B10B-XADSS-N-A(T)(LF)(SN)
    JST
    插件,P=2.5mm
    线对板针座 2x5P 直插 间距:2.5mm
B10B-XADSS-N-A(T)(LF)(SN) 数据手册
ラジアル XAD CONNECTOR 2.5mm pitch/Disconnectable Crimp style connectors Specifications ––––––––––––––––––– • Current rating: 3A AC, DC (AWG #20) • Voltage rating: 250V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/10m Ω max. After environmental testing/20m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 1,000V AC/minute • Applicable wire: AWG #28 to #20 • Applicable PC board thickness: 1.6mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Double-row construction connector with secure locking device. Standards –––––––––––––––––––––– • Secure locking device • Solder crack preventive material • Polarizing boss • Mis-insertion preventive design 0 Recognized E60389 1 Certified LR20812 2 R9851219 PC board layout (viewed from component side) and Assembly layout Top entry type 11.5 With a boss +0.1 φ0.9 0 Without a boss 0.1 φ0.9+  0 Circuit No.1 1.7±0.05 A±0.05 Side entry type 2.5±0.05 Even number circuits Odd number circuits 13.8 2.5±0.05 2.5±0.05 1.8±0.05 Even number circuits Odd number circuits 2.5±0.05 +0.1 φ1.1 0 Circuit No.1 A±0.05 2.8±0.05 2.5±0.05 A±0.05 13.5 2.5 ±0.05 Even number circuits 7.6±0.05 Circuit No.1 Odd number circuits 2.0±0.05 19.9 0.1 φ0.9+  0 Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 1 XAD CONNECTOR Contact Model No. 1.9 SXA-01T-P0.6 SXA-001T-P0.6 SXA-001T-P0.6L Applicable wire mm2 AWG# 0.22∼0.5  0.08∼0.33 0.13∼0.33 6.5 3.1 1.3 Insulation O.D. (mm) Q'ty / reel 24∼20 1.5∼1.9 8,000 28∼22 0.8∼1.9 8,000 26∼22 1.3∼1.7 8,000 Material and Finish 1.6 Phosphor bronze, tin-plated (reflow treatment) 2.3 RoHS compliance Note: 1. SXA-001T-P0.6L is low-insertion force type contact, for easier insertion/withdrawal, which would be less resistant to the vibration. The crimp height is different from the standard contact. 2. Contact JST for gold-plated products. Crimping machine Crimp applicator Contact SXA-001T-P0.6 AP-K2N SXA-001T-P0.6L Applicator Dies Crimp applicator with dies MKS-L MK/SXA/M-001-06 APLMK SXA/M001-06 *MKS-SC SC/SXA/M-001-06 APLSC SXA/M001-06 MKS-L MK/SXA-001-06L APLMK SXA001-06L *MKS-SC SC/SXA-001-06L Contact SXA-01T-P0.6 Crimping machine Crimp applicator AP-K2N MKS-L *MKS-SC Applicator Dies Crimp applicator with dies MK/SXA/M-01-06 APLMK SXA/M01-06 SC/SXA/M-01-06 APLSC SXA/M01-06 Note:*Strip-crimp applicator APLSC SXA001-06L Housing (8 to 16 circuits) B A 2.5 Circuit No.1 mark 3.6 11.4 12.0 6.8 H JST 12 (18 to 40 circuits) B A 2.5 Circuit No.1 mark 3.6 11.4 12.0 6.8 H JST 30 Circuits Model No. Dimensions (mm) A B 8 XADRP-08V 7.5 14.7 1,000 10 XADRP-10V 10.0 17.2 1,000 12 XADRP-12V 12.5 19.7 1,000 14 XADRP-14V 