09110012652
09110012652
    HARTING(浩亭)
    MODULE MALE 1POS SCREW
09110012652 数据手册
Product data sheet 09 11 001 2652 Han 1HC-sti-AX (350A,95-120mm2) Han 1HC-sti-AX (350A,95-120mm2) Part number 09 11 001 2652 Specification Han 1HC-sti-AX (350A,95-120mm2) HARTING eCatalogue https://b2b.harting.com/09110012652 Image is for illustration purposes only. Please refer to product description. Identification Category Inserts Series Han® HC Modular Identification 350 Version Termination method Axial screw termination Gender Male Details The vibration and shock resistance can only be met if the cables are fixed at an appropriate distance. Instructions for the spacing of strain relief can be found in the document in eCatalogue under the section Instructions. Technical characteristics Conductor cross-section 95 ... 120 mm² Wire outer diameter ≤19.5 mm Rated current 350 A Rated voltage 2,000 V Rated impulse voltage 12 kV Pollution degree 3 Insulation resistance >1010 Ω Contact resistance ≤0.2 mΩ Stripping length 19 ... 20 mm Tightening torque 14 Nm @ 95 mm² 16 Nm @ 120 mm² Limiting temperature -40 ... +125 °C Page 1 / 3 | Creation date 2024-04-13 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electric Stiftung & Co. KG | Wilhelm-Harting-Straße 1 | 32339 Espelkamp | Germany Phone +49 5772 47-97100 | electric@HARTING.com | www.HARTING.com Product data sheet 09 11 001 2652 Han 1HC-sti-AX (350A,95-120mm2) Technical characteristics Mating cycles ≥500 Vibration resistance Category 2 acc. to IEC 61373 Shock resistance Category 2 acc. to IEC 61373 Material properties Material (insert) Polycarbonate (PC) Polyamide (PA) Colour (insert) RAL 7032 (pebble grey) Material (contacts) Copper alloy Surface (contacts) Silver plated Material flammability class acc. to UL 94 V-0 RoHS compliant with exemption RoHS exemptions 6(a) / 6(a)-I: Lead as an alloying element in steel for machining purposes and in galvanised steel containing up to 0,35 % lead by weight / Lead as an alloying element in steel for machining purposes containing up to 0,35 % lead by weight and in batch hot dip galvanised steel components containing up to 0,2 % lead by weight 6(c): Copper alloy containing up to 4 % lead by weight ELV status compliant with exemption China RoHS 50 REACH Annex XVII substances Not contained REACH ANNEX XIV substances Not contained REACH SVHC substances Yes REACH SVHC substances Potassium 1,1,2,2,3,3,4,4,4-nonafluorobutane-1-sulphonate Lead California Proposition 65 substances Yes California Proposition 65 substances Lead Nickel Fire protection on railway vehicles EN 45545-2 (2020-08) Requirement set with Hazard Levels R26 Specifications and approvals Specifications IEC 60664-1 IEC 61984 UL / CSA UL 1977 ECBT2.E235076 Approvals DNV GL Page 2 / 3 | Creation date 2024-04-13 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electric Stiftung & Co. KG | Wilhelm-Harting-Straße 1 | 32339 Espelkamp | Germany Phone +49 5772 47-97100 | electric@HARTING.com | www.HARTING.com Product data sheet 09 11 001 2652 Han 1HC-sti-AX (350A,95-120mm2) Commercial data Packaging size 1 Net weight 145 g Country of origin Romania European customs tariff number 85359000 GTIN 5713140015982 ETIM EC000438 eCl@ss 27440205 Contact insert for industrial connectors Page 3 / 3 | Creation date 2024-04-13 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electric Stiftung & Co. KG | Wilhelm-Harting-Straße 1 | 32339 Espelkamp | Germany Phone +49 5772 47-97100 | electric@HARTING.com | www.HARTING.com
09110012652 价格&库存
很抱歉,暂时无法提供与“09110012652”相匹配的价格&库存,您可以联系我们找货
