857-150
857-150
    WAGO(万可电子)
    插件
857-150 数据手册
Data sheet | Item number: 857-150 Basic relay; Nominal input voltage: 12 VDC; 1 changeover contact; Limiting continuous current: 6 A; Module width: 5 mm; Module height: 15 mm www.wago.com/857-150 i Picture differs from the item. Similar to picture DC load limit curve Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 1/5 Data sheet | Item number: 857-150 www.wago.com/857-150 Item description Note: The 60 VDC basic relay must be used for 60 VDC, 110 VDC, 220 VDC and 115 VAC/DC, 230 VAC/DC relay modules. To protect the relay coils and contacts, inductive loads must be dampened with an effective protection circuit. 30 VDC switching voltages and 50 mA currents must not be exceeded for gold-plated basic relays. Higher switching power eventually evaporates the gold layer. The resulting deposits in the housing may reduce service life. Data Technical data Control circuit Nominal input voltage UN DC 12 V Nominal input current at UN 0 Load circuit Number of changeover/switchover contacts 1 Contact material (relay) AgSnO2 Limiting continuous current 6 A Inrush current (resistive) (max.) (AC) 20 A / 0.02 s Switching voltage (max.) AC 250 V Switching power (resistive) (max.) AC 1500 VA; DC (see load limit curve) Switching capacity AC-15: 3 A / AC 250 V; DC-13: 2 A / DC 24 V Recommended minimum load 10 V / 10 mA; 24 V / 1 mA Pull-in time (typ.) 8 ms Drop-out time (typ.) 4 ms Bounce time (typ.) 3.5 ms Electrical life (NO; resistive load; 23 °C) 50 x 103 switching operations Mechanical life 5 x 106 switching operations Switching frequency with/without load (max.) 6 min-1 / 180 min-1 Safety and protection Dielectric strength, control/load circuit (AC, 1 min) 4 kVrms Dielectric strength, open contact (AC, 1 min) 1 kVrms Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 2/5 Data sheet | Item number: 857-150 www.wago.com/857-150 Dielectric strength, open contact (AC, 1 min) 1 kVrms Protection type IP20 Physical data Width 5 mm / 0.197 inch Height from the surface 15 mm / 0.591 inch Depth 28 mm / 1.09 inch Mechanical data Mounting type Pluggable module Material data Weight 4.7 g Environmental requirements Surrounding air temperature (operation at UN) -40 … 85 °C Surrounding air temperature (storage) -40 … 85 °C Relative humidity 5 … 85 % (no condensation permissible) Operating altitude (max.) 2000 m Standards and specifications Standards/Specifications EN 61810-1; EN 61373; VDE; UR Commercial data Product Group 6 (Interface Electronics) Packaging type BOX Country of origin CZ GTIN 4050821868293 Customs tariff number 85364900990 Approvals / Certificates UL-Approvals Logo Approval Additional Approval Text Certificate name UL Underwriters Laboratories Inc. UL 508 E340707 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 3/5 Data sheet | Item number: 857-150 www.wago.com/857-150 Compatible products plug base Item no.: 857-104 Relay socket; Nominal input voltage: 24 V AC/DC; for 5 mm basic relays; Yellow status indicator www.wago.com/857-104 Downloads Documentation Bid Text 857-150 2019 Feb 19 xml 4.3 kB Download 2018 Nov 29 doc 27.1 kB Download V 1.0.0 pdf 265.8 kB Download URL Download ZUKEN Portal 857-150 URL Download WSCAD Universe 857-150 URL Download EPLAN Data Portal 857-150 URL Download X81 - Datei 857-150 doc - Datei Additional Information Disposal; Electrical and electronic equipment, Packaging CAD/CAE-Data CAD data 2D/3D Models 857-150 CAE data Environmental Product Compliance Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 4/5 Data sheet | Item number: 857-150 www.wago.com/857-150 Compliance Search Environmental Product Compliance 857-150 URL Download Basic relay; Nominal input voltage: 12 VDC; 1 changeover contact; Limiting continuous current: 6 A; Module width: 5 mm; Module height: 15 mm Installation Notes Installation Removing a relay via ejector. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 20.05.2021    Page 5/5
857-150 价格&库存
很抱歉,暂时无法提供与“857-150”相匹配的价格&库存,您可以联系我们找货
  • 1+135.75478
库存:1
