0.35mm Pitch, 0.8mm Height, Board to Board or Board to FPC Connectors with Rated Current Up to 5A
BM23PF Series
High current applicable
Conventional product
(P=0.35mm, 34pos.)
Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
BM23PF-24pos.
(+2pos. for power)
Power lines are concentrated into 2 power contacts
(Up to 5A/line) instead of conventional multiple
signal contacts.
Fig.1
■Features
Space-saving
Dimension Example : 24 Pos.
1. Rated current : 5A
Receptacle
Equipped with power contacts capable of handling up to
5A current. (See Fig.1)
Rated current : 5A (Power contact), 0.3A (Signal contact)
Header
2. Space saving design
Compact design ideal for mobile devices. (See Fig.2)
Pitch : 0.35mm, Width : 1.98mm, Stacking height : 0.8mm
3. Robust [Breaking Strength : 90N]
Metal guides prevent housing damage due to incorrect
mating. (See Fig.3)
4. Highly reliable contact design
2-point contact design for both power and signal contact
ensures high reliability. (See Fig.4)
5. Good mating operation
Wide self alignment range with metal guides offers
enhanced mating operation.
(0.4mm in pitch direction, 0.35mm in width direction)
Furthermore, a clear tactile click generated by the
unique locking contact design insures complete mating.
The narrower and shorter, yet flexible design allows
tight installation ( Pitch : 0.35mm, Width : 1.98mm )
Fig.2
Robust design
Metal guide prevents
connector damage even if
mated incorrectly.
Metal guide
6. Supports USB 3.1 Gen.2 (10Gbps) transmission
Breaking Strength
Actually Measured
Signal contacts support USB3.1 Gen.2 transmission
speed.
■Environmental
Halogen-free*
As defined by IEC 61249-2-21
Br : 900ppm max., Cl : 900ppm max.
Br+Cl :1,500ppm max.
90 N
Fig.3
Cross-sectional view of mated contacts
Power contact
Signal contact
Fig.4
In cases where the application will demand a high level of reliavility, such as automotive,
please contact a company representative for further information.
2022.03 ③
1
BM23PF Series●0.35mm Pitch, 0.8mm Height, Board to Board or Board to FPC Connectors with Rated Current Up to 5A
■Product Specifications
Ratings
Rated
current
Signal contact : 0.3A (Note1)
Power contact : 5A
Operating
temperature range
-55°C to 85°C
(Note2)
Storage
temperature range
-10°C to 60°C
(Note3)
Rated
voltage
30V AC/DC
Operating
humidity range
20% to 80%
Storage
humidity range
40% to 70%
(Note3)
Items
Specifications
Conditions
1. Contact resistance
Signal contact : 90mΩ max.
Power contact : 30mΩ max.
Measured at 20mV AC, 1kHz, and 1mA
2. Insulation resistance
50MΩ min.
Measured at 100V DC
3. Withstanding voltage
No flashover or insulation breakdown
100V AC for 1 minute
4. Durability
Contact resistance : Signal contact : 90mΩ max.
10 mating cycles
5. Vibration
No electrical discontinuity for more than 1μs.
Frequency: 10 to 55Hz, single amplitude : 0.75mm
in 3 axis directions for 5 minutes,
10 cycles
6. Shock resistance
No electrical discontinuity of 1µs or more.
Acceleration : 490m/s2, duration of pulse: 11ms
at 3 times for 3 directions.
7. Humidity
Insulation resistance : 25MΩ min.
96 hours at temperature of 40±2°C and a humidity
range from 90 to 95%
8. Temperature cycle
Power contact: 30mΩ max.
Insulation resistance : 50MΩ min.
-55°C for 30minutes ➝ 85°C for 30minutes,
5 cycles
9. Soldering heat
resistance
No dissolution or melting of the resin that will affect
the performance.
Reflow : with recommended temperature profile;
Hand soldering at soldering iron temperature of
350°C for 3 seconds max.
Note 1 : The total current capacity for the connector with 40 or more signal contacts is 12A for all contacts.(Signal contact only)
Note 2 : Includes temperature rise caused by current flow.
Note 3 : Storage refers to long-term-storage of unused items before they are mounted on the PCB.
Operating temperature/humidity range applies to the state of temporary storage such as non-powered after mounting on the
PCB, and during transportation, etc.
