Ha-VIS eCon 3000 Fast Ethernet Basic
3 to 10 Ethernet ports RJ45 and SC
English
Unmanaged Plug & Play Ethernet switches for DIN rail assembly in control
cabinets
Commercial temp.: 0°C ... +55°C / Industrial temp.: -40°C ... +70°C
Energy
Efficient
Ethernet
■ Fast Ethernet Non-Blocking Switch architecture in accordance with
IEEE 802.3
■ Variants with industrial temperature range of -40°C ... +70°C
■ Wide range power supply 24/48 VDC
■ Surge protection and reverse polarity protection
■ Minimum energy consumption due to energy-efficient Ethernet
■ Optimised DIN rail bracket
Target markets
Machinery & Robotics
Automation
Industrial network
infrastructures
Wind Energy,
Solar Energy
Transportation
Shipbuilding
General Description
The Ha-VIS eCon 2000 Fast Ethernet family of unmanaged Ethernet switches
is equipped with up to 10 Fast Ethernet ports and allow for cost-efficient
and quick expansion and/or reconstruction of network infrastructures. The
slender design of the switches enables an extremely high packing density
on the DIN rail. The selection includes various combinations of variants with
RJ45 and fibre optic ports. Automatic detection of the transmission rate
(auto-negotiation) and of the wiring of the twisted pair data cable (autopolarity and auto-MDI(X)) allow for simple plug & play. All variants are
available with the temperature ranges "Industrial" and "Commercial".
Specification
Switch features
Ethernet ports 10BASE-Te / 100BASE-TX EEE
Housing width
Number of ports
25 mm
38 mm
3, 5, 6, 7, 8
9, 10
Type of connection
RJ45
Auto-negotiation
Yes
Yes
Switching technology
Store and Forward
Auto-polarity
Supported standards
IEEE 802.3
Auto-MDI(X)
Yes
Frame size
1522 bytes
1632 bytes
MAC table size
Transfer conditions
1k entries
2k entries
448 kbit
1 Mbit
Transfer speed
10 / 100 Mbit/s
Transfer length
100 m (Twisted Pair, Cat 5)
Packet buffer size
Non-blocking
Yes
Quality of Service
Yes
Energy Efficient Ethernet
Yes
PROFINET compatible
Yes
EthernetIP compatible
Yes
Twisted pair
Ethernet Ports 100BASE-FX
Type of fibre
Multi-mode (MM)
Type of connection
Transfer conditions
FOC
Wavelength
Power supply
Nominal voltage
Permissible voltage range
24 VDC
48 VDC
9 VDC ... 60 VDC
Surge protection
Yes
Reverse polarity proof
Yes
Starting current
Overcurrent protection at input
Max. power consumption @ 24 VDC
Conductor cross-section
Type of connection
Pinout
Output power
Input sensitivity
1.6 A
3.2 A
Yes (12 A)
Yes (2 A)
1.73 W ... 6.72 W
0.08 mm² ... 2.5 mm² (28 AWG ... 12 AWG)
3-pole, pluggable screwed contact
Supply circuit (according to 60950)
SELV (circuit breaker 10 A)
Service hotline: +49 5772 47-97100, Fax: +49 5772 47-495
Electric@HARTING.com, www.HARTING.com
100 Mbit/s
2 km
15 km
-20 dBm ... -14 dBm
-15 dBm ... -8 dBm
≤ -30 dBm
≤ -32 dBm
Ambient conditions
Commercial temperature range
Industrial temperature range
Storage temperature range
0°C ... +55°C
-40°C ... +70°C
-40°C ... +85°C
Relative humidity (operation)
0% ... 95% (non-condensing)
Relative humidity (storage and
transport)
Air pressure
HARTING Technologiegruppe
P.O.Box 1473, D-32325 Espelkamp
Wilhelm-Harting-Straße 1, D-32325 Espelkamp, Germany
1310 nm
Transfer speed
Transfer length
Single-mode (SM)
SC Duplex
2000 m (795 hPa)
Note: We reserve the right to make technical changes to the products and to the content of this
document at any time without prior notification. The HARTING Technologiegruppe does not accept any responsibility for possible errors or incompletions in this document. We reserve all the
rights to this document and the topics and illustrations contained within it. Copying, disclosure to
third parties or use of its content - even partially - is forbidden without the prior written consent
of the HARTING Technologiegruppe.
