housing for interface connectors U for interface connectors I Fixing brackets for 19” racks left right Single fixing left right 09 06 000 9908 09 06 000 9967 09 06 000 9909 09 06 000 9910 09 06 900 9996 09 06 901 9924 09 06 901 9925 Shell housings for male connectors Multiple fixing B for female connectors Multiple fixing left 09 06 000 9933 right 09 06 000 9933 Protection and fixing strip for 20 mm shell housing 20 . 03 Female connectors Male connectors Detailed system description see chapter 00 Shell housing C for types B, C, D, E and har-bus® 64 1 Shell 1x 2 Cover 1x 3 Blinding plate 1x 4 Cable tie 1x 5 Blinding piece 2x 6 Grounding plate 1x 7 Screw BZ 2.2 x 9.5 DIN ISO 1481 er t d un bl ca Ro g ers lev n cki Lo 2x 3 ws cre 2x 2x gs 5 8 Screw a) BZ 2.9 x 6.5 DIN ISO 1482 ns ei kin oc L 4 3x 9 )0 b), c), d) BZ 2.9 x 13 DIN ISO 1483 3x (10 6 5 (15 1 7 1 50 02 0 64 0 mm ) mm 09 02 4 06 02 05 2a 7 2b ale eB nn Cr fem p m ter im Shell housings le C pe a fem Ty le eD a fem c Cr nal Sol 2c l ina 90 term (20 0 m) m nal rmi te der tor l ina Sol rm p te Crim 2d 8 Typ r cto ne ctor n co ne ale con m fe ale fem p Crim l ina Sol nal rmi te der term E ® 64 ype bus T 20 r. ha 04 Moulding material: thermoplastic resin, glass-fibre filled, UL 94-V0 01 05 rmi te imp ec n on c der tor ne m l Typ n co 5 0 m) 01 05 ina to ec co 8 04 90 (15 r 3 6 09 Separate accessories for housings Fitting female connectors Flat cable access Housing parts supplied Shell housing C for types B, C, D, E and har-bus® 64 I Identification Shell housing C for female connectors type B I Part No. II Drawing III Dimensions in mm 10 mm 09 02 064 0501 Type B 15 mm 09 02 064 0502 Type B Shell housing C for female connectors types C, D 15 mm 09 03 096 0501 Type C Shell housing C for female connectors type E, har-bus® 64 III Type D 20 mm 09 05 048 0501 Shell housings II Type E, har-bus® 64 Blanking pieces Inserts see page 20.07 Grounding plate Cable tie 1) BZ 2.2 x 9.5 DIN ISO 1481 Possible access for flat cable (18 x Ø 1.27). Remove the blanking piece. 20 . 05 Shell housing C I III IV Accessories Identification Part No. II Drawing Dimensions in mm Locking lever for shell housing C I left 09 02 000 9902 right 09 02 000 9903 Shell housing C left right Male connector type B, C, D, E Fixing brackets C for male connectors Multiple fixing II left 09 02 000 9919 Shell housing C left right Male connector type B, C, D, E right 09 02 000 9920 Single fixing M 2.5 x 16 DIN EN ISO 7045 III Shell housings left 09 02 000 9921 Shell housing C left right 09 02 000 9922 right Male connector type B, C, D, E Fixing brackets R for inverse male connectors on pcb’s IV 20 . 06 M 2.5 DIN EN ISO 4036 for 19“ racks according to DIN EN 60 297, part 3-101 M 2.5 x 16 DIN EN ISO 7045 R1 09 02 000 9953 R 32 09 02 000 9954 Shell housing C M 2.5 DIN EN ISO 4036 Male connector type Q, R See application example 4, chapter 01 BZ 2.2 x 9.5 DIN ISO 7049 Shell housing C II I Accessories Identification Part No. Drawing Dimensions in mm for shell housing C 09 02 064 0501 09 02 000 9910 Supplied with: Round cable insert 1x Blinding piece A 1x Blinding piece B 1x Cable tie 1x max. ø 6.5 Round cable insert 2 x ø 6.5 Cable tie Round cable insert 2 x ø 11.5 for shell housings C 09 02 064 0502 09 03 096 0501 09 05 048 0501 09 02 000 9911 max. ø 11.5 I Cable tie Shell housings Supplied with: Round cable insert 1x Blinding piece A 1x Blinding piece B 1x Cable tie 1x II 09 02 000 99091) M 2.5 x 16 DIN EN ISO 7045 Locking screws Shell housing C Interface connector U 20 . 