■Materials / Finish
Product
Receptacle
Header
Part
Material
Finish
UL Regulation
Insulator
LCP
Black
UL94V-0
Signal Contact
Copper alloy
Gold plating
____
Power Contact
Copper alloy
Gold plating
____
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Receptacle / Header
BM 23 PF 0.8
1
2
4
DS
- 0.35 V
5
6
7
9
8
Series Name: BM
Connector Type
DS: Receptacle
DP: Header
Series No. : 23
Contact Pitch : 0.35mm
Shape Symbols
PF: Power contact type
Terminal type
V : Straight SMT
Stacking Height : 0.8mm
Gold plated specification and packaging status
(51) : Gold plate thickness 0.05µm
Embossed tape packaging(10,000pcs/reel)
(895) : Gold plate thickness 0.05µm
Embossed tape packaging (1,000pcs/reel)
Number of Contacts
2
3
■Receptacle
A
B
1.98
P=0.35
0.8
0.12
0.29
D
Recommended PCB layout
Recommended metal mask dimensions (mask thickness : 100µm)
Unit : mm
Part No.
HRS No.
No. of contacts
A
B
C
D
BM23PF0.8-10DS-0.35V(***)
480-0312-0 **
10
4.25
1.40
2.81
2.84
BM23PF0.8-14DS-0.35V(***)
480-0367-0 **
14
4.95
2.10
3.51
3.54
BM23PF0.8-20DS-0.35V(***)
480-0434-0 **
3.15
4.56
4.59
BM23PF0.8-24DS-0.35V(***)
480-0368-0 **
24
6.70
3.85
5.26
5.29
BM23PF0.8-30DS-0.35V(***)
480-0472-0 **
30
7.75
4.90
6.31
6.34
BM23PF0.8-40DS-0.35V(***)
480-0369-0 **
40
9.50
6.65
8.06
8.09
BM23PF0.8-42DS-0.35V(***)
480-0436-0 **
42
9.85
7.00
8.41
8.44
BM23PF0.8-46DS-0.35V(***)
480-0402-0 **
46
10.55
7.70
9.11
9.14
BM23PF0.8-54DS-0.35V(***)
480-0370-0 **
54
11.95
9.10
10.51
10.54
Note 1 : Please place orders in full reel quantities.
Note 2 : This connector has no polarity.
Note 3 : The specification number(895) in the Part No. changes to(95) in the HRS No.
3
■Header
Unit : mm
Part No.
HRS No.
No. of contacts
A
B
C
D
E
F
BM23PF0.8-10DP-0.35V(***)
480-0306-0 **
10
3.49
1.40
2.70
2.11
3.41
4.25
BM23PF0.8-14DP-0.35V(***)
480-0366-0 **
14
4.19
2.10
3.40
2.81
4.11
4.95
BM23PF0.8-20DP-0.35V(***)
480-0433-0 **
3.15
4.45
3.86
5.16
6.00
BM23PF0.8-24DP-0.35V(***)
480-0291-0 **
24
5.94
3.85
5.15
4.56
5.86
6.70
BM23PF0.8-30DP-0.35V(***)
480-0426-0 **
30
6.99
4.90
6.20
5.61
6.91
7.75
BM23PF0.8-40DP-0.35V(***)
480-0317-0 **
40
8.74
6.65
7.95
7.36
8.66
9.50
BM23PF0.8-42DP-0.35V(***)
480-0435-0 **
42
9.09
7.00
8.30
7.71
9.01
9.85
BM23PF0.8-46DP-0.35V(***)
480-0401-0 **
46
9.79
7.70
9.00
8.41
9.71
10.55
BM23PF0.8-54DP-0.35V(***)
480-0303-0 **
54
11.19
9.10
10.40
9.81
11.11
11.95
4
Embossed Tape Dimensions (IEC 602286-3, with JIC C 0806)
●Receptacle
Un-reeling direction
●Reel Dimensions
10,000pcs/reel
1,000pcs/reel
Unit : mm
Part No.
HRS No.
