Data sheet | Item number: 284-601
2-conductor through terminal block; 10 mm²; lateral marker slots; for DIN-rail
35 x 15 and 35 x 7.5; CAGE CLAMP®; 10,00 mm²; gray
www.wago.com/284-601
Color:
Data
Electrical data
Ratings per IEC/EN 60664-1
Ratings per
IEC/EN 60947-7-1
Nominal voltage (III/3)
800 V
Rated surge voltage (III/3)
8 kV
Rated current
57 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Connection data
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Connectable conductor materials
Copper
Solid conductor
0,2 … 10 mm² / 24 … 8 AWG
Fine-stranded conductor
Strip length
12 … 13 mm / 0.47 … 0.51 inch
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
01.06.2020 Page 1/11
Strip length
Total number of connection points
2
Total number of potentials
1
Number of levels
1
Wiring type
Front-entry wiring
Geometrical Data
Width
10 mm / 0.394 inch
Height from upper-edge of DIN-rail
33,5 mm / 1.319 inch
Depth
69 mm / 2.717 inch
Mechanical data
Design
horizontal type
Mounting type
DIN-35 rail
Marking level
Side marking
Material Data
Color
gray
Insulation material
Polyamide 66 (PA 66)
Fire load
0.253 MJ
Weight
18.9 g
Commercial data
Product Group
1 (Rail Mounted Terminal Blocks)
Packaging type
BOX
Country of origin
DE
GTIN
4044918486361
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60947
NTR NL7379
CSA
C22.2 No. 158
1536073
Hansastr. 27
32423 Minden
01.06.2020 Page 2/11
KEMA/KEUR
EN 60947
2178517.01
Approval
ABS
American Bureau of Shipping
EN 60947
20HG1941090PDA
BV
Bureau Veritas S.A.
EN 60947
07436/E0 BV
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
LR
Lloyds Register
EN 60947
91/20112
(E9)
Ship Approvals
Logo
Certificate
name
UL-Approvals
Logo
Approval
UL
UL International Germany GmbH
UL 1059
Certificate
name
20190731E45172
Counterpart
Compatible products
Hansastr. 27
32423 Minden
01.06.2020 Page 3/11
End plate
Item no.: 284-327
Separator plate; 2 mm thick; oversized; orange
www.wago.com/284-327
Item no.: 284-334
Step-down cover plate; 1 mm thick; for 2-, 3- and 4-conductor terminal blocks; gray
www.wago.com/284-334
Item no.: 284-337
Separator plate; 2 mm thick; oversized; gray
www.wago.com/284-337
Item no.: 284-338
Separator plate; 2 mm thick; oversized; light gray
www.wago.com/284-338
Item no.: 284-344
Step-down cover plate; 1 mm thick; for 2-, 3- and 4-conductor terminal blocks; orange
www.wago.com/284-344
Item no.: 284-415
Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow
www.wago.com/284-415
protection
Carrier rail
Item no.: 210-112
www.wago.com/210-112
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-113
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715
www.wago.com/210-114
Item no.: 210-115
www.wago.com/210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-118
Item no.: 210-196
www.wago.com/210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored
www.wago.com/210-198
Hansastr. 27
32423 Minden
01.06.2020 Page 4/11
colored
Item no.: 210-504
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715
www.wago.com/210-504
Item no.: 210-505
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715
www.wago.com/210-505
Item no.: 210-506
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715
www.wago.com/210-506
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715
www.wago.com/210-508
Marking accessories
Item no.: 2009-115
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-115
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
/000-002
Item no.: 2009-115/000-006
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-115/000-007
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-115/000-012
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-115/000-017
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light
green
/000-017
Item no.: 2009-115/000-023
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 2009-115/000-024
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 249-105
Group marker carrier; gray
www.wago.com/249-105
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/793-501
Item no.: 793-501/000-002
WMB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Hansastr. 27
32423 Minden
01.06.2020 Page 5/11
Item no.: 793-501/000-005
WMB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 793-501/000-006
WMB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 793-501/000-007
WMB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 793-501/000-012
WMB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 793-501/000-017
WMB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 793-501/000-023
WMB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 793-501/000-024
