21033836405
21033836405
    HARTING(浩亭)
    WDFM12F/PG94POL.D-KOD.700MM
21033836405 数据手册
Product data sheet 21 03 338 6405 M12 Cable Assembly B-cod st/- f/- 0,5m M12 Cable Assembly B-cod st/- f/- 0,5m Part number 21 03 338 6405 Specification M12 Cable Assembly B-cod st/- f/- 0,5m HARTING eCatalogue https://b2b.harting.com/21033386405 Image is for illustration purposes only. Please refer to product description. Identification Category Connectors Series Circular connectors M12 Element Panel feed through Specification With conductors for front mounting Version Gender Female Locking type Screw locking Shielding Unshielded Number of contacts 4 Coding B-coding Details without lock nut Technical characteristics Conductor cross-section 0.34 mm² Conductor cross-section AWG 22 Rated current 4 A Rated voltage 60 V Rated impulse voltage 1.5 kV Pollution degree 3 Overvoltage category III Insulation resistance >108 Ω Page 1 / 2 | Creation date 2021-07-02 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com Product data sheet 21 03 338 6405 M12 Cable Assembly B-cod st/- f/- 0,5m Technical characteristics Contact resistance ≤10 mΩ Tightening torque 2 Nm Lock nut Ambient temperature -30 ... +80 °C Mating cycles ≥100 Degree of protection acc. to IEC 60529 IP67 mated condition Isolation group I (600 ≤ CTI) Thickness of the panel 2 ... 5 mm Conductor length 50 cm Material properties Material (insert) Polyamide (PA) Material (contacts) Brass Surface (contacts) Gold plated Material (hood/housing) Zinc die-cast RoHS compliant with exemption RoHS exemptions 6(c): Copper alloy containing up to 4 % lead by weight ELV status compliant with exemption China RoHS 50 REACH Annex XVII substances No REACH ANNEX XIV substances No REACH SVHC substances Yes REACH SVHC substances Lead ECHA SCIP number 0d7d3693-d625-47ab-934a-d241bf72c86e Specifications and approvals Specifications IEC 61076-2-101 Commercial data Packaging size 1 Net weight 30.5 g Country of origin Czechia European customs tariff number 85444290 eCl@ss 27440103 Sensor-actuator connector chassis (sensor technology acc.) Page 2 / 2 | Creation date 2021-07-02 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com
21033836405 价格&库存
很抱歉,暂时无法提供与“21033836405”相匹配的价格&库存,您可以联系我们找货