No. of contacts
A
B
C
G
H
I
480-0312-0 **
10
16
7.5
4.36
17.5
21.5
330
480-0367-0 **
14
16
7.5
5.06
17.5
21.5
330
480-0434-0 **
7.5
6.11
17.5
21.5
330
480-0368-0 **
24
16
7.5
6.81
17.5
21.5
330
480-0472-0 **
30
16
7.5
7.86
17.5
21.5
330
480-0369-0 **
40
24
11.5
9.61
25.5
29.5
330
480-0436-0 **
42
24
11.5
9.96
25.5
29.5
330
480-0402-0 **
46
24
11.5
10.66
25.5
29.5
330
480-0370-0 **
54
24
11.5
12.06
25.5
29.5
330
Note 1 : The specification number(895) in the Part No. changes to(95) in the HRS No.
5
●Header
●Reel Dimensions
10,000pcs/reel
1,000pcs/reel
Unit : mm
Part No.
HRS No.
No. of contacts
A
B
C
G
H
I
480-0306-0 **
10
12
5.5
3.65
13.5
17.5
330
480-0366-0 **
14
16
7.5
4.35
17.5
21.5
330
480-0433-0 **
7.5
5.4
17.5
21.5
330
480-0291-0 **
24
16
7.5
6.10
17.5
21.5
330
480-0426-0 **
30
16
7.5
7.15
17.5
21.5
330
480-0317-0 **
40
24
11.5
8.90
25.5
29.5
330
480-0435-0 **
42
24
11.5
9.25
25.5
29.5
330
480-0401-0 **
46
24
11.5
9.95
25.5
29.5
330
480-0303-0 **
54
24
11.5
11.35
25.5
29.5
330
Note 1: The specification number(895) in the Part No. changes to(95) in the HRS No.
6
BM29 Series Ultra-small, power/signal contact design for Board-to-Board/FPC-to-Board providing 3A max current
Precautions
Precautions
1.Recommended
1.temperature
Recommended
solder
profi
le
MAX 250℃
temperature profile
250
220℃
Jul.1.2017 Copyright 2017 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Temperature
220
200
180
180℃
150℃
150
100
50
25
25℃
(60 sec onds)
90 to 120 seconds
Preheating time
Max. 60 seconds
Soldering time
Start
Time (seconds)
[Conditions]
[Conditions]
1. Peak temperature
1. Peak
temperature
2. Heating
unit
2. Heat
section unit
3. Preheating
3. Preheat
section
4. Number of times
: 250ç
: Maximum
of 250℃
: No less than
220ç for no more than 60 seconds
: 220℃
min.,
: 150 to
180çwithin
for 9060
to seconds
120 seconds
: 150
to
180℃,
90
to
120 seconds
: No more than 2 times
4. Number of reflow cycles : Maximum of 2 cycles
Note 1 :The temperature is the surface temperature of the PCB in the vicinity of the connector
Note 1 lead
: Thepart.
Note 2 :When
you use
refl
ow, please mount the product with the oxygen concentration
connector
leadnitrogen
part.
Note 2 at
: When
using nitrogen
reflow
process, please mount the product with the oxygen
a minimum
of 1,000
[ppm].
concentration
minimum
of 1,000[ppm].
Please
contactatusa if
the concentration
is below 1,000 [ppm].
Please contact Hirose if the concentration is below 1,000[ppm]
2. Recommended hand
soldering conditions
2. Recommended
manual
Soldering iron temperature : 340 ± 10°C,
Soldering
time
within 3 seconds
Soldering
iron: temperature:
340±10℃
3. Recommended screen
thickness/aperture ratio
3. Recommended
screen
(pattern area ratio)
Thickness : 0.1mm
Aperture ratio : 100% on the DS side ; 80% on the DP side
thickness and open area
4. ratio
Warpage
the PCB
to PCBofpattern
area
5. Cleaning
4. Warpage of the PCB
6. Notes
5. Cleaning
6. Notes
Soldering time : within 3 seconds
Thickness : 0.1mm
Aperture ratio
100% onat
thethe
DScenter
side, 100%
side
A maximum
of :0.02mm
part on
of the
the DP
connector
based on both ends of the connector.
Not recommended. If you clean this product, please evaluate the performance before using it.
(Cleaning may cause a change in the mating/unmating property and its resistance to
A maximum of 0.02mm at the center part of the connector on both ends of the connector.
environment)
Care should be taken that mating/unmating operation when the product is not mounted on the
Not recommended. If this product is cleaned, please evaluate the performance before using
PCB could cause damage or deformation, etc. of the contact.
it. Cleaning may cause a change in the mating/unmating properties as well as environmental
Avoid
supporting the PCB only by connectors, and support it by other means than connectors.
resistance.
