12FM-1.0SP-1.9-TF(LF)(SN)
    JST
    FM Series 12 Position 1.00 mm Side Entry SMT FFC/FPC Connector
12FM-1.0SP-1.9-TF(LF)(SN) 数据手册
1.0 mm FM CONNECTOR Emboss Tape Connectors for FFC and FPC pitch Features ● Compact Having no complicated cam or slide mechanism, this connector is small with a mounting height of only 4.4 mm and a width of 3.0 mm. FM CONNECTOR ● Double-sided contact This connector has highly resilient phosphor bronze contacts, each of which has two independent mating spring members that ensure continuity even when subjected to severe vibration. Because each of the contacts simultaneously mates with both sides of the FFC or FPC, the engineer has greater freedom in designing his circuitry. ● Simple snap-in action The FFC or FPC are securely connected by simply inserting their leads into the connector. ● Surface mount model (SMT) The FM connector, a miniature connector with a thickness of only 3.0 mm, was developed to connect flexible flat cables (FFC) or flexible printed circuits (FPC) with a lead pitch of 1.0 mm to printed circuit boards. It is ideally suited for connections inside high-density equipment or between mechanical units. The contact is constructed to ensure a stable connection and high reliability even under vibration and impact. Connection is easy with a simple snap-in action. This connector is also available in a surface mount configuration. Its housing is made of heat resistant resin so that it is not adversely affected during reflow soldering. Because of its tiny size and ability to be surface mounted, this connector meets the demand for high-density mounting of components inside electronic products. Specifications • Current rating: 0.5 A AC/DC • Voltage rating: 50 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 20 m Ω max. After environmental tests/ 30 m Ω max. • Insulation resistance: 800 M Ω min. • Withstanding voltage: 500 VAC/minute • Applicable FFC and FPC: Conductor pitch/ 1.0 mm Conductor width/ 0.7 mm +0.02 Mating part thickness/ 0.33 ― 0.03 mm • Applicable PC board thickness: 0.8 to 1.6 mm FFC/FPC to be actually used should be checked for applicability. * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. Standards ® ® ® ® ® Recognized E60389 Certified LR20812 1 FM CONNECTOR Connector ●Through-hole type Top entry type Side entry type 4.4 1.0 Insertion depth 2.0 Circuit No.1 Circuit No.1 0.4 ●SMT type Top entry type 2.8 4.4 挿入深さ Circuit No.1 Circuit No.1 4.35 2.0 0.5 Side entry type B C A 1.5 Insertion depth 2.8 B C A 4.4 1.0 1.5 Insertion depth 2.8 4.4 3.0 3.0 1.0 1.5 3.0 0.4 2.9 3.0 2.8 B C A 3.0 Insertion depth 3.0 1.0 1.5 7.3 0.5 B C A Circuit No.1 2.0 0.4 1.9 Circuit No.1 0.4 Through-hole type connector Model No. of Through-hole type No. of circuits Top entry type Side entry type 3 03FM-1.0BT 4 04FM-1.0BT 5 Dimensions (mm) Q'ty/box A B C 03FM-1.0ST 2.0 5.0 4.1 2,000 04FM-1.0ST 3.0 6.0 5.1 2,000 05FM-1.0BT 05FM-1.0ST 4.0 7.0 6.1 2,000 6 06FM-1.0BT 06FM-1.0ST 5.0 8.0 7.1 1,000 7 07FM-1.0BT 07FM-1.0ST 6.0 9.0 8.1 1,000 8 08FM-1.0BT 08FM-1.0ST 7.0 10.0 9.1 1,000 10 10FM-1.0BT 10FM-1.0ST 9.0 12.0 11.1 1,000 11 11FM-1.0BT 11FM-1.0ST 10.0 13.0 12.1 1,000 12 12FM-1.0BT 12FM-1.0ST 11.0 14.0 13.1 1,000 SMT type connector on embossed-tape No. of circuits Q'ty/reel Dimensions (mm) Model No. Top entry type Side entry type A B C ‒ 03FM-1.0SP-1.9-TF 2.0 5.0 4.1 ‒ 2,500 4 04FM-1.0BP-TF 04FM-1.0SP-1.9-TF 3.0 6.0 5.1 1,000 2,500 5 05FM-1.0BP-TF 05FM-1.0SP-1.9-TF 4.0 7.0 6.1 1,000 2,500 6 06FM-1.0BP-TF 06FM-1.0SP-1.9-TF 5.0 8.0 7.1 1,000 2,500 7 07FM-1.0BP-TF 07FM-1.0SP-1.9-TF 6.0 9.0 8.1 1,000 2,500 8 08FM-1.0BP-TF 08FM-1.0SP-1.9-TF 7.0 10.0 9.1 1,000 2,500 10 10FM-1.0BP-TF-A 10FM-1.0SP-1.9-TF 9.0 12.0 11.1 1,000 2,000 12 ‒ 12FM-1.0SP-1.9-TF 11.0 14.0 13.1 ‒ 2,000 3 Material and Finish (Through-hole type) Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment) Housing: PBT, UL94V-0 (SMT type) Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment) Housing: PPS, UL94V-0 RoHS2 compliance This product displays (LF)(SN) on a label. 2 Top entry type Side entry type FM CONNECTOR Lead section dimensions of FFC and FPC FFC FPC 1.0×(N+1)±0.12 1.0 ±0.15 1.0×(N-1)±0.07 1.0 ±0.05 +0.02 0.33 ー0.03 0.7 ±0.1 1.0 ±0.15 0.7 ±0.1 0.33 R0.3 10.0 3.0 min. 1.0 ±0.1 1.0×(N+1)±0.07 1.0 ±0.15 Conductor +0.02 ー0.03 Conductor 7.5 1.0×(N-1)±0.1 3.0 min. 1.0 ±0.15 Reinforcing layer Reinforcing layer Film cover layer Base layer Note: N --- Number of circuits PC board layout and Assembly layout ●Through-hole type Top entry type Side entry type 2.0 min. 3.0 3.0 2.9 2.0 ±0.05 Circuit No.1 4.4 5.0 min. φ0.75 ±0.05 4.4 φ0.75±0.05 2.0 min. 1.0±0.05 Circuit No.1 Soldering side 2.0 ±0.15 1.0 ±0.05 2.0±0.05 3.0 0.9 min. 2.0±0.05 Soldering side ●SMT type Top entry type Side entry type 1.5 min. 1.0±0.05 3.0 Connector mounting side 1.5 min. 0.6 ±0.05 4.4 3.0 1.9 3.6 1.2 2.0 4.4 0.6 ±0.05 3.0 1.0 ±0.05 Connector mounting side Note: 1. Tolerances are non-cumulative: ± 0.05 mm for all centers. 2. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. 3. It is recommended that surface mount connectors be secured using thermosetting resin or something similar. Contact JST for details. 3
12FM-1.0SP-1.9-TF(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“12FM-1.0SP-1.9-TF(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