07 1) Order 2 pieces for one shell housing Shell housing A for type F 5 6 g kin oc 4 7 ws cre 9 )0 nn o ec al fem e Typ (15 r cto e 06 0 48 0 mm F 3 1a 7 Cr t mp i n al fem 06 9 )0 (15 r cto e nn on ati n 5 Shell housings 6 L 1c g kin oc fem Typ ale s ew r c s n co 2x 02 ) ne (15 er m pt 1x 0 48 1 0 2x 1c Shell 1x 2c Cover 1x 4 Cable clamp 2x 5 Screw BZ 2.9 x 9.5 DIN ISO 1481 4x 6 Hexagonal nut M3 DIN EN ISO 4032 4x 7 Screw M3 x 12 DIN EN ISO 1207 4x eF 7 rim mm 0 09 4 80 4 60 r cto 2c n tio ina 5 Screw BZ 2.9 x 9.5 DIN ISO 1481 7 Screw M3 x 12 DIN EN ISO 1207 4x 6 4 7 1x 6 Hexagonal nut M3 DIN EN ISO 4032 4x 7 C 4 Cable clamp 1b Casing shell 1b rim 1x mm eF p y T mi 3 Blinding piece 40 s o ec 1b 2x ws cre ng cki Lo er pt 2x 7 Screw M3 x 12 DIN EN ISO 1207 2x 6 6 7 1a Casing shell 6 Hexagonal nut M3 DIN EN ISO 4032 2x tio ina erm 1 50 s L 1a 2x 6 C 20 . 08 Moulding material: thermoplastic resin, glass-fibre filled, UL 94-V0 Separate accessories for housings Fitting female connectors Cable access Housing parts supplied Shell housing A for type F III I Identification Part No. IV II Drawing Dimensions in mm Shell housing A Side entry 15 mm 09 06 048 0501 I Flat cable entry Top entry II 15 mm 09 06 048 0401 15 mm 09 06 048 0402 Cable clamp incl. screw 09 00 000 5329 See à + Ä on page 20.08 Fixing brackets A for male connectors for 19” racks according to DIN EN 60 297, part 3-101 Shell housings Identification recess 12.2 x 64.8 Shell housing A left 09 06 000 9901 Male connector type F Multiple fixing III right 09 06 000 9902 left 1) Single fixing right nut and screw not supplied with bracket left 09 06 000 9905 Male connector type F IV right 09 06 000 9906 left right 20 . 09 Shell housing B for types F, H and MH 1 Shell 1x 2 Cover 1x 3 Blinding plate 1x 4 Cable clamp 2x 5 Screw BZ 2.9 x 9.5 DIN ISO 1481 4x 6 Blinding piece 2x 7 Grounding plate 1x D LE r . fo g e. s er t Ins er t ns ei l ab c nd u Ro 8 Screw a) BZ 2.9 x 9.5 DIN ISO 1483 3x b), c) BZ 2.9 x 13 DIN ISO 1483 g kin oc ers lev L 3x 5 3 2x x s2 ew cr gs 6 n cki 0 m) 6 8 04 90 1 (20 0 m) 90 (20 4 04 05 m 7 6 03 05 m 4 5 6 8 04 90 (15 Lo 6 8 04 0 m) m 2a 2b rt Shell housings tor ale e Typ F fem ec onn c ge Ca tor ale Typ fem n con 8 S nal i term le ma p ec eH p Crim e old 2c l na i erm m cla H eM s Fa l er pt e ac erf na mi eF int p Ty l ina erm pt rim co fe Typ ton im Cr r cto e nn C 20 . 10 Moulding material: thermoplastic resin, glass-fibre filled, UL 94-V0 n co tor c ne 05 05 I Separate accessories for housings Fitting female connectors Fitting male connectors Flat cable access Housing parts supplied Shell housing B for types F, H and MH II III Identification Part No. I Drawing Dimensions in mm Shell housing B 15 mm 09 06 048 0503 II 20 mm 09 06 048 0504 III 20 mm 09 06 048 0505 Inserts see page 20.13 Blanking piece Grounding plate Shell housings I 1) Possible access for flat cable (18 x ø 1.27). Remove the blanking piece 20 . 11 Shell housing B I III II Accessories Identification Part No. Drawing Dimensions in mm Locking lever for shell housing B 09 06 048 0503 09 06 000 99131) I Shell housing B 1) Order 2 pieces for one shell housing left 09 06 000 9913 09 06 000 99261) right Male connector type F, H, MH right 09 06 000 9919 Locking screws II left M 2.5 x 20 09 06 048 0504 09 06 048 0505 Shell housing B Male connector type F, H, MH 1) Order 2 pieces for one shell housing M 2.5 DIN EN ISO 4036 Fixing brackets B for male connectors for 19” racks according to DIN EN 60 297, part 3-101 Shell housings Multiple fixing without nut with nut M 2.5 DIN 562 left 09 06 000 9907 Shell housing B left right 09 06 000 9908 right Male connector type F, H, MH left 09 06 000 9966 right 09 06 000 9967 Single fixing without nut III 20 . 