24020061120
24020061120
    HARTING(浩亭)
24020061120 数据手册
Ha-VIS eCon 2000 Fast Ethernet Basic PoE / PoE+ 5 to 8 Ethernet ports RJ45, FOC, and PoE / PoE+ English Unmanaged Plug and Play Ethernet switches for DIN rail assembly in control cabinets Commercial temp.: 0 °C ... +55 °C / Industrial ­­ temp.: -40 °C ... +70 °C Energy Efficient Ethernet ■ Energy supply of up to 4 terminal devices via PoE+ (137 watts) in accordance with IEEE 802.3at ■ Fast Ethernet Non-Blocking Switch architecture in accordance with IEEE 802.3 ■ Variants with industrial temperature range of -40 °C ... +70 °C ■ Surge protection and reverse polarity protection ■ Minimum energy consumption due to energy-efficient Ethernet Target markets Machinery & Robotics Automation Industrial network infrastructures Wind Energy, Solar Energy Transportation Shipbuilding General Description The Ha-VIS eCon 2000 Fast Ethernet PoE family of unmanaged Ethernet switches is equipped with up to 8 Fast Ethernet ports and allow for cost-efficient and quick expansion and/or reconstruction of network infrastructures. The switches work as power sourcing equipment (PSE) and are capable of simultaneously providing the full PoE output of 34.2 watts on up to four ports. Due to the extremely flat design, these switches can be accommodated in installations where space is restricted towards the cable connection at the front. The selection includes various combinations of variants with RJ45 and fibre optic ports. Automatic detection of the transmission rate (auto-negotiation) and of the wiring of the twisted pair data cable (auto-polarity and auto-MDI(X)) allow for simple plug and play. All variants are available with the temperature ranges "Industrial" and "Commercial". Technical characteristics Switch features Ethernet ports 10BASE-Te / 100BASE-TX EEE Enclosure width 120 mm Number of ports 5, 7, 8 Type of connection RJ45 Auto-negotiation Yes Yes Switching technology Store and Forward Auto-polarity Supported standards IEEE 802.3 Frame Size Auto-MDI(X) 1552 bytes MAC table size Transfer conditions 1k entries Transfer speed 448 kbit 10 / 100 Mbit/s Transfer length 100 m (twisted pair, Cat 5) Packet buffer size Non-blocking Yes Quality of Service Yes Energy Efficient Ethernet Yes PROFINET compatible Yes EthernetIP compatible Yes Yes Twisted pair Ethernet ports 100BASE-FX Type of fibre Multi-mode (MM) Type of connection Transfer conditions FOC Wavelength Power supply 1310 nm Transfer speed Nominal voltage 24 VDC Permissible voltage range 48 VDC Yes Reverse polarity proof Yes 3.20 A Overcurrent protection at input Max. power consumption @ 24 VDC Conductor cross-section Type of connection Pinout 6.40 A Input sensitivity 7.20 A Yes (4 A) 1.2 W ... 3.36W 0.08 mm² ... 2.5 mm² (28 AWG ... 12 AWG) 3-pole, pluggable screw type terminal block +/-/ Supply circuit (according to 60950) Transfer length Output power 9 VDC ... 60 VDC Surge protection Starting current 54 VDC SELV (circuit breaker 10 A) HARTING Technology Group P.O.Box 1473, D-32325 Espelkamp Wilhelm-Harting-Straße 1, D-32325 Espelkamp, Germany ICPN-Service@harting.com | Service hotline: +49 5772 47-9479 Fax: +49 5772 47-495 | www.HARTING.com/de/ethernet-switches Single-mode (SM) SC Duplex 100 Mbit/s 2 km 15 km -19 dBm ... -14 dBm -15 dBm ... -8 dBm ≤ -32 dBm ≤ -34 dBm Environmental conditions Commercial temperature range Industrial temperature range Storage temperature range 0 °C ... +55 °C -40 °C ... +70 °C -40 °C ... +85 °C Relative humidity (operation) 0% ... 95 % (not-condensing) Relative humidity (storage and transport) 0% ... 