2000-1492
2000-1492
    WAGO(万可电子)
2000-1492 数据手册
0.14 … 1 (1.5) mm²1 AWG 24 … 16 800 V/8 kV/3 2 600 V, 10 AU 600 V, 10 A2 IN 13.5 A (18 A) 0.14 … 1 (1.5) mm²1 AWG 24 … 16 800 V/8 kV/3 2 600 V, 10 AU 600 V, 10 A2 IN 13.5 A (18 A) Terminal block width 3.5 mm / 0.138 in. L 9 … 11 mm / 0.39 in. 3 Terminal block width 3.5 mm / 0.138 in. L 9 … 11 mm / 0.39 in. 3 Terminal block width 3.5 mm / 0.138 in. L 9 … 11 mm / 0.39 in. 3 19,9mm/0.78in 48,5 mm/1.91 in Item No. 32,9 mm/ 1.3 in 0.14 … 1 (1.5) mm²1 AWG 24 … 16 800 V/8 kV/3 2 600 V, 10 AU 600 V, 10 A2 IN 13.5 A (18 A) 32,9 mm/ 1.3 in 10 32,9 mm/ 1.3 in 1 TOPJOB® S Through/Ground Conductor/Ex and Double-Potential Terminal Blocks 1 (1.5) mm², 2000 Series 29,6 mm/1.17 in 58,2 mm/2.29 in Pack. Unit Item No. 29,6 mm/1.17 in 67,9 mm/2.67 in Pack. Unit Item No. Pack. Unit 2-conductor through terminal block 2000-1201 5 100 gray 4 2000-1204 4 5 100 blue 4 2000-1202 5 100 orange 4 2000-1203 5 100 red 4 2000-1205 5 100 black 4 2000-1206 5 100 yellow 4 3-conductor through terminal block 2000-1301 5 100 gray 4 2000-1304 4 5 100 blue 4 2000-1302 5 100 orange 4 2000-1303 5 100 red 4 2000-1305 5 100 black 4 2000-1306 5 100 yellow 4 4-conductor through terminal block 2000-1401 5 100 gray 4 2000-1404 4 5 100 blue 4 2000-1402 5 100 orange 4 2000-1403 5 100 red 4 2000-1405 5 100 black 4 2000-1406 5 100 yellow 4 2-conductor ground terminal block 2000-1207 5 green-yellow 4 3-conductor ground terminal block 2000-1307 5 green-yellow 4 4-conductor ground terminal block 2000-1407 5 green-yellow 4 100 Item-Specific Accessories End and intermediate plate, 0.7 mm thick 2000-1292 orange 2000-1291 gray Ex e/Ex i separator, orange, 6 3 mm thick 209-190 90 mm 209-191 120 mm Item-Specific Accessories 100 (4x25) 100 (4x25) End and intermediate plate, 0.7 mm thick 2000-1392 orange 2000-1391 gray Ex e/Ex i separator, orange, 6 3 mm thick 50 (2x25) 209-191 120 mm 50 (2x25) 2000 Series Accessories Push-in type jumper bar, insulated, 6 IN 14 A, light gray 2-way 2000-402 3-way 2000-403 4-way 2000-404 5-way 2000-405 6-way 2000-406 7-way 2000-407 8-way 2000-408 9-way 2000-409 10-way 2000-410 Push-in type jumper bar, insulated, IN 14 A, light gray from 1 to 3 2000-433 from 1 to 4 2000-434 from 1 to 5 2000-435 from 1 to 6 2000-436 from 1 to 7 2000-437 from 1 to 8 2000-438 from 1 to 9 2000-439 from 1 to 10 2000-440 100 100 Item-Specific Accessories 100 (4x25) 100 (4x25) End and intermediate plate, 0.7 mm thick 2000-1492 orange 2000-1491 gray Ex e/Ex i separator, orange, 6 3 mm thick 50 (2x25) 209-191 120 mm 100 (4x25) 100 (4x25) 50 (2x25) Appropriate marking systems: WMB/Marking strips (see Section 13) 200 200 200 100 100 100 100 100 100 200 200 100 100 100 100 100 100 (8x25) (8x25) (8x25) (4x25) (4x25) (4x25) (4x25) (4x25) (4x25) Protective warning marker, with high-voltage symbol, black, for 5 terminal blocks yellow 2000-115 100 (4x25) Delta jumper, insulated, 6 IN = IN terminal block, light gray 1-2 3-4 5-6 2000-406/020-000 100 (4x25) Star point jumper, insulated, 6 IN = IN terminal block, light gray 2000-405/011-000 1-3-5 100 (4x25) Push-in type wire jumper, 6 insulated, IN 16 A, wire size 1.5 mm² 2009-402 100 (10x10) L = 60 mm L = 110 mm 2009-404 100 (10x10) L = 250 mm 2009-406 100 (10x10) (8x25) (8x25) (4x25) (4x25) (4x25) (4x25) Test plug adapter, (4x25) for 4 mm Ø test plug (4x25) gray 2009-174 Certification organizations can be found in the overview on page 622. Banana plug, for socket 4 mm Ø, color mixed   215-111 50 Testing tap, for max. 2.5 mm² gray 2009-182 100 (4x25) Test plug, with 500 mm cable, 2 mm Ø red 210-136 50 Test plug, with 500 mm cable, 2.3 mm Ø yellow 210-137 Marking strip, plain, 11 mm wide, 50 m roll white 2009-110 WMB Multi marking system, 10 strips with 10 markers per card, 100 (4x25) for 3.5 mm terminal block width plain 793-3501 50 1 5
2000-1492 价格&库存
很抱歉,暂时无法提供与“2000-1492”相匹配的价格&库存,您可以联系我们找货
      • 100+9.25686
      库存:375
      2000-1492
      • 1+15.535711+2.01575
      • 10+13.2319610+1.71684
      • 25+12.4021825+1.60918
      • 50+11.8103350+1.53238
      • 100+11.24647100+1.45922
      • 250+10.54151250+1.36776
      • 500+10.03828500+1.30246
      • 1000+9.559061000+1.24028
      • 2500+8.960802500+1.16266
      库存:362