12 left 09 06 000 9909 right 09 06 000 9910 Shell housing B left right Male connector type F, H, MH Shell housing B II IV III I Accessories Identification Part No. Drawing Dimensions in mm Fixing brackets B for female connectors for 19” racks according to DIN EN 60 297, part 3-101 Multiple fixing 09 06 000 99331) I 1) Order 2 pieces for one female connector M 2.5 x 8 DIN EN ISO 12072) 2) Female connector type F nut and screw not supplied with fixing brackets Round cable insert 2 x ø 10 for shell housings B 09 06 048 0503 09 06 048 0504 09 06 000 9914 Supplied with: Round cable insert 1x Blinding piece 1x Round cable insert 2 x ø 12.5 II for shell housing B 09 06 048 0505 09 06 000 9915 Shell housings Supplied with: Round cable insert 1x Blinding piece 1x III for shell housing B 09 06 048 0505 09 06 000 9917 pcb 35.5 x 17 x 1.5 Insert for LED Protection strip IV 09 06 000 9929 Used with shell housings type B for front side access 09 06 048 0504 09 06 048 0505 Male connector type F 20 . 13 Shell housing D 15 for types F, H and MH 3 cal ni cha Me g idin gu ws cre und gro gs g kin tin c a m Lo irst 4 2 5 ion ect n con 2x f and 5 51 9 )0 1 (15 06 0 48 0 mm 3 6 1 4 7 6 ale F pe tor c ne n co fem Ty r r te Shell housings e p Crim ld So nal l na mi le ma ec n on c fe eH Typ i term mp la ec g Ca tor le ma tor c e nn co l ina p im 2 Blinding plate 1x 3 Cable tie 2x 4 Blinding piece 2x 5 Hexagonal nut M2.5 DIN EN ISO 4035 2x 6 Screw BZ 2.9 x 9.5 DIN ISO 1481 2x 7 Screw M2.5 x 12 DIN EN ISO 7045 2x Typ ton Cr 2x fe H eM s Fa m ter 1 Casing shell F pe e ac erf n co tor c ne I int Ty Separate accessories for housings 20 . 14 l er pt im Cr na mi Moulding material: thermoplastic resin, glass-fibre filled, UL 94-V0 Fitting female connectors Fitting male connectors Housing parts supplied Shell housing D 15 for types F, H and MH II I Identification Part No. Drawing III Dimensions in mm Shell housing D 15 I Cable tie 2 x Blanking pieces 2 x BZ 2.2 x 9.5 DIN ISO 1481 15 mm 09 06 048 0515 M 2.5 DIN EN ISO 4 036 Shell housings M 2.5 x 12 DIN EN ISO 7045 Mechanical guiding and first mating ground connection II 09 06 000 9961 Locking screws Shell housing D 15 III 09 06 000 99261) Male connector type F, H, MH 1) Order 2 pieces for one shell housing M 2.5 DIN EN ISO 4 036 20 . 15 Shell housing D 15 I II III Accessories Identification Part No. Drawing Dimensions in mm Fixing brackets B for male connectors for 19” racks according to DIN EN 60 297, part 3-101 Shell housing D 15 Multiple fixing left 09 06 000 9907 without nut I with nut M 2.5 DIN 562 left right 09 06 000 9908 right Male connector type F, H, MH left 09 06 000 9966 right 09 06 000 9967 Single fixing without nut left right 09 06 000 9910 right Male connector type F, H, MH Shell housings II Shell housing D 15 left 09 06 000 9909 Fixing brackets B for female connectors for 19” racks according to DIN EN 60 297, part 3-101 Multiple fixing III 20 . 16 1) Order 2 pieces for one female connector 09 06 000 99331) Female connector type F M 2.5 x 8 DIN EN ISO 12072) 2) nut and screw not supplied with fixing brackets Open hood G, junction element O, locking lever II Identification Open hood G Part No. I for types E, F, H and MH, for applications A B C Supplied with: Open hood 1x Locking screw 2x (09 06 000 9958) Cable tie 1x Screw 2x Open hood G 09 06 000 9957 III IV Drawing 2 x BZ 2.2 x 9.5 DIN ISO 1481 I Dimensions in mm Cable tie 1 x II for types E, F, H and MH, for application A B C C U element Junction element O for type