95 % (not-condensing) Air pressure 2000 m (795 hPa) Note: We reserve the right to make technical changes to the products and to the content of this document at any time without prior notification. The HARTING Technologiegruppe does not accept any responsibility for possible errors or incompletions in this document. We reserve all the rights to this document and the topics and illustrations contained within it. Copying, disclosure to third parties or use of its content - even partially - is forbidden without the prior written consent of the HARTING Technologiegruppe. PoE Enclosures Number of PoE ports 4 Standard IEEE 802.3af / IEEE 802.3at PoE type PSE Supported mode Alternative A Power supply PSE 48 VDC Maximum Power consumption Maximum output power PSE 54 VDC 375 mA 638 mA 15.4 W per port 61.6 W total 34.2 W per port 136.8 W total Supported cabling See 802.3at, section 33.1.4 PoE pinout Alternative A, MDI-X (1/2 = V-, 3/6 = V+) Status and diagnostic displays Power ("Pwr") illuminated green Supply voltage is applied Link/Activity ("L/A") off No link Link/Activity ("L/A") illuminated green Link/Activity ("L/A") flashes green Link is active Link is active and data is transferred Link speed ("Spd") off 10 Mbit/s Link speed ("Spd") illuminated yellow 100 Mbit/s PoE status off PoE is inactive / low voltage PoE status illuminated green Voltage in PoE range PoE status illuminated blue Voltage in PoE+ range PoE status illuminated red Fault Enclosure width Dimensions H x W x D (without pluggable screw type terminal block and holding bracket) Weight 120 mm 113.5 mm x 120 mm x 27.3 mm 364 g ... 420 g Type of installation 35 mm DIN rail acc. to EN 60 715 Material enclosures Anodised aluminium Protection class (with pluggable screw type terminal block) IP30 Protection class III Approvals CE, FCC CFR 47 Part 15, cUL US 508 listed, DNV, GL, ABS, NK, ABB IIT EMC and environmental conditions EMC interference immunity (EN 61000-6-1, 61 000-6-2 55024) Electrostatic discharge (ESD) EN 61 000-4-2 Electromagnetic field EN 61 000-4-3 Rapid transients (burst) EN 61 000-4-4 Surge voltages EN 61 000-4-5 Conducted interference voltages EN 61 000-4-6 EMC interference emission (EN 61000-6-4, EN 55 022, FCC CFR 47 Part 15) Mechanical stability (EN 60721-3) IEC 60068-2-6 Vibration IEC 60068-2-6 Resonance search IEC 60068-2-27 Shock test Included in delivery ■ Pluggable screw type terminal block for power supply ■ Installation instructions Drawings Technical characteristics / order information Ports / order information Commercial temp.: 0 °C ... +55 °C Industrial temp.: -40 °C ... +70 °C SC Enclosure width Power consumption @ 24 VDC without PoE MTBF in million h - - 120 mm 0.05 A 0.84 Ha-VIS eCon 2050B-A-P 24 02 005 0030 Ha-VIS eCon 2050BT-A-P - 1x MM (2 km) 120 mm 0.10 A 0.78 Ha-VIS eCon 2061B-AD-P 24 02 006 1130 Ha-VIS eCon 2061BT-AD-P 24 02 006 1120 6 - 1x SM (15 km) 120 mm 0.09 A 0.79 Ha-VIS eCon 2061B-AF-P 24 02 006 1230 Ha-VIS eCon 2061BT-AF-P 24 02 006 1220 6 - 2x MM (2 km) 120 mm 0.14 A 0.76 Ha-VIS eCon 2062B-AD-P 24 02 006 2130 Ha-VIS eCon 2062BT-AD-P 24 02 006 2120 6 - 2x SM (15 km) 120 mm 0.12 A 0.78 Ha-VIS eCon 2062B-AF-P 24 02 006 2230 Ha-VIS eCon 2062BT-AF-P 24 02 006 2220 8 - - 120 mm 0.07 A 0.73 Ha-VIS eCon 2080B-A-P 24 02 008 0030 Ha-VIS eCon 2080BT-A-P 24 02 008 0020 RJ45 SFP 5 6 Copyright© 2014 HARTING Technology Group All rights reserved Date of issue 02.2015 ICPN Datasheet 0836/01 Switch Part no. Switch Part no. 24 02 005 0020
24020061120 价格&库存
很抱歉,暂时无法提供与“24020061120”相匹配的价格&库存,您可以联系我们找货
