.IST
CMKS-L DIES CONSTRUCTION SHEET
SEH-00lT-PO.6
Die set Model No.
I------ - - - - - - : - - - - -
Terminal/Contact
Mode I No.
I SEH-001-06
Appl icator Model No. I CMItS-L
I------
Cr imp shape (w ire)
I N-1. 4
Cr imp shape (i ns)
I
N-1. 8
Clearance between Crimper ( B) and Shear blade
Description
Cr impe r (A)
Crimper (B)
Spacer (A)
Spacer (B)
Spacer (C)
Punch
Die holder
Sp ring
Wire block
Insulation block
r>.
Wi re hold punch
Wi re hold punch spring
Guide plate (L)
Guide plate (R)
Feed plate
Pressure plate
Pressure spring (Zncs)
Description
Cr i mper anv i I (A)
Crimper anv i I (B)
No.
C75165
C76830
68225
67530
A325
B266
Spacer
Shear blade
Shear blade supporter
Shear blade base
Shear blade spring
C77 400
C74370
C73120
C78010
C87010
68235
87270
Feed finger
Feed finger holder
G6190
G6130
C81510
C82500
C84310
C83170
87001
Stripper
Stripper bracket
Stripper pin
91450
92290
Type
Size
UL1007
#30
I
#28
0.60"-'0.65
I 0.65+0.05
I
Ins
0.57"-'0.62
1.4
I
1.5
I
1.5
#24
0.70+0.05
I
1.6
I
I
#22
t
0.75+0.05
I
1.7
I
I
ULl 007 I
I
UL1007
I
Wi re
#26
i
C95310
Scrap cover
Remarks
I
ULl 007
Cr imp he i ght (mm)
Wi re
UL1007
O. 1
No.
63821
64760
65120
Wi re and Crimp height
I
I Prepared •.Qy I..
J(~
J Issue da te I
_._-
Oct 01, 1996
Side-Feeding ADDI i c a t o r-
CMKS~L
Die Set AssemblY
APPlicable
terminal/
contact
SEH-001-06
l
l~
67530
6~
/6130
~ /86190
r
I
64760
68235
C83170
C82500
C81510
C84310
87001
92290
C74370
C87010
C73120
C77400
C75165
C76830
D ate
Drawn
65120
63821
bY
很抱歉,暂时无法提供与“CMKSL”相匹配的价格&库存,您可以联系我们找货