F IV Supplied with: Junction element 2x Cable tie 2x Screw 2x Screw M2.5 x 20 2x 09 06 000 9968 Locking lever for type F, H and MH Female connector Female connector I element Male connector Fixing brackets B 2 x M 2.5 x 20 DIN EN ISO 7045 Shell housings 09 06 001 9939 2 x BZ 2.2 x 9.5 DIN ISO 1481 Supplied with: Open hood 1x Pre-assembled, undetachable locking screw 2x Cable tie 1x Screw 2x M 2.5 x 8 DIN EN ISO 12072) 09 06 000 99301) III Female connector M 2.5 DIN EN ISO 4 0322) M 2.5 x 8 DIN EN ISO 12072) 09 06 000 99111) Female connector type F 2) 1) Order 2 pieces for one female connector M 2.5 DIN EN ISO 4 0322) nut and screw not supplied with locking levers 20 . 17 Shell housing D 20/2 for types F, H and MH m) b pc 2.5 m ED L x 1 . for 5 . g (79 e. ED rL . fo .5 d: ire u req s er t r . fo D LE p g e. .5 79 ( cb 2 x1 g e. ) m m Ins for . .g se D LE er t Ins nd u Ro t Fla 1 Shell 1x 2 Cover 1x 3 Screw (09 06 000 9993) 2x 4 Locking washer 2.3 DIN 6799 2x 5 Cable clamp 2x 6 Blinding piece 2x 7 Screw BZ 2.2 x 9.5 DIN ISO 7049 er t ins le ab c er t ns ei 4 7 bl ca 3 3 5 4 1 6 6 7 1 52 8 0 21 4 05 60 9 0 948 0 ) 06 mm 09 (20 mm) (20 7 Shell housings r cto ne on c ale lde So 2 mp la ec g Ca or ect ton s Fa n on c ale eH Typ rm r te p te Crim fem Typ fem or ect er pt l na mi im Cr n on c ale 20 . 18 l ina al rmin fem H x eM tor ts 2 p c y e e T n k con brac e l g Ma Fixin g din Co 5 eF 10x pcb Moulding material: thermoplastic resin, glass-fibre filled, UL 94-V0 g din Co Separate accessories for housings Fitting female connectors Fitting male connectors Fixing brackets Housing parts supplied Shell housing D 20 Fitting female connectors Part-No. Type D 20/2 D 20/4 D 20 metal D 20 metal HF X X X X X X 09 06 2__ _823 F with open solder lugs X 09 06 2__ _853 F with closed solder lugs X 09 06 248 3201 F moulding for crimp contacts X 09 06 215 2871 H for faston X X X 09 06 015 2813 H with cage clamps X X X 09 06 231 2881 MH moulding for crimp contacts X X X X 09 06 2__ _853 Order example: 7 = performance level 3 6 = performance level 2 2 = performance level 1 32 = 32 contacts 48 = 48 contacts 1) Shell housings Technical characteristics D 20/2 D 20/2 metallised1) D 20/4 D 20/4 metallised1) D 20 metal D 20 metal HF Part No. 09 06 048 0521 09 06 948 0521 09 06 048 0522 09 06 948 0522 09 06 848 0550 09 06 848 0551 Material Polycarbonate Polycarbonate Polycarbonate Polycarbonate Zinc alloy Zinc alloy Surface none nickel/copper none nickel/copper nickel-plated nickel-plated Weight [g] 36 44 43 52 182 188 Cable entries side (2 x), top (2 x) side (2 x), top (2 x) side (4 x) side (4 x) side (2 x), top (2 x) side (2 x) top (2 x) Protection IP 20 IP 20 IP 20 IP 20 IP 20 IP 20 upper temperature limit is +105 °C 20 . 19 Shell housing D 20 for types F, H and MH I II III Identification Part No. Shell housing D 20/2 Dimensions in mm Order inserts separately Two side cable entries I Drawing Blanking piece 2 x 20 mm 09 06 048 0521 Shell housing D 20/4 Four side cable entries II Supplied with: Shell 1x Cover 1x Locking screw 2x Locking washer 2.3 2x Screw BZ 2.2x9.5 12x Blinding piece 3x Cable clamp 2x 20 mm 09 06 048 0522 Shell housings Inserts e. g. for LED* for 55 mm height 09 06 000 9986 pcb for 60 mm height 09 06 000 9987 pcb Round cable insert* 2 x ø 11 III 09 06 000 9988 Flat cable insert* 09 06 000 9989 20 . 