15.0 22.2 1,000 16 XADRP-16V 17.5 24.7 1,000 18 XADRP-18V 20.0 27.2 1,000 20 XADRP-20V 22.5 29.7 500 22 XADRP-22V 25.0 32.2 500 24 XADRP-24V 27.5 34.7 500 26 XADRP-26V 30.0 37.2 500 28 XADRP-28V 32.5 39.7 500 30 XADRP-30V 35.0 42.2 500 32 XADRP-32V 37.5 44.7 500 34 XADRP-34V 40.0 47.2 500 36 XADRP-36V 42.5 49.7 250 40 XADRP-40V 47.5 54.7 250 Material PA 66, UL94V-0, natural (white) RoHS compliance Note: Contact JST if retainers are required. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 2 Q'ty / bag XADRP-08V-oo(blank)…natural (white) K…black R…red E…blue O…orange M…green L…lemon yellow PK…pink XAD CONNECTOR Shrouded header Model No. Top entry type B A 2.5 8 B08B-XADSS-N B08B-XADSS-N-A S08B-XADSS-N 7.5 15.0 200 270 10 B10B-XADSS-N B10B-XADSS-N-A S10B-XADSS-N 10.0 17.5 200 234 12 B12B-XADSS-N B12B-XADSS-N-A S12B-XADSS-N 12.5 20.0 200 198 14 B14B-XADSS-N B14B-XADSS-N-A S14B-XADSS-N 15.0 22.5 150 180 16 B16B-XADSS-N B16B-XADSS-N-A S16B-XADSS-N 17.5 25.0 150 10.1 JST 12 φ0.6 162 18 B18B-XADSS-N B18B-XADSS-N-A S18B-XADSS-N 20.0 27.5 150 144 20 B20B-XADSS-N B20B-XADSS-N-A S20B-XADSS-N 22.5 30.0 100 126 22 B22B-XADSS-N B22B-XADSS-N-A − 25.0 32.5 100 − 24 B24B-XADSS-N B24B-XADSS-N-A − 27.5 35.0 100 − 26 B26B-XADSS-N B26B-XADSS-N-A S26B-XADSS-N 30.0 37.5 100 108 28 B28B-XADSS-N B28B-XADSS-N-A − 32.5 40.0 100 − 30 B30B-XADSS-N B30B-XADSS-N-A − 35.0 42.5 50 − 32 B32B-XADSS-N B32B-XADSS-N-A − 37.5 45.0 50 − 34 B34B-XADSS-N B34B-XADSS-N-A − 40.0 47.5 50 − 36 B36B-XADSS-N B36B-XADSS-N-A − 42.5 50.0 50 − 40 B40B-XADSS-N B40B-XADSS-N-A − 47.5 55.0 50 − Without a boss 2.5 1.7 (18 to 40 circuits) 1.5 H Top entry type 10.1 Circuit No.1 Mark (3.5) (8 to 16 circuits) 1.8 φ0.9 Circuit No.1 Mark B A 10.1 2.5 (3.5) 10.1 1.5 2.5 H JST 22 1.7 φ0.6 1.8 φ0.9 Dimensions (mm) Q'ty / box Top Side Side entry type A B entry entry type type Circuits With a boss Side entry type Material and Finish (8 to 16 circuits) Pin: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural (white) B A 3.5 12.1 9.9 RoHS compliance This product displays (LF)(SN) on a label. Note: Contact JST for the headers with gold-plated pins. φ0.6 16.2 10.3 2.5 2.5 2.7 2.5 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. (3.4) 9.9 (18 to 26 circuits) B A 3.5 12.1 φ0.6 9.9 2.5 2.7 16.2 10.3 2.5 2.5 B08B-XADSS-NS…natural (white) K…black R…red E…blue O…orange M…green L…lemon yellow PK…pink (3.4) 9.9 3
B10B-XADSS-N-A(T)(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“B10B-XADSS-N-A(T)(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
  • 1+5.23800
  • 10+4.44960
  • 30+4.05000
  • 100+2.26995
  • 624+2.12264
  • 936+2.04898
库存:1145
    • 1+2.44420
    • 156+2.20000
    • 312+1.98000
    库存:1533