Housing
Housing width
Dimensions H x W x D (without
pluggable screwed contact and
holding bracket)
25 mm
38 mm
142 mm x 25 mm
x 107.5 mm
142 mm x 38 mm
x 107.5 mm
Weight
430 g ... 531 g
Type of installation
35 mm DIN rail acc. to EN 60 715
Anodised aluminium / powder-coated
steel sheet
Material hoods/housings
Protection class (with plugged
screwed contact)
III
Status and diagnostic displays
Power ("Pwr")
illuminated green
Supply voltage is applied
Link/Activity ("L/A") off
No link
Link/Activity ("L/A") illuminated green
Link/Activity ("L/A") flashes green
Link is active
Link is active and data is transferred
Link speed ("Spd") off
10 Mbit/s
Link speed ("Spd") illuminated yellow
100 Mbit/s
EMC and environmental conditions
EMC interference immunity (EN 61000-6-1, 61 000-6-2 55024)
Electrostatic discharge (ESD) EN 61 000-4-2
Electromagnetic field EN 61 000-4-3
Rapid transients (burst) EN 61 000-4-4
Surge voltages EN 61 000-4-5
Conducted interference voltages EN 61 000-4-6
EMC interference emission (EN 61000-6-4, EN 55 022, FCC CFR 47 Part 15)
IP 30
Protection class
Approvals (in preparation)
CE (FCC CFR 47 Part 15, cUL US 508 listed, DNV, GL, ABS, NK)
Mechanical stability (EN 60721-3)
IEC 60068-2-6 Vibration
IEC 60068-2-6 Resonance search
IEC 60068-2-27 Shock test
Scope of delivery
■ Pluggable screwed contact for power supply
■ Installation instructions
Drawings
Specifications / order information
Ports / order information
SC
Housing
width
Power consumption @ 24 VDC
MTBF in
million h
Switch
Order no.
Switch
Order no.
RJ45
SFP
2
1x MM (2 km)
25 mm
90 mA
2.52
Ha-VIS eCon 3021B-AD
24030021110
Ha-VIS eCon 3021BT-AD
24030021100
2
1x SM (15 km)
25 mm
90 mA
2.52
Ha-VIS eCon 3021B-AF
24030021210
Ha-VIS eCon 3021BT-AF
24030021200
4
1x MM (2 km)
25 mm
105 mA
2.36
Ha-VIS eCon 3041B-AD
24030041110
Ha-VIS eCon 3041BT-AD
24030041100
4
1x SM (15 km)
25 mm
105 mA
2.36
Ha-VIS eCon 3041B-AF
24030041210
Ha-VIS eCon 3041BT-AF
24030041200
4
2x MM (2 km)
25 mm
125 mA
2.28
Ha-VIS eCon 3042B-AD
24030042110
Ha-VIS eCon 3042BT-AD
24030042100
4
2x SM (15 km)
25 mm
125 mA
2.28
Ha-VIS eCon 3042B-AF
24030042210
Ha-VIS eCon 3042BT-AF
24030042200
6
25 mm
75 mA
2.30
Ha-VIS eCon 3060B-A
24030060010
Ha-VIS eCon 3060BT-A
24030060000
6
1x MM (2 km)
25 mm
115 mA
2.22
Ha-VIS eCon 3061B-AD
24030061110
Ha-VIS eCon 3061BT-AD
24030061100
6
1x SM (15 km)
25 mm
115 mA
2.22
Ha-VIS eCon 3061B-AF
24030061210
Ha-VIS eCon 3061BT-AF
24030061200
8
25 mm
85 mA
2.17
Ha-VIS eCon 3080B-A
24030080010
Ha-VIS eCon 3080BT-A
24030080000
8
1x MM (2 km)
38 mm
220 mA
0.95
Ha-VIS eCon 3081B-AD
24030081110
Ha-VIS eCon 3081BT-AD
24030081100
8
1x SM (15 km)
38 mm
220 mA
0.95
Ha-VIS eCon 3081B-AF
24030081210
Ha-VIS eCon 3081BT-AF
24030081200
8
2x MM (2 km)
38 mm
280 mA
0.93
Ha-VIS eCon 3082B-AD
24030082110
Ha-VIS eCon 3082BT-AD
24030082100
8
2x SM (15 km)
38 mm
280 mA
0.93
Ha-VIS eCon 3082B-AF
24030082210
Ha-VIS eCon 3082BT-AF
24030082200
10
38 mm
200 mA
0.92
Ha-VIS eCon 3100B-A
24030100010
Ha-VIS eCon 3100BT-A
24030100000
Copyright © 2014
HARTING Technologie
All rights reserved
Date of issue 04.2014
Doc No 24030000000/98
很抱歉,暂时无法提供与“24030041100”相匹配的价格&库存,您可以联系我们找货