Care should be taken that excessive prying mating/unmating could cause damage.
During
do not
apply fl ux which
will causeand
fl ux
oozing
on mounted
connector.
sholudsoldering,
be taken when
mating/unmating
the connector
when
it is not
on the
■Carehand
This
product
may
differ in hue
due
to production
PCB.
Damage
or deformation
of the
contacts
may occur. lot variability, but it doesn’t have any
infl
uencesupporting
on the performance.
the PCB only with the connectors. Support it by other means such as bolts,
■Avoid
screws,
posts,
etc.next page for the precautions for mating/unmating.
Please
refer
to the
taken to avoid
thatcaused
could cause
damage.
■Care should
Considering
thebepossibility
of sengagement
diexcessive prying
duemating/unmating
to the counterfor
ce
by the
drop, impact
manual
soldering,
do not state
apply by
fluxthe
which
flux oozing
on connector.
■During
and
routing
of FPC,
xfi the mated
usewill
ofcause
housings
and cushion
materials, etc.
may
have
color differences
due to production
lot variability,
butrated
this does
not rated
■This product
Caution!
Do not
use
theslight
connector
in non-recommended
conditions
(i.e.,
current,
have any effect on the performance.
voltage, PCB design and operating environment, etc.). Such usage could lead to material
■Please refer to the next page for precautions regarding mating/unmating.
outgassing, ignition, or short-circuit, etc.
■Because the product can disengage if dropped (or other impact), and by FPC routing, it is
Refer to the specifi cations and the guidelines for board pattern dimensions, board cautions,
advised to secure the mated connectors to the board with housings and cushioning materials.
and connector treatment.
■Caution! Do not use the connector in non-recommended conditions (i.e., rated current, rated
Pleasae
contact
Hirose
if operating
using theenvironment,
connector etc.).
underSuch
conditions
other
than
those described in
voltage,
PCB design
and
usage could
lead
to material
the outgassing,
specifi cations
andorthe
guidelines
is being considered.
ignition,
short-circuit,
etc.
Refer to the specifications and the guidelines for board pattern dimensions, board cautions, and
Please contact Hirose if using the connector under conditions other than those described in the
specifications and the guidelines is being considered.
7
5
●Handle with care when mating a connector
BM23PF0.8-*DP-0.35V
BM23PF0.8-*DS-0.35V
Alignment method
OK
When aligning, look for the guide port without
applying excessive force.
Caution! If excessive force is applied, the
connector could crack or be shaved which
could lead to a defect in contact resistance.
NG
Guiding condition
Mated condition
8
When guided, the connectors are aligned
parallel to each other with longitudinal and
lateral movements restricted. Mate them
parallel to each other.
●Handle with care when un-mating connectors
OK
Un-mate connectors parallel to each other.
OK
If the connector cannot be un-mated parallel, it can be removed
diagonally from the pitch direction, as shown in the left figure.
However, the connector can be broken if the FPC is not rigid.
Please confirm rigidity of the FPC at the time of trial production.
Pitch direction
Do not pull from the corner. If it is pulled from the corner as
shown in the left figure, the contact and connector could be
damaged.
NG
Corner direction
NG
Please provide a reinforcing plate for the FPC.
If the rigidity of the FPC is not sufficient, the connector may
break as shown in the left figure. Please check the action of the
FPC to be used repeatedly.
