232-163
232-163
    WAGO(万可电子)
232-163 数据手册
Data sheet  |  Item number: 232-263 THT female header; 0.6 x 1.0 mm solder pin; angled; Pin spacing 5.08 mm; 3pole; orange www.wago.com/232-263 Color: Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 1/7 Data sheet  |  Item number: 232-263 www.wago.com/232-263 L = (pole no. x pin spacing) + 1.5 mm Distance to first solder pin: 2.2 mm 2- to 3-pole female connectors – one latch only Item description Horizontal or vertical PCB mounting via straight or angled solder pins For board-to-board and board-to-wire connections Touch-proof PCB outputs Easy-to-identify PCB inputs and outputs With coding fingers Safety information 1: The MULTI CONNECTION SYSTEM (MCS) is designed without breaking capacity for compliance with DIN EN 61984. When used as intended, MCS Connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Data Electrical data Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 2/7 Data sheet  |  Item number: 232-263 www.wago.com/232-263 Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 320 V Rated impulse voltage (III / 3) 4 kV Rated voltage (III / 2) 320 V Rated impulse voltage (III / 2) 4 kV Rated voltage (II / 2) 630 V Rated impulse voltage (II / 2) 4 kV Rated current 12 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 15 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Approvals per UL 1977 Rated voltage per UL 1977 (factory wiring only) 600 V Rated current per UL 1977 (factory wiring only) 15 A Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 15 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Connection data No. of poles 3 Total number of connection points 3 Total number of potentials 3 Number of connection types 1 Number of levels 1 Geometrical Data Pin spacing 5.08 mm / 0.2 inch Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 3/7 Data sheet  |  Item number: 232-263 www.wago.com/232-263 Pin spacing 5.08 mm / 0.2 inch Width 16.74 mm / 0.659 inch Height 16.6 mm / 0.654 inch Height from the surface 11.6 mm / 0.457 inch Depth 18.25 mm / 0.719 inch Solder pin length 5 mm Solder pin dimensions 0.6 x 1 mm Drilled hole diameter (tolerance) 1.3(- … +0.1) mm Plug connection Contact type (pluggable connector) Female connector/socket Connector connection type for PCBs Mismating protection No Mating direction to the PCB 0  ° PCB contact PCB contact THT Solder pin arrangement over the entire female connector, in line Number of solder pins per potential 1 Material Data Color orange Material group I Insulating material Polyamide 66 (PA 66) Flammability class per UL94 V0 Contact material Copper alloy Contact plating tin-plated Fire load 0.047 MJ Weight 2.7 g Environmental Requirements Limit temperature range -60 … +85 °C Commercial data Product Group 3 (Multi Conn. System) Packaging type BOX Country of origin DE GTIN to changes. Subject WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com 4044918579445 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 4/7 Data sheet  |  Item number: 232-263 www.wago.com/232-263 Country of origin DE GTIN 4044918579445 Customs Tariff No. 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CB DEKRA Certification B.V. IEC 61984 NL-39756 KEMA/KEUR DEKRA Certification B.V. EN 61984 2190761.01 Ship Approvals Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping - 19HG15869876PDA LR Lloyds Register IEC 61984 96/20035 (E5) UL-Approvals Logo Approval Additional Approval Text Certificate name UL UL International Germany GmbH UL 1977 E45171 UR Underwriters Laboratories Inc. UL 1059 E45172 sec. 18 Compatible products check Item no.: 231-661 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/231-661 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 5/7 Data sheet  |  Item number: 232-263 www.wago.com/232-263 Item no.: 231-661 Test plugs for female connectors; for 5 mm and 5.08 mm pin spacing; 2,50 mm²; light gray www.wago.com/231-661 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 3.6 MB Download URL Download CAD/CAE-Data CAD data 2D/3D Models 232-263 CAE data EPLAN Data Portal 232-263 Download PCB Design Symbol and Footprint 232-263 URL Download CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 6/7 Data sheet  |  Item number: 232-263 www.wago.com/232-263 STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian Installation Notes Product family MCS MIDI Classic Show all products from the family Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 7/7
232-163 价格&库存
很抱歉,暂时无法提供与“232-163”相匹配的价格&库存,您可以联系我们找货
      库存:200
      232-163
        库存:3556