20 * Fits D 20/2 Shell housing D 20 II III I Coding Identification Part No. Drawing Dimensions in mm Code comb for shell housing3) (can also be used as a blanking cover) I 09 06 000 9984 Coding pin3) II 1) 09 06 001 99051) Order 13 pieces per code comb Order 13 pieces per code comb Code comb for male connectors3) III 09 06 000 9985 Shell housings Mounting possibilities for the code comb in the shell housing D 20/2 2) Use the lower slot when coding the male connector with fixing brackets Mounting example A max. cable entry ø 14 mm to the top, see page 20.23 Mounting example B max. cable entry ø 14 mm to the bottom, see page 20.23 3) Fits D 20/2 and D 20/4 20 . 21 Shell housing D 20 Identification Part No. Drawing Dimensions in mm Mounting possibilities for code comb at the male connector with fixing brackets M 2.5 x 18 DIN EN ISO 1207 pcb M 2.5 Fixing brackets B for male connectors* for 19” racks according to DIN EN 60 297, part 3-101 Single fixing* left 09 06 000 9909 M 2.5 DIN EN ISO 4 036 Shell housing D 20 left right right 09 06 000 9910 without nut left 09 06 001 9934 right 09 06 001 9935 M 2.5 DIN 562 Multiple fixing* without coding at the fixing bracket without nut Shell housings without coding at the fixing bracket with nut M 2.5 DIN 562 left 09 06 000 9907 left 09 06 000 9966 with coding at fixing bracket1) with nut M 2.5 15 mm DIN 562 20 mm left 09 06 000 9995 09 06 000 9997 15 mm 20 mm right 09 06 000 9996 09 06 000 9998 fits female connectors and I element crimp 20 . 22 left M 2.5 DIN 562 Shell housing D 20 left 2) supplied with fixing 09 06 001 9909 * Fits D 20/2 and D 20/4 Specific coding between the fixing bracket and the pcb guiding rail. The guiding rail and corresponding coding pins are not scope of delivery 1) right right 09 06 000 9908 right 09 06 000 9967 Protection and fixing strip* for 20 mm shell housing Single fixing Shell housing D 20 right mounting examples with nut M 2.5 DIN 562 Shell housing D 20 Mounting examples Dimensions in mm Single fixing Multiple fixing or Shell housings or Mounting example A2) max. cable entry to the top Mounting example B max. cable entry to the bottom Separate accessories for housings Fitting female connectors 1) Specific coding between the fixing bracket and the pcb guiding rail 2) Max. cable entry (ø 14 mm) from the bottom with fixing brackets 09 06 901 9924/…9925 possible. See page 20.29. Fitting male connectors Fixing brackets Housing parts supplied 20 . 23 EMC housing EMC with HARTING connectors HARTING offers metallised D 20 housings and full metal housings for EMC connectors according to IEC 60 603-2. Its strong EMI characteristics and metallised fixing elements offers optimal shielding and grounding. The connection of the cable braid to different types of connector housings, as well as the influence of the connector itself on EMC characteristics of an instrument application, were analysed in regard to the shielding effectiveness against electromagnetic radiation. The shielded signal data lines of a railway application were carried via two eurocard pcb´s installed into a 19”-rack. The fixing of the cable braid was realised with different HARTING D 20 housings. The application including the connectors was then exposed to RF signals, transient bursts and electrostatic discharges. Shell housings The standard plastic housings showed minimal EMC performance. The EMC performance of metallised and full metal housings showed significant improvements. 20 . 