A reinforcing plate of 0.3mm or thicker made of glass epoxy
material, or 0.2mm or thicker stainless steel is recommended
9
MEMO
10
MEMO
11
Aug.1.2017 Copyright 2017 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
BM23PF
Series●to
0.35mm
Pitch,SCREW
0.8mm TM
Height,
Board
EF2 Series●Up
400A ZERO
Terminal
Block
USA:
HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE
2300 Warrenville Road, Suite 150,
Downers Grove, IL 60515
Phone : +1-630-282-6700
http://www.hirose.com/us/
USA:
HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE
2841 Junction Ave, Suite 200
San Jose, CA. 95134
Phone : +1-408-253-9640
Fax : +1-408-253-9641
USA:
HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE)
17197 N. Laurel Park Drive, Suite 253,
Livonia, MI 48152
Phone : +1-734-542-9963
Fax : +1-734-542-9964
USA:
HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE
300 Brickstone Square Suite 201,
Andover, MA 01810
Phone : +1-978-662-5255
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Hogehillweg #8 1101 CC Amsterdam Z-O
Phone : +31-20-6557460
Fax : +31-20-6557469
http://www.hirose.com/eu/
GERMANY:
HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH
Schoenbergstr. 20, 73760 ostfildern
Phone : +49-711-456002-1
Fax : +49-711-456002-299
GERMANY:
HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE
Neumeyerstrasse 22-26, 90411 Nurnberg
Phone : +49-911 32 68 89 63
Fax : +49-911 32 68 89 69
GERMANY:
HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE
Bayernstr. 3, Haus C 30855 Langenhagen, Germany
Phone : +49-511 97 82 61 30
Fax : +49-511 97 82 61 35
FRANCE:
HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE
130 Avenue Joseph Kessel, Bat E, 78960
Voisins le Bretonneux, France
Phone : +33-1-85764886
Fax : +33-1-85764823
UNITED KINGDOM:
HIROSE ELECTRIC EUROPE BV (UK BRANCH)
4 Newton Court, Kelvin Drive, Knowlhill,
Milton Keynes, MK5 8NH
Phone : +44-1908 202050
Fax : +44-1908 202058
CHINA:
HIROSE ELECTRIC (SHANGHAI) CO., LTD.
18, Enterprise Center Tower 2, 209# Gong He
Road, Jing’an District, Shanghai, CHINA 200070
Phone : +86-21-6391-3355
Fax : +86-21-6391-3335
http://www.hirose.com/cn/
CHINA:
HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH
A1001, Ocean International Center, Building 56# East 4th
Ring Middle Road, ChaoYang District, Beijing, 100025
Phone : +86-10-5165-9332
Fax : +86-10-5908-1381
CHINA:
HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD.
Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre,
5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008
Phone : +86-755-8207-0851
Fax : +86-755-8207-0873
HONG KONG:
HIROSE ELECTRIC HONGKONG TRADING CO., LTD.
Room 1001, West Wing, Tsim Sha Tsui Centre, 66
Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong
Phone : +852-2803-5338
Fax : +852-2591-6560
http://www.hirose.com/hk/
TAIWAN:
HIROSE ELECTRIC TAIWAN CO., LTD.
103 8F, No.87, Zhengzhou Rd., Taipei
Phone : +886-2-2555-7377
Fax : +886-2-2555-7350
http://www.hirose.com/tw/
KOREA:
HIROSE KOREA CO.,LTD.
143, Gongdan 1-daero, Siheung-si,
Gyeonggi-do, 15084, Korea
Phone : +82-31-496-7000
Fax : +82-31-496-7100
http://www.hirose.co.kr/
INDIA:
SINGAPORE:
HIROSE ELECTRIC SINGAPORE PTE. LTD.
HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE
03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C,
Singapore 079909
Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India
Phone : +65-6324-6113
Phone : +91-12-660-8018
Fax : +65-6324-6123
Fax : +91-120-4804949
http://www.hirose.com/sg/
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE
Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma
Gandhi (MG) Road, Bangalore 560 001, Karnataka, India
Phone : +91-80-4120 1907
Fax : +91-80-4120 9908
THAILAND:
MALAYSIA:
BANGKOK OFFICE (REPRESENTATIVE OFFICE)
PENANG REPRESENTATIVE OFFICE
73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn
Lepas Penang, 11950, Malaysia
Road, Yannawa, Sathorn, Bangkok 10120 Thailand
Phone : +604-648-5536
Phone : +66-2-686-1255
Fax : +66-2-686-3433
12
4
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose-connectors.com
Thecharacteristics
characteristicsand
andthe
thespecifications
specificationscontained
containedherein
hereinare
arefor
forreference
referencepurpose.
purpose.Please
Pleaserefer
refertotothe
thelatest
latestcustomer
customerdrawings
drawingsprior
priortotouse.
use.
The
The
contents
catalog
current
of date
of 08/2017.
Contents
subject
to change
without
notice
purpose
of improvements.
The
contents
of of
thisthis
catalog
areare
current
as as
of date
of 03/2022.
Contents
areare
subject
to change
without
notice
for for
thethe
purpose
of improvements.