WMB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
type; white
Item no.: 793-5501/000-002
/000-002
type; yellow
Item no.: 793-5501/000-005
/000-005
type; red
Item no.: 793-5501/000-006
/000-006
type; blue
Item no.: 793-5501/000-007
/000-007
type; gray
Item no.: 793-5501/000-012
/000-012
type; orange
Item no.: 793-5501/000-017
Hansastr. 27
32423 Minden
01.06.2020 Page 6/11
type; green
/000-017
Item no.: 793-5501/000-023
/000-023
type; light green
Item no.: 793-5501/000-024
/000-024
type; violet
check
Item no.: 209-170
Test plug adapter; 8.3 mm wide; for 4 mm Ø test plugs; suitable for 1.5 mm² - 10 mm² tbs; gray
www.wago.com/209-170
Item no.: 209-106
Mounting carrier; for isolated mounting on DIN 35 rails; gray
www.wago.com/209-106
Item no.: 709-154
Cover; Type 2; suitable for cover carrier, type 2; 1 m long; transparent
www.wago.com/709-154
Item no.: 210-721
Operating tool; Blade: 5.5 x 0.8 mm; with a partially insulated shaft
www.wago.com/210-721
assembling
tools
General accessories
Item no.: 284-400
Finger guard; touchproof cover protects unused conductor entries; yellow
www.wago.com/284-400
Item no.: 709-310
B-type test plug module; modular; suitable for all WAGO 282 Series rail-mounted terminal blocks with
jumper slots; 6,00 mm²; gray
www.wago.com/709-310
Item no.: 709-311
B-type spacer module; modular; e.g., for bridging commoned terminal blocks; gray
www.wago.com/709-311
Item no.: 709-312
B-type intermediate plate; modular; snaps on 709-310 B-type test plug modules and 709-311 B-type
spacer modules; Module width 2 mm; gray
www.wago.com/709-312
Item no.: 284-402
Adjacent jumper; insulated; Nominal current 57 A; gray
www.wago.com/284-402
Item no.: 284-409
Alternate jumper; insulated; Nominal current 57 A; gray
www.wago.com/284-409
Item no.: 284-413
Step-down jumper; insulated; from 10/6 mm² to 6/4 mm²; Nominal current 30 A; gray
www.wago.com/284-413
Jumper
Item no.: 284-414
Hansastr. 27
32423 Minden
www.wago.com/284-414
01.06.2020 Page 7/11
Item no.: 284-414
Step-down jumper; insulated; from 10/6 mm² to 4/2.5/1.5 mm²; Nominal current 15 A; gray
Item no.: 284-422
Adjacent jumper; insulated; Nominal current 57 A; yellow-green
www.wago.com/284-422
Item no.: 216-108
Ferrule; Sleeve for 6 mm² / AWG 10; uninsulated; electro-tin plated
www.wago.com/216-108
ferrule
Item no.: 216-208
Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-208
acc. to DIN 46228, Part 4/09.90; yellow
Item no.: 216-262
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-262
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-264
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-264
Item no.: 216-266
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; blue
www.wago.com/216-266
Item no.: 216-267
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-267
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.1 MB
Download
URL
Download
EPLAN Data Portal 284-601
URL
Download
WSCAD Universe 284-601
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 284-601
CAE data
Hansastr. 27
32423 Minden
01.06.2020 Page 8/11
Handling Instructions
Assembly
Snapping a terminal block onto the carrier
rail.
Quick assembly keys prevent reverse
mounting.
Removing a terminal block from the
assembly.
Steel carrier rails are not suited for PEN
(ground and N-conductor) applications per
EN 60947-7-2 (VDE 0611, Part 3).
Inserting a conductor
Hansastr. 27
32423 Minden
01.06.2020 Page 9/11
CAGE CLAMP® connection
Inserting a conductor.
Removing a conductor.
With ferruled conductors, it is necessary to
use a terminal block one size larger than the
conductor’s nominal cross-section.
Jumpered
Commoning using an adjacent jumper
(280‑402).
Push jumper down until fully inserted.
Testing
Hansastr. 27
32423 Minden
01.06.2020 Page 10/11
Testing with a test plug
(picture shows 209‑170 Test Plug Adapter).
Snapping test plug and spacer modules
(each with a spacer plate) together to
assemble a multi-pole test plug module
(max. 10 poles) for 10 mm terminal block
width.
The test plug modules are directly plugged
into the jumper contact slot of the current
bar (picture shows 284 Series).
Cover
Protective warning markers inserted into the
operating slots.
Finger guard seals an unused conductor
entry.
Marking
Marking via WMB Multi Marking System.
Hansastr. 27
32423 Minden
01.06.2020 Page 11/11
很抱歉,暂时无法提供与“284-601”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+96.676901+12.56341
- 10+68.6344310+8.91922
- 25+60.6851825+7.88620
- 50+55.8715550+7.26065
- 100+51.97096100+6.75376
- 250+47.99748250+6.23740
- 500+45.72134500+5.94161
- 1000+43.944711000+5.71073
- 国内价格 香港价格
- 10+91.6769610+11.91366
