98 42 937 0201
HARTING Han® GND
People | Power | Partnership
Han® GND
Han® GND - Mateable Potential Equalization
The new Han® GND series now enables pluggable grounding systems
Han® GND (Han® Ground) is the innovative HARTING solution for potential equalization. The new
connector series makes it possible to execute grounding systems in a pluggable design for the first time.
The use of connectors has been well-established in the electrical cabling of machines and systems
for many years. The advantage is quick and error-free commissioning. Potential equalization lines are
still being permanently connected, which is relatively time-consuming and can be subject to errors.
HARTING‘s remedy: the Han® GND. The single-pole connector in the robust IP 65 plastic housing is
designed for stranded wires from 10 - 35 mm² and is optionally available in crimp or axial screw
termination. The latter has the advantage that the lines can be connected without a special tool. A simple
screwdriver is all it takes to achieve a quick and easy reliable connection. Extra connector mating security
can be provided by the use of additional locking elements that prevent unintentional opening.
Fast and easy termination
without any special tools
robust IP 65
housing
Ground connector
with green-yellow colour marking
2
Protection against
10
5
-3
²
mm
Han® GND
Features
• New: First connector for potential equalization
• Slim, space saving design
• Low cost plastic hoods and housings
• Colours: green and yellow
• Separate axial screw contacts can be terminated
without any special tools directly to the wire.
Technical characteristics
Specifications
DIN EN 60 664-1
DIN EN 61 984
Hoods/Housings
Material
- hoods/housings
- seal
- cable seal
polycarbonate
NBR
polyamide
Limiting temperatures
-40 °C ... +85 °C
Flammability acc. to UL 94
V0
Degree of protection
according to DIN EN 60 529
for coupled connectors
IP 65
Mechanical working life
≥ 500 mating cycles
Cable diameter
7.5 - 14 mm
Modules
Number of contacts
1
Material polycarbonate
-40 °C ... +125 °C
V0
≥ 500 mating cycles
Crimp Contacts
Material
Surface
- hard-silver plated
Contact resistance
Crimp terminal
- wire gauge1)
Axial Screw Contacts
Material
Surface
Contact resistance
Screw terminal
- wire gauge1)
- AWG
- hexagonal driver
- tightening torque
copper alloy
3 µm Ag
≤ 0.3 mΩ
10 ... 35 mm²
copper alloy
3 µm Ag
≤ 0.3 mΩ
10 ... 35 mm²
6 ... 2
SW 4
mm²
10
16
25
35
Nm
6
6
7
8
3
1) geometric wire gauge
Han® GND
Number of contacts
1
Identification
Hood
Part-Number
09 14 001 0430
top entry
Unlocking Protection
09 14 000 9938
Housing
09 14 001 0330
Hoods, cable to cable
09 14 001 0730
Gender changer / coupler
09 14 001 9901
male / male
4
Drawings
Dimensions in mm
Han® GND
Identification
Part-Number
Male module (M) Female module (F) Drawings
Dimensions in mm
Modules
order contacts separately
M
09 14 001 3032
F
09 14 001 3132
Identification
Wire gauge Part number
(mm²)
Male contact Female contact
Drawing
Dimensions in mm
Crimp contacts*
10
09 11 000 6114
09 11 000 6214
16
09 11 000 6116
09 11 000 6216
25
09 11 000 6125
09 11 000 6225
35
09 11 000 6135
09 11 000 6235
Wire gauge
Ø
Stripping length (A)
10 mm²
4.3
5.5
7.0
8.2
19 mm
19 mm
19 mm
16 mm
16 mm²
25 mm²
35 mm²
for stranded wire acc. to IEC 60 228 Class 5
Axial screw contacts
10-25
09 11 000 6112
09 11 000 6212
16-35
09 11 000 6113
09 11 000 6213
Stripping length 13 mm
Identification
Part number
Drawing
Dimensions in mm
Hex key SW 4
for axial setscrew
with grip
09 99 000 0363
Bit 3/8“
09 99 000 0370
5
* Crimp zone acc. to DIN EN 46 235
For further information see chapter 99 (Tools) in the main catalogue „Industrial Connectors Han®“
Han® GND
Assembly and construction
Assembly
Please use fine stranded wire (Class 5) which is recommend for the axial screw termination.
1.
Do not twist the stripped wire!
Please strip the wire. All suitable wire
gauges have to be stripped with a length
of 13 mm (acc. to Class 5 wire).
Insert stripped wire into the terminal and
push fully inside. Pay attention that all fine
stranded wires are inserted in the contact.
13 mm
stripping lenght
turn clockwise
Secure axial screw
6
2.
Please insert suitable torque key (SW 4)
into the contact from mating side and turn
the axial screw clockwise. For that
purpose secure the axial screw with a
spanner (SW 11).
Tighten the screw to the specified torque
value.
Han® GND
3.
4.
5.
Insert the installed cable through the cable
gland into the Han® GND housing!
Push the axial screw contact into the
module until you hear an audible click,
which is the indicator that the contact
snaps into position.
Push the module back into the housing
and turn the cable gland clockwise.
Mount the module in the housing with the
enclosed screws.
Protection against unintentional opening
1.
2.
Push the unlocking protection over the
opening latches to prevent an unintentional
opening (the connector can only be
unma ted with a separate tool).
The removal of the unlocking protection can
be done with a screwdriver for slotted
screws (e.g. size 0.8 x 4.0). Insert the
screwdriver in the unlocking protection slot
and release the plastic latch until you are
able to remove the unlocking protection
with your fingers.
7
98 42 937 0201
www.HARTING.com
很抱歉,暂时无法提供与“09140013132”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2+78.957042+10.21520
- 6+70.572226+9.13040
- 10+62.2747410+8.05690
- 国内价格
- 2+162.60686
- 10+146.35086
- 国内价格
- 1+180.87794
- 12+176.36875
- 25+171.94287
- 50+166.63181
