09 35 232 0423
09 35 232 0423
    HARTING(浩亭)
    Conn Power PL 4Power/1Ground POS Crimp ST Cable Mount 5 Terminal 1 Port
09 35 232 0423 数据手册
Han® PushPull Power 4/0 Plastic PushPull Han-Quick Lock® Han® PushPull, type acc. to IEC 61 076-3-118 Panel feed-through, 5-poles, 230/400 V, 16 A Features Technical characteristics • HARTING PushPull technology • Compact, space-saving design • Touch-proof • Panel feed-through: male - crimp termination - Han-Quick Lock® termination technology • 4 times coding without contact loss • NEW: Larger termination cross section for conductors 0.25 - 1.5 mm² Locking Mating face Degree of protection Number of contacts Electrical data acc. to DIN EN 61 984 Termination cross section Mating cycles Temperature range Housing material Flammability acc. to UL 94 Identification Part No. Han® PushPull Power 4/0 Panel feed-through 5-poles, 690 V / 16 A incl. bulkhead housing and male insert with crimp termination (Order crimp male contacts separately) 09 35 231 0331 with Han-Quick Lock® termination 0.5  … 2.5 mm² 0.25 … 1.5 mm² 09 35 232 0331 09 35 234 0331 Coding element 10 pieces each for device and cable side 02 56 enables 4 times coding without contact loss 09 35 000 6190 Drawing PushPull technology acc. to IEC 61 076-3-117 variant 14 acc. to IEC 61 076-3-118 IP 65 / IP 67 4 + PE 16 A 690 V 4 kV 3 0.25 – 2.5 mm² min. 500 -40 °C ... +70 °C Plastic, black V0 Dimensions in mm Han® PushPull Power 4/0 Plastic PushPull Han-Quick Lock® Han® PushPull, type acc. to IEC 61 076-3-118 Connector, 5-poles, 230/400 V, 16 A Features Technical characteristics • HARTING PushPull technology • Compact, space-saving design • Touch-proof • Cable side: female - crimp termination - Han-Quick Lock® termination technology Field-assembly without special tools • 4 times coding without contact loss • NEW: Larger termination cross section for conductors 0.25 - 1.5 mm² Locking Mating face Degree of protection Number of contacts Electrical data acc. to DIN EN 61 984 Termination cross section Mating cycles Temperature range Housing material Flammability acc. to UL 94 Identification Part No. Drawing PushPull technology acc. to IEC 61 076-3-117 variant 14 acc. to IEC 61 076-3-118 IP 65 / IP 67 4 + PE 16 A 690 V 4 kV 3 0.25 – 2.5 mm² min. 500 -40 °C ... +70 °C Plastic, black V0 Dimensions in mm Connector set, plastic incl. housing and female insert with crimp termination 9 – 13 mm clamp range Han® P crimp contacts order separately 09 35 231 0423 with Han-Quick Lock® termination 9 – 13 mm clamp range for termination cross section 0.5 - 2.5 mm² 09 35 232 0423 with Han-Quick Lock® termination 6.5 – 9.5 mm clamp range for termination cross section 0.5 - 2.5 mm² for termination cross section 0.25 - 1.5 mm² 09 35 232 0421 09 35 234 0421 Dust protection cover IP 40 09 35 002 5412 Protection cover IP 65 / IP 67 09 35 002 5411 Coding pins 09 35 000 6190 02 57 PushPull Han® PushPull Power 4/0 Han® PushPull, type acc. to IEC 61 076-3-118 variant 14 Accessories Identification Part No. BUCHANANcrimping tool Drawing Dimensions in mm 09 99 000 0001 Locator Han P® for crimping tool 09 99 000 0001 09 99 000 0329 Multiple crimping tool depth 09 99 000 0379 adjustment gauge Removal tool Han P® Wire gauge 0.5 - 1 mm2 ø 1.55 1.5 - 2.5 mm2 ø 1.80 09 99 000 0319 Coding pins for 4 times coding without contact loss 09 35 000 6190 Part No. Male contact Female contact Identification Drawing Dimensions in mm Crimp contacts Han® P silver plated for 0.5 mm² for 0.75 mm² for 1.0 mm² for 1.5 mm² for 2.5 mm² 09 35 000 6103 09 35 000 6203 09 35 000 6104 09 35 000 6204 09 35 000 6105 09 35 000 6205 09 35 000 6106 09 35 000 6206 09 35 000 6107 09 35 000 6207 Wire gauge Ø Stripping length for 0.5 mm² AWG 20 1.15 mm 6 mm for 0.75 mm² AWG 18 1.30 mm 6 mm for 1.0 mm² AWG 18 1.45 mm 6 mm for 1.5 mm² AWG 16 1.75 mm 6 mm for 2.5 mm² AWG 14 2.25 mm 6 mm 02 61
09 35 232 0423 价格&库存
很抱歉,暂时无法提供与“09 35 232 0423”相匹配的价格&库存,您可以联系我们找货
    • 1+222.22087
    • 12+211.10931
    • 25+206.89170
    库存:29
