2606-1359
2606-1359
    WAGO(万可电子)
    插件
    接线端子
2606-1359 数据手册
Data sheet  |  Item number: 2606-1359 PCB terminal block; lever; 6 mm²; Pin spacing 12.5 mm; 9-pole; Push-in CAGE CLAMP®; 6,00 mm²; gray www.wago.com/2606-1359 Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 01.06.2020    Page 1/6 Data sheet  |  Item number: 2606-1359 www.wago.com/2606-1359 L = (pole no. – 1) x pin spacing + 9 mm Item description PCB terminal blocks with levers and Push-in CAGE CLAMP® connection Push-in termination of solid and ferruled conductors Intuitive and tool-free operation Several clamping units can be held open simultaneously – convenient for terminating multi-core cables Testing can be performed both parallel and perpendicular to conductor entry Data Electrical data Ratings per IEC/EN 60664-1 Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 800 V Rated surge voltage (III/3) 8 kV Rated voltage (III/2) 1000 V Rated surge voltage (III/2) 8 kV Nominal voltage (II/2) 1000 V Rated surge voltage (II/2) 8 kV Rated current 41 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 01.06.2020    Page 2/6 Data sheet  |  Item number: 2606-1359 www.wago.com/2606-1359 Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Approvals per UL 1059 Rated voltage UL (Use Group B) 600 V Rated current UL (Use Group B) 42 A Rated voltage UL (Use Group C) 600 V Rated current UL (Use Group C) 42 A Connection data Connection technology Push-in CAGE CLAMP® Actuation type Lever Solid conductor 0,2 … 10 mm² / 24 … 8 AWG Fine-stranded conductor 0,2 … 10 mm² / 24 … 8 AWG Fine-stranded conductor; with insulated ferrule 0,25 … 6 mm² Fine-stranded conductor; with uninsulated ferrule 0,25 … 6 mm² Fine-stranded conductor; with twin ferrule 0,25 … 2,5 mm² Strip length 11 … 13 mm / 0.43 … 0.51 inch Conductor connection direction to PCB 0  ° Pole No. 9 Total number of connection points 9 Total number of potentials 9 Number of connection types 1 Number of levels 1 Geometrical Data Pin spacing 12,5 mm / 0.492 inch Width 109,0 mm / 4.291 inch Height 28 mm / 1.102 inch Height from the surface 24 mm / 0.945 inch Solder pin length 4 mm Solder pin dimensions 1,5 x 1,2 mm Drilled hole diameter with tolerance 2 (+0,1) mm PCB contact PCB contact THT Solder pin arrangement over the entire terminal strip (in-line) Number of solder pins per potential 2 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 01.06.2020    Page 3/6 Data sheet  |  Item number: 2606-1359 www.wago.com/2606-1359 Number of solder pins per potential 2 Material Data Color gray Material group I Insulation material Polyamide 66 (PA 66) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Electrolytic copper (ECu) Contact plating tin-plated Color of actuator orange Weight 47.8 g Environmental Requirements Limit temperature range -60 … +105 °C Commercial data Packaging type BOX Country of origin DE GTIN 4055143862134 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CSA DEKRA Certification B.V. C22.2 70146882 KEMA/KEUR DEKRA Certification B.V. EN 60947-7-4 71107864 Approval Additional Approval Text Certificate name UL UL 1059 20190731- UL-Approvals Logo Underwriters Laboratories Inc. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com E45172 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 01.06.2020    Page 4/6 Data sheet  |  Item number: 2606-1359 www.wago.com/2606-1359 Underwriters Laboratories Inc. E45172 Counterpart Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 3.6 MB Download URL Download CAD/CAE-Data PCB Design Symbol and Footprint 2606-1359 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 01.06.2020    Page 5/6 Data sheet  |  Item number: 2606-1359 www.wago.com/2606-1359 TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian Handling Instructions Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 01.06.2020    Page 6/6
2606-1359 价格&库存
很抱歉,暂时无法提供与“2606-1359”相匹配的价格&库存,您可以联系我们找货
    • 10+83.7816610+10.87060
    • 50+75.4209150+9.78580
    库存:158
    2606-1359
      • 8+120.93421
      • 24+115.17889
      • 95+109.96767
      库存:158