24 One advantage of metallised housings is their reduced weight (40 grams compared to 180 grams of a full metal housing). Therefore, minimal interference is applied to the pcb in applications where strong vibration is occuring. The HARTING housings are comparatively light through the use of metallised plastic. The main advantages of a full metal housing are improved cable braid fixing, easy mounting and robustness. In general, one should keep in mind that an unshielded cable entry leads to loss of the shielding against electromagnetic interference. “A high-resistance interruption of the cable shield (e.g. by using “pigtails” via twisted stranded wires of the cable shield) may affect the EMC performance and therefore cause unacceptable effects to the electromagnetic environment.” These housings are applied in electronic installations of the railway vehicles of the GERMAN RAILWAY. They are also recommended for stationary installations of the GERMAN RAILWAY (see norm BN 74016, part 1 of December 1989). Shell housing D 20 metallised for types F, H and MH I Identification Part No. Shell housing D 20/2 metallised II Drawing Dimensions in mm Order inserts separately with two side cable entries Blanking piece 2 x I 20 mm 09 06 948 0521 Supplied with: see page 20.18 Shell housing D 20/4 metallised with four side cable entries II 20 mm 09 06 948 0522 Shell housings Supplied with: Shell 1x Cover 1x Locking screw 2x Locking washer 2.3 2x Screw KA 22x7.5 12x Blinding piece 3x Cable clamp 4x Metallised insert e. g. for LED* for 55 mm height 09 06 900 9986 pcb for 60 mm height 09 06 900 9987 pcb Metallised round cable insert* 2 x ø 11 * Fits D 20/2 metallised 09 06 900 9988 20 . 25 Shell housing D 20 metallised I II Coding Identification Part No. Drawing Dimensions in mm Metallised code comb for shell housing3) (can also be used as blanking cover) 09 06 900 9984 I Code pin3) 09 06 001 99051) 1) Order 13 pieces per code comb Order 13 pieces per code comb Metallised code comb for male connector3) II 09 06 900 9985 Shell housings Mounting possibilities for the code comb in shell housing D 20/2 metallised 2) 20 . 26 Use the lower slot when coding the male connector with fixing brackets Mounting example A max. cable entry ø 14 mm to the top, see page 20.23 Mounting example B max. cable entry ø 14 mm to the bottom, see page 20.23 3) Fits D 20/2 and D 20/4 metallised Shell housing D 20 metallised Identification Part No. Drawing Dimensions in mm Mounting possibilities for coding at the male connector with fixing brackets M 2.5 x 18 DIN EN ISO 1207 pcb M 2.5 Fixing brackets B metallised for male connectors* without nut with nut M 2.5 DIN EN ISO 4 036 Multiple fixing* without coding at fixing bracket without nut without coding at fixing bracket with nut M 2.5 DIN 562 left 09 06 900 9909 right 09 06 900 9910 left 09 06 901 9934 right 09 06 901 9935 left M 2.5 DIN EN ISO 4 036 left 09 06 900 9907 right 09 06 900 9908 left 09 06 900 9966 right 09 06 900 9967 right Shell housing D 20 left right M 2.5 DIN 562 Shell housing D 20 left with coding at fixing bracket1) with nut M 2.5 DIN 562 left 15 mm 09 06 900 9995 20 mm 09 06 900 9997 right 15 mm 09 06 900 9996 Protection and fixing* strip for 20 mm shell housing Single fixing fits female connectors and I element crimp 2) supplied with fixing 09 06 001 9909 * Fits D 20/2 and D 20/4 metallised Specific coding between the fixing bracket and pcb guiding rail 1) right Shell housings Single fixing* Shell housing D 20 mounting examples for 19” racks according to DIN EN 60 297, part 3-101 M 2.5 DIN EN ISO 4 036 20 . 27 Shell housing D 20 metal for types F, H and MH I Identification Part No. Shell housing D 20 metal I Supplied with: Shell with coding Cover Locking screw (hexagonal) M2.5 x 22 Screw (torx) M2.5 x 10 Earth screw M4 x 8 1x 1x 2x 09 06 848 0550 4x 2x Shell housings Shell housing D 20 metal HF with nickel-plated surface II Supplied with: Shell with coding and HF-sealing spring Cover with shielding plate Locking screw (hexagonal) M2.5 x 22 Screw (torx) M2.5 x 10 Earth screw M4 x 8 20 . 28 1x 1x 2x 4x 2x 09 06 848 0551 Drawing II Dimensions in mm Shell housing D 20 metal HF for types F, H and MH IV I V VII VI II Identification Part No. Drawing Fixing brackets B metallised for male connectors with nut M 2.5 DIN EN ISO 4 036 Dimensions in mm Shell housing D 20 for 19” racks according to DIN EN 60 297, part 3-101 Single fixing VIII III left I left 20 mm 09 06 901 9924 II right 20 mm 09 06 901 9925 right M 2.5 DIN EN ISO 4 036 Multiple fixing Shell housing D 20 with coding at fixing bracket with nut M 2.5 DIN 562 III left 20 mm 09 06 900 9997 IV right 15 mm 09 06 900 9996 V 09 06 800 9951 VI 09 06 800 9955 VII 09 06 800 9950 VIII 09 06 001 9906 left right Shell housings Blinding piece Cable clamp Cable grommet with strain relief Code pin Earth screw 09 06 800 9958 Order 13 pieces per code comb 20 . 29 Electronic connectors in heavy duty housings For applications where robust, high density, splash-proof connectors are required, e.g. in the automated control and industrial processing systems, HARTING have combined the proven reliability of DIN 41 612 connectors with standard Han® 24 B heavy duty hoods and housings, to bring forward a connector system with up to 96 ways and various contact plating thicknesses to suit the individual requirements. Advantages ● The combination enhances design flexibility, as it permits an identical wiring interface between the standard 19“ racking systems and the peripheral equipment. ● Simplified stock-holding, identical operating tools. Inserts Female 2 x 48 way type F female connectors with crimp contact elements see chapter 02 Male 2 x 48 way type F interface connectors I with crimp contact elements see chapter 02 Hoods and housings see catalogue "Heavy Duty Han® Connectors" chapter 30 size 24 B Degree of protection for hoods and housings: IP 65 Retaining frames For fixing the inserts into the housing. Alternative versions with pre-mating contacts and ground termination. Shell housings If the working voltages are in excess of 42 V (50 V) it is essential to use retaining frames which have pre-mating ground contacts. 20 . 30 Retaining frames II Identification Part No. I Drawing Dimensions in mm Retaining frame without contact elements 09 06 001 9904 I Retaining frame with 2 contact pins and ground termination 09 06 001 9902 Retaining frame with 2 contact sockets and ground termination 09 06 001 9903 Each retaining frame is supplied with 4 fixing screws for mounting the inserts and with 2 guide pins and sockets that provide mechanical protection for the contacts during mating and disconnection. These can also be used as a coding system to prevent cross plugging of adjacent connectors. Mounting example Shell housings II Connectors in the retaining frame with contact sockets Guide pin Ground termination Contact socket Guide sockets M 2.5 x 6 DIN EN ISO 1207 20 . 31 Retaining frame for types C and R is available with part no. 09 03 000 9911 Shell housings Notes 20 . 32
09 06 048 0504 价格&库存
很抱歉,暂时无法提供与“09 06 048 0504”相匹配的价格&库存,您可以联系我们找货
  • 1+126.09074
  • 15+124.52867
  • 50+122.22721
  • 100+120.31106
  • 250+118.22830
库存:140
09060480504
    • 10+116.4408210+15.10810
    • 100+105.55443100+13.69560
    • 250+100.76442250+13.07410
    • 500+97.01950500+12.58820
    • 1+184.911991+23.99218
    • 10+157.1416510+20.38900
    • 30+145.4193130+18.86804
    • 50+140.2722550+18.20021
    • 100+133.57946100+17.33183
    • 250+125.22380250+16.24769
    • 500+119.25374500+15.47308
    库存:6
